А профиль у пайка какой и где его можно срисовать?
PIKE Superior
Specification:
Wing span: 3300 mm
Wing area: 66,5 dm2 The profile in the centre of the wing: HQ/W 2,5/8 - the camber and the thickness is gradually changed to the end of the wing
Flying weight: 1860 - 2180g -it depends on the version of the strength
Ballast tube: 600 g - 1700 g - depends on the version and CG
Joiners are 11,5x11,8 mm (bigger than the old one)
3-piece wing. The leading edge is ellipsed. The flaps and ailerons are bottom hinged that makes better aerodynamics because we don’t need big servo covers.
The seating of the wings and V-tail is very strong and precise. There is also X-tail available.
Versions:
Standard:
Glass cloth with Carbon flaps and ailerons. Steel pushrods. 500g ballast possible
Weight: V-tail apx. 2140g, X-tail apx. 2230g
Carbon 68 SL:
Full carbon 68g/dm. Steel pushrods. This model is for weak conditions only. Strength of spar 80%. No ballast.
Weight: V-tail apx. 1900g, X-tail apx. 1990g
Carbon 68 F3J:
Full Carbon 68g/dm. 500g ballast and steel pushrods.
Weight: 1-piece V-tail 1980g, X-tail 2070g
Light:
Carbon 80g/dm centre section, carbon 80g/dm D-box wing tips and Carbon aileron and flaps.
Steel pushrods. 500g ballast.
Weight: V-tail apx. 2050g, X-tail apx. 2140g
Carbon F3J:
Full Carbon 80g/dm wings. 500g ballast and steel pushrods.
Weight: 1-piece V-tail 2080g, X-tail 2170g
Carbon F3B:
Full Carbon 80g/dm wings. 1500g ballast and steel pushrods.
Weight: 1-piece V-tail 2170g, X-tail 2250g
Pike Perfect
Pike Giant
Wingspan is 3,3m, area 64dm and airfoil used is MG-06.
