Turnigy TR52DV
Как раз на эту камеру я где - то видел мануал… щас поищу…
а, ну да, там же в комментах есть на него ссылка. www.hobbyking.com/…/57465344X43556X26.pdf
Вот и дрова www.hobbyking.com/…/794328834X133299X45.zip
Если еще не нашли, я месяц назад тоже искал. Вот что нашел:
Hobby King TR52DV Camera Instructions.
I finally got my HOBBY KING TURNIGY TR52DV and found the lack of instructions made it very difficult for me to operate the camera. After doing a lot of reading and searching on the web, I came up with the following.
If this helps you, or if you have more information, or see something that needs correction, please let me know. Thanks.
Fly4Fun,
Wayne
MODE INSTRUCTIONS FOR HOBBY KING TURNIGY TR52DV CAMERA:
There is no Yellow or Green lights on new camera. These instructions are for cameras with the red and blue lights.
You can use either Abreviated or Detailed instructions listed below.
ABBREVIATED INSTRUCTIONS:
NOTE: MODE button is identified with M. EXECUTE or FUNCTION (Start/Stop) button is identified with a circle and square.
The mode sequence is:
Turn on SWITCH
Push Mode (M) button for voice activated video (Mode 1) - Push EXECUTE or FUNCTION to Start/Stop
Push Mode (M) again for manual activated video (Mode 2) - Push EXECUTE or FUNCTION to Start/Stop
Push Mode (M) again for picture (snapshot) (Mode 3) - Push EXECUTE or FUNCTION to take snapshot
Push Mode (M) again for voice recording (Mode 4) - Push EXECUTE or FUNCTION to Start/Stop
Holding Mode button in will turn camera off at any time (red light goes out). Do not use on/off switch before Mode button turns off camera or camera and pictures will reset.
DETAILED INSTRUCTIONS:
- Power on.
- Press M. Red light is on. Now the camera on in voice activated mode and will allow video recording with voice activation. Push EXECUTE or FUNCTION (Start/Stop) button identified with a circle and square to start and then stop recording.
Blue light blinks slow while recording - Press M again. Mode changes but light remains red. This is manual video mode. Push EXECUTE or FUNCTION (Start/Stop) button identified with a circle and square to start and then stop recording.
Blue light blinks fast while recording. - Press M again. Mode changes to take picture mode but light remains red. Push EXECUTE or FUNCTION (Start/Stop) button identified with a circle and square to start and then stop recording to take a picture.
Blue light blinks when picture taken - Press M again. Mode changes to voice recording but light is the same red. Push EXECUTE or FUNCTION (Start/Stop) button identified with a circle and square to start and then stop recording.
Blue light stays on while recording - Press and hold M at any time until the red light goes off to turn camera off.
NOTE: In any mode, you can start/ stop recording and then start/stop a second recording with out exiting the Mode.
NOTE: Do not turn camera switch off until you hold the MODE button and lights go off or camera will be reset and pictures will be lost.
Viewing Pictures:
With camera switch off, plug into computer with USB cable Red and Blue lights will be on. Use Windows Explorer to get pictures/audio from camera. The camera will be shown as a disk in Explorer. Look under directory DCMI and 100MEDIA for pictures
Go to Hobby King web page and read reviews for up to date information. Here is the link:
www.hobbycity.com/hobbycity/…/uh_viewItem.asp?idPr…
Original Manual location (not for new camera):
www.hobbyking.com/hobbycity/store/…/hk52.zip
Друг заказал такую ж камеру, вот тоже разобраться не могли, как раз отсутствие зеленого и желтого и ввело в заблуждения.
Имеется для камеры такая вот программка установки времени.
Скачиваем, делаем. Задаем программке “white camera HK-52” появляется в камере файлик time.txt, результат нулевой, камера думает что 2008й на дворе.
Задаем программке “silver camera TR800” появляется в камере файлик tag.txt, результат интересный - при первом включении тумблерка on/off камера дату кушает и понимает что 2011й. А файлик исчезает. И при втором движении тумблерка on/off у нас опять на дворе 2008й.
Установка файликам атрибута “только чтение” не помогает, файлик исчезает, время сбрасывается.
Дкмаю, что бы такое исправить. Но не очень придумывается.
Принимайте в ряды чтоли. 😃)) Я вот разобрался с ней, а не пойму, как уменьшить монстроидальное пожирание флешки. 5 минут сожрало 350мб. И так будет дальше, да? А есть какая-нить аппаратная компрессия?
врятли) 😁
а у меня она как вебка не работает) мол дровишки не те)
