Приемник
Добрый день ,
помогите разобраться в чем разница между этими приемниками
на официалmном сете spektrum
AR12120 12-Channel DSMX/XPlus PowerSafe Receiver
SPMAR12120
$249.99*
KEY FEATURES
12-channel DSMX® PowerSafe™ reciever
True dual battery redundancy—each battery is isolated and if one fails/shorts the other takes over
Utilizes up to four remote receivers for the ultimate RF link in even the most demanding applications
Up to 35 amps continuous and 50 amps peak current handling capability
Fail-on soft switch in case the switch is damaged
Two types of failsafe—SmartSafe™ (throttle only) and preset failsafe (all servos)
QuickConnect™—if a power interruption (brownout) occurs, the system reconnects in less than 1/2 second
Flight Log compatible
Heavy 16 AWG dual battery leads with pre-wired E-flite® EC3™ connectors
Compatible with all Spektrum™ and JR® full-range DSM2® and DSMX® radio systems
2048 resolution
X Plus™ compatible
PRODUCT SPECIFICATIONS
# of Channels:12Modulation😁SM2/DSMXBand:2.4GHzLength:2.05 in (52.0mm)Width:1.83 in (46.5mm)Height:0.60 in (15.3mm)Weight:2.54 oz (72 g)Voltage Range:6-10VAntenna Length:31mm
OVERVIEW
The Spektrum AR12120 is a 12-channel DSMX® PowerSafe™ receiver that gives you the option of adding extra channels simply by plugging a Spektrum X-Plus8 channel expander into its SRXL port. This makes it ideal for scale modelers who like to push realism to the extreme with working accessories and lights, in addition to regular control functions - all in one small packages.
The PowerSafe battery system of the AR12120 incorporates redundant, dual-battery leads for use with battery systems up to 10 volts. Besides the ability to supply all the power your aircraft demands, the AR12120 also includes four small, remote receivers that let you take advantage of patented DualLink technology that ensure a comprehensive safety network on multiple levels.
The Spektrum AR12120 PowerSafe™ offers the ultimate solution for powering high-current draw radio systems. In aircraft with multiple high-current draw servos (e.g. giant-scale aircraft, jets, etc.), the AR12120 PowerSafe can provide peak current of up to 50 amps and offers true dual battery redundancy and a fail-on soft switch for the ultimate in reliability. By locating up to four remote receivers throughout the aircraft, the RF link can be optimized in even the most demanding aircraft installations that have significant conductive materials like carbon, stainless steel bypass tubes, tuned exhausts, etc. For models high in carbon fiber content the SPM9646 DSMX Carbon Fiber Remote Receiver is compatible with the AR12120.
Applications
• Giant-scale aircraft
• Jets with multiple high-current draw servos
• Scale aircraft with multiple high-current draw servos and accessories (e.g. lights, ESCs, air valves, etc.)
• Scale helicopters
Important
The PowerSafe main unit is not a receiver. The PowerSafe’s main unit is a power distribution center that provides up to 35-amps continuous and 50-amps peak current to power your system. Through extensive testing our engineers discovered that mounting the receiver in the typical location in sophisticated aircraft (an aircraft with many high-current draw servos and/or conductive materials), at the end of the servo and battery leads, is not the optimum location to provide the clearest RF signal. The AR12120 PowerSafe uses up to four (a minimum of three are required) remotely mounted receivers that can be optimally placed in your aircraft providing the best possible RF link in the most demanding conditions.
и
Этот же приемник на AliExpress
US $ 63.98
AR12120 12CH XPlus PowerSafe Receiver SPMAR12120
Key Features
12 Channel PowerSafe Receiver
True dual battery redundancy - each battery is isolated and if onefails/shorts the other takes over
Utilizes up to four remote receivers for the ultimate RF link in even themost demanding applications
Two types of failsafe SmartSafe (throttle only) and preset failsafe (allservos)
QuickConnect if a power interruption (brownout) occurs, the systemreconnects in less than 1/2 second
Heavy 16AWG dual battery leads with pre-wired E-flite EC3 connectors
Compatible with all Spek-trum and J-R full range radio and modulesystems
2048 resolution
X Plus compatible
To ensure the receivers work well, all of them will be tested and packed ingood condition before shipping.
Разница в том, что на AliExpress продают клоны (counterfeit) приемников Spektrum. Цена настоящего приемника Spektrum не может быть ниже, чем определяет владелец Spektrum (Horizon).
на сколько они отличаются в качестве , что лучше брать (цена качество) чтобы не переплачивать больше ,но и не лопухнуться с дешевым.
Сомневаюсь, что игра стоит свеч. Что-то я нигде не нахожу отзывов об этих клонах.
Хотелось бы еще услышать высказывания и мысли про эти приемники
