посоветуйте недорогой balance charger с выводом на компьютер.
посоветуйте недорогой balance charger 1 - 5 lipo с выводом на компьютер.
Чтобы можно было контролировать устройство с компа, либо хотябы анализировать данные на компе.
Перерыл и-нет - так и не нашел подходящего.
Спасибо.
PS рассматриваю как вариант rc power 601bc, возможно есть еще и подешевле.
www.rcf-hobby.com
вот тут был…
сейчас сайт почемуто не пашет…
попробуй…
по USB там был балансирчик… 100%
Specification:
Operating voltage : DC 10~18 volts
Idling current : approx. 100mA
Charge/discharge power: max. 150/30W
NiCd/MH : 1~27 cells
Li-ion/polymer : 1~8 series
Pb : 6,12 or 24V
Charge current : 0.1 to 7.0A
Discharg current : 0.1 to 5.0A
No. of cycle : 1 to 5 times
Battery data memory : up to 10 data
Weight : 570g
Dimension : 160x120x40 mm
User’s setting-up parameters
Lithium battery voltage type : 3.6 or 3.7 volt per cell
NiCd Delta-peak voltage sensitivity: 1 to 15mV
NiMH Delta-peak voltage sensitivity: 1 to 15mV
Battery temperature cut-off : 20 to 80C or OFF
Waste time between charge/discharge: 1 to 60 min.
Trickle charge mode : ON/OFF
Integral timer limit for safety : 10 to 720 min.or OFF
Maximum charging limit for safety : 10 to 9990mAh or OFF
Key beep and buzzer sound : ON/OFF
Input power low alert : 10 to 11V
LCD back-light brightness : 1 to 100 steps
USB port
We provide the program analyze the charge/discharge process at your PC
Charge/discharge graph
You can see the curves of current and voltage at your PC when the
charger links to PC via USB
Individual voltage monitoring port
701 can monitor the voltage of each cell up to 8 cells of NiCd, NiMH
or Li-poly battery being charged during charge/discharge process.
If the voltage of a peculiar cell raises or drops other than normal by
any reason the process will be terminated forcibly for safety reason.
At the end of abnormal finishing process, you can read the voltage of
the cell at the display with an error message.
You can pick out the bad cell of the battery pack.
This program does not have the voltage balancing function.
Temperature sensor
The processor monitors the temperature of the battery being charged
or discharged during the process.
For safety reason, the charger can stop the process at high temperature
by your set up.
Intelligent cooling fan
Side-mounted cooling fan operates only when internal temperature
of the charger raises.
Back-light LCD screen
You can adjust the brightness of LCD display
Robust outer aluminum case
High-quality aluminum case is durable and very efficient to cool
out the internal heat
260 нерусских рублей…
как вам?
вот фото
Самое лучшее, к чему я пришел - www.pilotage-rc.ru/catalogue/80_/80_20/RC7308/
Зарядник тогда играет вообще второстепенную роль.
Я пользуюсь Robbe PowerPeak Fun (мне для 6 банок нужно было). Дешево и сердито.
Про сам балансир я подробно расписал тут: rcopen.com/forum/f4/topic60029
Доволен как слон. Деньги оправдывает на 100%
На комп выводит любой параметр, по каждой банке. Хотя я уже его к компу не подключаю - сам все делает, контроль не нужен (если только для отбраковки банок)
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"3f4d22d83df9550077795e64":{"_id":"3f4d22d83df9550077795e64","hid":2115,"name":"collapse","nick":"collapse","avatar_id":null,"css":""},"421a40f73df9550077792123":{"_id":"421a40f73df9550077792123","hid":6137,"name":"jedi","nick":"jedi","avatar_id":null,"css":""},"4580643a3df9550077787777":{"_id":"4580643a3df9550077787777","hid":18920,"name":"nikitae","nick":"nikitae","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50a8","hid":4,"title":"Аппаратура радиоуправления","parent":"61c9a54c3df9550077bb50fc","description":"Приёмники и передатчики для радиоуправляемых моделей.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":9173,"post_count":222071,"last_post":"6789167e6bffb2a5448ce1d6","last_topic":"5b3dc11c3df9550077c95ffc","last_topic_hid":525495,"last_topic_title":"решение вопросов с приемниками FrSky","last_ts":"2025-01-16T14:23:58.233Z","last_user":"4d35d1103df9550077757380"}},"topic":{"_id":"45d0b9b29970730077f664dd","hid":60435,"title":"посоветуйте недорогой balance charger с выводом на компьютер.","views_count":1883,"last_post_counter":4,"cache":{"post_count":4,"first_post":"45d0b9b29970730077f66faa","first_ts":"2007-02-12T19:02:10.000Z","first_user":"4580643a3df9550077787777","last_post":"45f3417a9970730077f66fb0","last_post_hid":4,"last_ts":"2007-03-10T23:38:34.000Z","last_user":"3f4d22d83df9550077795e64"},"st":1,"section":"61c9a54c3df9550077bb50a8"},"subscription":null,"pagination":{"total":4,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
