Покраска белых рычагов RPM Dyeable Parts
Всем привет!
Подскажите, чем можно покрасить сабж в домашних условиях. Пиндосы советуют развести специальную краску Rit™ в воде. Но можно ли использовать какие-либо легко доступные в Москве и недорогие аналоги? Меня в теории такой водяной метод покраски устраивает, но про подобные краски не слышал. Тока про нитру и гуашь с акварелью 😃
Цвет хочу оранжевый 😒
Вот что пишут про покраску на англ:
_All RPM nylon parts can be dyed with outstanding results! This includes parts that are natural white, yellow, blue, etc. The key to remember is that you can only dye a part darker than its current color. For example, a yellow part can be dyed orange, red, green ,blue, purple, etc., yet a blue part can only be dyed a darker shade of blue, dark purple or black.
To get started, simply boil some water, add some Rit™ clothing dye of the color you want the parts to be to the boiling water (start with a small amount of dye and add more later if the parts don’t reach the desired color depth - don’t forget to remove the parts from the solution before adding more dye), and then place your new RPM dyeable parts in the water. Be sure that the dye is completely saturated in the water before adding your parts! The depth and shade of the color will vary depending on time left in the water/dye solution, the amount of dye used, and the temperature of the water. Usually, higher concentrations of dye darken the color of the parts faster, as will higher water temperatures. Use caution because the parts will look lighter in color when first removed from the hot water. When the color looks close, but still slightly lighter than what you want, remove the parts from the water/dye solution and let them cool. They will darken slightly after cooling. If they aren’t quite dark enough at this point, place them back in the solution for a brief time until the color is to the tint of your choice.
Important note: To make all of your parts identical in color, either dye all of them at the same time, or take careful notes during the dyeing process such as;
- Water temperature (i.e. fast boil, slow simmer, etc.).
- Amount of dye and water used.
- Type and manufacturer of the dye.
- Time the parts spent in the dye solution.
Additionally: Because this is a dyeing process of the parts, and not a plating process, the dye will have absolutely no effect on the adhesive bond when tires are glued to our dyeable wheels._
Это всё очень напоминает покраску коннекторов для компа у “оверклокеров”, их тоже варили в растворе пигмента. Как вариант - промыть содержимое яркого маркера для выделения текста - и в смыве сварить. Ну или искать нужный пигмент - и варить в нём…
Антон, я правильно понимаю, что данные рычаги как бы “впитывают” краску? Где лучше поискать продажу подобных пигментов?
Анилиновый краситель для ткани?
Совершенно верно, при варке пигмент диффундирует в толщу рычага.
Верно, анилиновые красители будут отлично работать.
Потратил полчаса, так и не нашёл ничего по теме - как будто статьи пятилетней давности испарились отовсюду…
В общем - нужно искать пигмент, для окраски нейлона/капрона или подобных вещей.
Пигмент растворяется в воде, вода нагревается до кипения, варим в ней рычаги 10-15 минут. Это дольше, чем обычная варка нейлона, но если варить недостаточно - плохо прокрасится. Желательно варить все детали сразу - иначе будет разница в оттенке.
После остывания промыть детали в слабом растворе уксуса.
Вроде всё, что сохранил мой мозг.
варить
А нужно прям варить в кипятке или просто держать в воде, которая только что закипела?
я до кипения не доводил. просто в горячей воде держал, подогревая ее изредка.
Если будите касить не в черный, то рекомендую профильтровать жидкость после растворения в ней краски. иначе могут быть ярки “точки” от плохо растворившегося красителя. краситель использовал для капрона
обратись к Сане Зайцеву (dralexsimpson) он красил, и вроде краска есть.
