Height: 210mm (8.3 in)
Diameter Without Rotor Blades: 565mm (22.2 in)
Propeller/Main Rotor Diameter: 330mm (13.0 in)
Weight Without Battery and Payload: 1130g (40.0 oz)
Takeoff Weight With Battery and CGO2-GB: 1700g (60.0 oz)
Battery: 6300mAh 3S 11.1V LiPo (included)
Charger: 3S 11.1V LiPo DC balancing and AC adapter (included)
Transmitter: 10-channel 2.4GHz with 5.8GHz video downlink (included)
[ST10]
Number of Channels: 10
RC Band: 2.4GHz
RC Modulation: Yuneec
Video Downlink Band: 5.8GHz
Telemetry/OSD: Yes
LCD Screen Size: 4.5"
[H920]
Height: 515mm (20.3 in)
Diameter Without Rotor Blades: 980mm (38.6 in)
Propeller/Main Rotor Diameter: 440mm (17.3 in)
Weight Without Battery and Payload: 3.0kg (6.6 lbs)
Maximum Takeoff Weight With Battery and Payload: 6.0kg (13.2 lbs)
Battery: 8800mAh 6S 22.2V LiPo (included with RTF, 8800+mAh 6S 22.2V required for RR)
Charger: 6S 22.2V LiPo DC balancing and AC adapter (included with RTF, required for RR)
Transmitter: 24-channel 2.4GHz with 5.8GHz video downlink (included with RTF, 8+ channel required for RR)
On-Board Electronics: 12-channel 2.4GHz receiver (installed in RTF, 8+ channel required for RR), FC0 flight controller, ESC/main power board and brushless motors (installed in RTF and RR)
[ST24]
Number of Channels: 24
RC Band: 2.4GHz
Telemetry/OSD: Yes
SD Card Compatible: Yes
LCD Screen Size: 7”
Touchscreen: Yes
Two-Way Communication with Telemetry
Extended-Range Video Downlink
Universal Channel Control System
Built-In Flight Simulator
Built-in Android™ Tablet/Pad
500-ка вроде как уже в продаже, и видюшек на ютубе много…
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"5302475f3df955007772c170":{"_id":"5302475f3df955007772c170","hid":195986,"name":"Ol_3","nick":"Ol_3","avatar_id":null,"css":""},"53d165bb3df95500777270ea":{"_id":"53d165bb3df95500777270ea","hid":205360,"name":"Вадимм","nick":"Вадимм","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb5204","hid":135,"title":"Квадрокоптеры RTF других производителей","parent":"61c9a54c3df9550077bb51fe","description":"","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":299,"post_count":198188,"last_post":"66d69284c68e4ffcbc63cb74","last_topic":"66d69284c68e4ffcbc63cb73","last_topic_hid":572539,"last_topic_title":"Заблокировались двигатели у Walkera rodeo 150","last_ts":"2024-09-03T04:37:24.422Z","last_user":"491ea1623df95500777757b6"}},"topic":{"_id":"545ce61c3df9550077ff0b20","hid":384574,"title":"Flying Eyes","views_count":1252,"last_post_counter":2,"cache":{"post_count":2,"first_post":"545ce61c3df9550077ff0e67","first_ts":"2014-11-07T15:32:44.000Z","first_user":"53d165bb3df95500777270ea","last_post":"54b0232a3df9550077ff0e69","last_post_hid":2,"last_ts":"2015-01-09T18:51:22.000Z","last_user":"5302475f3df955007772c170"},"st":1,"section":"61c9a54c3df9550077bb5204"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
