Specification: rpm/v (kv) : 1100
Current (A) : 1.7-25A
Size : 36.4 X 51.7 mm
Shift : dim. 3 mm
Weight : 91g
Max. Efficiency : 90%
Suggested Battery : 3 Li-Poly battery
Voltage : 7.2-12.6v
Suggested Propellers : 10 X 6 - 11 X 6
Power : 300W Controljer
100% Brand New
Suitable for Nicd, NiMH and Lipo batteries
Selective cut-off voltage at 5V or 7.5V by a jumper switch
Can be programmed to switch the brake ON / OFF
Number of FET = 15 pieces
High rate PWM 8K
Auto Timing
BEC 1.5A
Self-adjusting throttle range
Suitable for JR/Futaba/Hitec/GWS
do kakovo vesa on smozhet podnjatj pilotezhku?
Nje sljishkom lji boljsoi ves motora?
Ceni prosto super 😃 , po sravnjeniju v nashem rodmon magazinje 😜
Самолетик с взлетным весом около 1000-1100 г. будет летать неплохо, на мой взгляд.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"400feedf3df95500777953d5":{"_id":"400feedf3df95500777953d5","hid":2755,"name":"Modris","nick":"Modris","avatar_id":null,"css":""},"4208c2c83df95500777923ab":{"_id":"4208c2c83df95500777923ab","hid":5980,"name":"Zetmax","nick":"Zetmax","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50d8","hid":20,"title":"Электродвигатели, регуляторы, мотоустановки","parent":"61c9a54c3df9550077bb518f","description":"Коллекторные, бесколлекторные двигатели и регуляторы скорости.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":3531,"post_count":36024,"last_post":"66ceb5bbc68e4ffcbce15a94","last_topic":"66ceb5bbc68e4ffcbce15a93","last_topic_hid":572534,"last_topic_title":"Вдруг кому-то пригодится с регулем.","last_ts":"2024-08-28T05:29:31.813Z","last_user":"59ad19b83df9550077703a54"}},"topic":{"_id":"44c9a6629970730077fb8f88","hid":46463,"title":"Motor i controljer iz e-bay","views_count":1423,"last_post_counter":2,"cache":{"post_count":2,"first_post":"44c9a6629970730077fb977a","first_ts":"2006-07-28T05:53:38.000Z","first_user":"400feedf3df95500777953d5","last_post":"44c9ddaf9970730077fb977c","last_post_hid":2,"last_ts":"2006-07-28T09:49:35.000Z","last_user":"4208c2c83df95500777923ab"},"st":1,"section":"61c9a54c3df9550077bb50d8"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
