Доброго всем времени. Просветите по нагрузкам на автомат перекоса
Возможно ли использовать автомат перекоса вертолета SJM 180(rconline.ru/modules/news/article.php?storyid=132) для верта выше классом, точнее выдержит ли автомат перекоса нагрузку в 1 кг, не учитывая активный пилотаж (пассивный полёт)?
RTF weight : 320-400g
Kit length(incl*ude canopy) : 430mm
Kit width : 100mm
Kit height : 170mm
Main rotor diameter : 438 mm
Main rotor specification : 215×30mm
Flybar rod : 155mm
Tail rotor diameter : 108mm
Main shaft diameter : Ø4mm
Tail rotor shaft diameter : Ø3mm
Speed ratio of main and tail drive gear : 1:4:8
Main rotor : Changeable screw distance
Adjustable mixing control;
ccpm120 degree swash plate
Main drive gear : M0.4 96T
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"432e26f33df955007778f228":{"_id":"432e26f33df955007778f228","hid":9197,"name":"Scat","nick":"Scat","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb512c","hid":58,"title":"Новичкам","parent":"61c9a54c3df9550077bb5129","description":"Вопросы начинающих вертолётчиков. Выбор модели вертолета для новичка, вопросы сборки, настройки, обучения.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":1759,"post_count":71705,"last_post":"64feb58c3627b35af47719cf","last_topic":"64feb58c3627b35af47719ce","last_topic_hid":572131,"last_topic_title":"Расходы 450ого TREX","last_ts":"2023-09-11T06:37:00.390Z","last_user":"5b164bb33df95500776fdf2c"}},"topic":{"_id":"48ec1f313df9550077a990da","hid":116498,"title":"Просветите по нагрузкам на автомат перекоса","views_count":1831,"last_post_counter":1,"cache":{"post_count":1,"first_post":"48ec1f313df9550077a99db0","first_ts":"2008-10-08T02:47:13.000Z","first_user":"432e26f33df955007778f228","last_post":"48ec1f313df9550077a99db0","last_post_hid":1,"last_ts":"2008-10-08T02:47:13.000Z","last_user":"432e26f33df955007778f228"},"st":1,"section":"61c9a54c3df9550077bb512c"},"subscription":null,"pagination":{"total":1,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
