Hubsan Zino 2
balts
Specifications:
Hubsan ZINO 2 Size 32.60 x 26.00 x 9.49 cm
Weight (Propeller + battery): 929g
Motor: Brushless Motor
Maximum Take-off Altitude: 5000m
Max Flying Time: 33mins (windless)
Max Hovering Time: 32mins (windless)
Max. Endurance Mileage: 20km (50km/h windless cruising)
Wind Resistance: 5-level
Max. Tiltable Angle: 25 degrees (normal mode); 35 degrees (sports mode)
Max. Rotational Speed: 150 degrees/s
Max Flying Speed: Movie mode: 1m/s Normal mode: 12m/s Sport mode: 20m/s
Max Ascent Speed: Normal mode: 3m/s Sport mode: 5m/s
Max Descent Speed: Normal mode: 2m/s Sport mode: 3m/s
Working Temperature: -10 Deg.C - 40 Deg.C
Working Frequency: 5.725 - 5.850 GHz
Positioning: GPS + GLONASS
Camera Image Sensor 1/2.3 inch CMOS sensor
View Angle: 80°
Equivalent Focal Length: 24-48mm
Aperture: F/2.2 TTL 23 mm
ISO Range Photography: 100-1600 (automatic); 100-3200 (manual)
Video: 100-3200 (automatic); 100-3200 (manual)
Shutter Speed: 1/8000 - 1/30
Resolution: 4K: 3840*2160 30/60fps / 2.7K: 2704*1520 30/60fps / 1080P: 1920*1080 30/60/120fps / 720P: 1280*720 30/60/120/200fps
Video Maximum Bitrate:: 100Mbps
Support File System: FAT32
Image Format: JPEG/DNG (RAW)
Video Format: MP4 / MOV (h.264 / mpeg-4 AVC)
Gimbal Structural Design Range Pitch: -135 degrees to 45 degrees;
Roll: -40degrees to 40 degrees;
Shift: -35 degrees to 35 degrees
Controllable Rotation Range: Pitch -90 degrees to 0 degrees
Stability System: 3-axis gimbal
Maximum Control Speed (Pitch): 100°/s
Angle jitter: ±0.01°
Image Transmission: Image Transmission System LEAS 2.0
Distance: 8KM
Transmission power (EIRP): <=26dbm
Band 5.725-5.850 GHz
Battery Capacity 3800 mAh
Nominal Voltage: 17.4V (4S)
Charging Limit Voltage: 17.6V
Battery Type: intelligent lithium battery, accurate calculation of battery power, ensure the safety of battery life
Energy: 66.12Wh
Weight: 310 g
Charging Environment Temperature: -10 Deg.C- 40 Deg.C
Maximum Charging Power: 52.2W
Charger Input Voltage 100V-240V
Input Current: 2A
Output Voltage: 17.1V-18.9V
Output Current: 0.0- 3.33A
Rated Output Power: 54W
Remote Control Operating Frequency: 5.725-5.850 GHz
Maximum Effective Signal Distance: 8KM (No interference, No obstacle)
Operating Environment Temperature: -10 Deg.C- 40 Deg.C
Built-In Battery: 3350mAh
Mode: Mode 2 (Left Hand Throttle)
Working Current/Voltage: 3.7V, 1400mA (connecting the android devices); 750mA 3.7V (connecting the iOS devices)
Support Mobile Device Size Maximum Length: 160mm;
Thickness: 6.5 - 8.5mm
Interfaces Type Lightning / Micro USB / Type-C
Charging Micro USB
9 days later
KoTimur
Подскажите, зино2- из коробки, при подключении телефона к пульту выдает такое сообщение , Андроид 8,тел doogee, что делаю не так? Может что в настройках тел,типа вид подключения усб-
balts
Так а в чём проблема? Нажми “больше не отображать”.
10 days later
KoTimur
подскажите плиз- порядок(последовательнось) подключения пульта к телефону. У меня почему то выдает переодически не правильное подключение к узб. может я как то соеденяю не по пунктам? . в телефоне какое ставить подключение_ зарядка по узб.как миди или передача файлов?
8 days later
KoTimur
Мдя уж.я счас в Витязево,а тут почти деревня,попробую завтра до салонов связи добраться))), какую лучше карточку купить чтоб без бубнов в зинку 2 пошла,? Варианты? Да и блин компа с собой нет, ещё вопрос надо карту форматировать из программы управления зиной2? Или найти где в фат 32 отформатировать? Хотя роде карты идут уже с маг в фат 32?
balts
Последовательность подключения есть здесь. Про карты - здесь.
Я рекомендую карту ёмкостью 32Гб, т.к. карты бОльшей ёмкости отформатировать в FAT32 штатными средствами Windows затруднительно.
21 days later
Tarrok
Подскажите, по сравнению с первым зино у него только дальность полета увеличена, да пульт с дисплеем?
KoTimur
про карты вроде все прочитал- но всеж -реально владельцы зины 2- какие карты памяти используете?- какой прогой лучше их форматировать?
3 months later
verwolf
Доброго времени суток. Подскажите пожалуйста алгоритм привязки пульта с дроном zino 2.
