Приобрел вот такого красавца !!!
Расчитан под 300-ый мотор с прямым приводом на винт.
Хочу поставить на него 75ый импеллер от GWS(5 лопастей,400-ый двиг)
ПБуду обтягивть пленкой.Батарея DUALSKY-1100 мА 11.1 вольт.
Принимаются советы и предложиния.
На элероны ставлю одну серву а отверстия под них на крыльях хочу заделать
Самолет выполнен из очень плотного пенопласта и отлично сформован
The Flycat is a fast speed jet plane designed for all advanced pilot. Rear drive brushed 370 motor w/ 4x3 & 5x4 propellers are incl*uded on this plane. Extremely high-speed over 100km/h can be achieved with an optional brushless motor power system. Optional Duct Fan system can also be installed on this jet plane !!
Specification
Length: 800mm
Wingspan: 640mm
Net Weight: 290gram (with motor)
Flying Weight: 420-480gram
Other Requirement:
Battery Required: Zeta-Plus 7.4V 1700mah or 11.1V 1700mah Li-po Battery(not incl*uded)
Power System: Stock 370 brushed motor is incl*uded. Optional Himark 2025-3200kv or 4200kv brushless motor w/ GWS EP4040 or EP4530 prop.(not incl*uded)
Propeller: 4x3 & 5x4 propellers x 2pc. are incl*uded
Optional Duct Fan System: GWS EDF-55
Servos Required: Pico or Naro servos x 3 (not incl*uded)
Receiver: 4ch or above FM Receiver (not incl*uded)
Speed Controller: Telebee TS-35 Brushed ESC or Otter BS25A / Towerpro 25-N Brushless motor ESC (not incl*uded)
Radio: 4 channel radio (not incl*uded)
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"3c18d79a3df95500776f10ab":{"_id":"3c18d79a3df95500776f10ab","hid":126,"name":"gennady","nick":"gennady","avatar_id":null,"css":"user__m-banned"},"4149f6603df9550077793ab7":{"_id":"4149f6603df9550077793ab7","hid":4504,"name":"boroda_de","nick":"boroda_de","avatar_id":null,"css":""},"440fb81d3df955007778c6e8":{"_id":"440fb81d3df955007778c6e8","hid":12547,"name":"hondahrv","nick":"hondahrv","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb5108","hid":36,"title":"Электролёты. Общие вопросы","parent":"61c9a54c3df9550077bb518f","description":"Самолёты с электрическими мотоустановками.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":3991,"post_count":111770,"last_post":"66b5e12e563b07d603c81f95","last_topic":"66b24d2a3627b35af44acfe5","last_topic_hid":572512,"last_topic_title":"Мотоустановка для пилотажки 1450мм.","last_ts":"2024-08-09T09:28:14.334Z","last_user":"4f3e22e13df955007774805c"}},"topic":{"_id":"449e8afe9970730077fc1749","hid":44619,"title":"FlyCat+75-ый импеллер от gws","views_count":1985,"last_post_counter":3,"cache":{"post_count":3,"first_post":"449e8afe9970730077fc1c23","first_ts":"2006-06-25T13:09:18.000Z","first_user":"440fb81d3df955007778c6e8","last_post":"44c078129970730077fc1c27","last_post_hid":3,"last_ts":"2006-07-21T06:45:38.000Z","last_user":"3c18d79a3df95500776f10ab"},"st":1,"section":"61c9a54c3df9550077bb5108"},"subscription":null,"pagination":{"total":3,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
