Что есть zapping и matched?
gennady
Можно популярно о zapping-е и о matched-е аккумуляторов. Это что-то типа “раскачки” и “форматирования”?
Lazy
Доброго дня…
  1. Matched - это батарея из селектированных по параметрам элементов (максимально близкие значения Ri, Imax., U const. и прочее).
  2. Zapped - элементы обрабатываются импульсами токов 80А и более, целью получения ещё более низкого Ri и лучших разрядных характеристик.
6egemot
  1. Zapped - элементы обрабатываются импульсами токов 80А и более, целью получения ещё более низкого Ri и лучших разрядных характеристик.
Most high current cells are made with thin metalic plates rolled up like a jelly roll. In produciton, this “jelly roll” is dropped in the case and the end cap pressed on - just a press fit between the ends of the cell and the rolled up metal plates. Zapping spot welds the end caps to the rolled up plates, decreasing the internal resistance of the cell.
Most high current cells use metal plates and most high capacity cells use a conductive foam which of course can’t be welded. That’s why some cells respond to zapping and some don’t.
Zapping is done by putting a very high current through a cell. Usually a bank of capacitors, about 70,000uF, is charged to about 70V. The energy is discharged through the cell resulting in a few thousand Amps for a very short time. This spot welds the cell’s internal connections.
The welded connections reduce the cell’s internal resistance. This results in a higher voltage under high loads. As far as we know, all serious electric flight competitors used zapped cells. At the higher currents used, the voltage increase is noticeable.
Zapping only works on some cells. It appears that only high current cells such as Sanyo SCR series and Panasonic SCP series respond to zapping. This is probably because these cells use metallic electrodes. Many high capacity cells use a foam electrode and foam can’t be welded. Both NiCd and NiMH cells can respond to Zapping.
Properly done zapping does not seem to have any negative effects on cells.
6egemot
а про matched - это нужно вот зачем:
берем несколько коробок хороших аккумуляторов kan 950. паяем тупо сборки по 8 банок и продаем. это неселектированые сборки.
а если возьмем хотя бы вольтметр, но на каждую сотню банок найдем 2-3 банки с внутренним КЗ, 2-3 банки с напряжением не 1.25, а 0.6, 0.8В… если есть чем, то можно ещё и сопротивление внутреннее померять.
таким образом у меня в 1 купленной сборке фирменной была найдена 1 банка дохлая. внутреннее КЗ. ток идет, а напряжение на банке нуль.
потому селектированные сборки и стоят дороже, что их в идеале подбирают с одинаковыми параметрами.
gennady
Посмотрите по ссылке :www.battlepack.com/loosecells.asp
zapping free - бесплатно морочится с обработкой большими токами,врядли - это скорее элементарная выбраковка, а не селекция.
matched :
www.battlepack.com/Matched.asp
  • а это уже похоже на то , что у Вас называется zapping ❓
Lazy
Да нет, всё правильно у них написано…Даже название агрегата приводят - Turbomatcher 4/35 used in matching process…
