SoarOTX - Настройки аппаратуры FrSky Taranis для планеров DLG F3K и F5J
Коллеги, добрый день!
Вчера наткнулся на интересный проект настроек планера для аппаратур FrSky Taranis SoarOTX Ссылка на github
До этого пользовался ADDLG 4.1 и Tarani Curious. Обе программы устарели (плохо работают с последним OpenT 2.2.1), не обновляются и не используют LUA-скрипты.
Судя по описанию - все что нужно в этих настройках есть:
Timing and score keeping for all of the official FAI F3K tasks.
Scores can be saved to the SD card and viewed later. That way, you can fly a self-timed contest and record scores on paper afterwards.
Graphing of telemetry log data. You can view e.g. receiver battery volts, RSSI signal strength and, if you have an altimeter, altitude and vertical speed.
Controls and mixes: flaps, camber control, ailerons, aileron differential, aileron-to-rudder, snap flaps, flap-to-elevator, and flight modes.
Zoom flight mode is entered after the Launch mode, to facilitate a straight climb-out.
Flaps are disabled at launch, and remain disabled until the throttle stick is pushed forward, for quick turnaround.
Optimal usage of the flaperon servo range by having full flaps be 100% servo down, and aileron up without flaps and camber be 100% servo up.
Full aileron control at any flap position by reducing flaps, if needed to allow for the desired aileron response.
Camber preset for each flight mode is adjusted with the throttle trim button.
Mixes for snap flap, flap-to-elevator, aileron differential, and aileron-to-rudder can easily be adjusted with trim buttons.
Flaperon travel can be adjusted on five-point curves, and the curves can be easily adjusted with the aileron trim button at each of the five points, to get perfect alignment of the flaperons.
Channels can easily be moved around, and servo directions, centering, and end points set with the channel configurator.
Кто-то уже пробовал?
Не совсем по теме, однако тоже касается настройки Taranis.
При бабочке планер задирает нос вверх - приходится компенсировать РВ. Это нормально, или он должен лететь ровно?
Должен ровно лететь, пробуйте компенсировать это увеличением отклонения элеронов вверх в “бабочке”.
А может , чуток вниз, а не ровно?
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"445b81c03df955007778b468":{"_id":"445b81c03df955007778b468","hid":13896,"name":"лерыч","nick":"лерыч","avatar_id":null,"css":""},"498046a43df955007777296f":{"_id":"498046a43df955007777296f","hid":43459,"name":"chitaf3a","nick":"chitaf3a","avatar_id":null,"css":""},"4a1d81a73df955007776d984":{"_id":"4a1d81a73df955007776d984","hid":48794,"name":"nosow","nick":"nosow","avatar_id":null,"css":""},"5633ee8b3df9550077717e26":{"_id":"5633ee8b3df9550077717e26","hid":238833,"name":"arrowcircle","nick":"arrowcircle","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb510b","hid":37,"title":"Планеры, мотопланеры","parent":"61c9a54c3df9550077bb50fc","description":"Безмоторные полёты - динамы, термики.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":3057,"post_count":126705,"last_post":"67f0dd4db4761b70be75e809","last_topic":"632d368bc9e26c33556be513","last_topic_hid":571531,"last_topic_title":"F-5J Расписание, анонс мероприятий","last_ts":"2025-04-05T07:35:41.350Z","last_user":"3bc09af03df9550077797e57"}},"topic":{"_id":"5acf161a3df9550077cae379","hid":520504,"title":"SoarOTX - Настройки аппаратуры FrSky Taranis для планеров DLG F3K и F5J","views_count":1919,"last_post_counter":4,"cache":{"post_count":4,"first_post":"5acf161a3df9550077cae6db","first_ts":"2018-04-12T08:17:30.000Z","first_user":"5633ee8b3df9550077717e26","last_post":"5ad6995f3df9550077cae6e1","last_post_hid":4,"last_ts":"2018-04-18T01:03:27.000Z","last_user":"498046a43df955007777296f"},"st":1,"section":"61c9a54c3df9550077bb510b"},"subscription":null,"pagination":{"total":4,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
