Что то я никак не пойму чем отличаются сервы Futaba BLS 451 от сервы Futaba BLS 253?😵😵😵😵
Вот я нашел какие характеристики для 451: Control System: +Pulse Width Control 1520usec Neutral Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
**Operating Speed (4.8V):0.14sec/60 degrees at no load
Operating Speed (6.0V): 0.10sec/60 degrees at no load
Stall Torque (4.8V): 111 oz/in. (9.6kg.cm)
Stall Torque (6.0V): 147 oz/in. (10.6kg.cm)**
Operating Angle: 45 Deg. one side pulse traveling 400usec 360 Modifiable: Yes Direction: Counter Clockwise/Pulse Traveling 1520-1900usec Motor Type: Brushless Motor Potentiometer Drive: Indirect Drive Bearing Type: Dual Ball Bearings Gear Type: All Metal Gears Connector Wire Length: 12" Dimensions: (40.6 x 20.3 x 35mm) Weight: 2.1oz. (60g)[/FONT]
Вот по 253:
Torque: 4.8V: 8.4 kg.cm; 6.0V: 10.6Kg.cm
Speed: 4.8V: 0.13 sec/60 degree; 6.0V: 0.10 sec/60 degree
Dimensions: 40 x 20.0 x 36.8mm (1.6 x .8 x 1.5" )
Weight: 58 g
Power Supply: DC 3.8V ~ 6.0V
Как минимум разница в скорости есть небольшая.
А так же в диапазоне рабочих напряжений.)
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"418527b73df95500777934c0":{"_id":"418527b73df95500777934c0","hid":4881,"name":"b0b","nick":"b0b","avatar_id":null,"css":"user__m-banned"},"458f8ed03df9550077787384":{"_id":"458f8ed03df9550077787384","hid":19194,"name":"Nikolik","nick":"Nikolik","avatar_id":null,"css":""},"4720f05e3df95500777804f8":{"_id":"4720f05e3df95500777804f8","hid":28721,"name":"AkaiDD","nick":"AkaiDD","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb5141","hid":65,"title":"Аппаратура, гироскопы, гувернеры, электроника","parent":"61c9a54c3df9550077bb5129","description":"Вертолётная аппаратура радиоуправления и бортовая электроника.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":2494,"post_count":58136,"last_post":"697b1496b4761b70bee1ab48","last_topic":"697b1496b4761b70bee1ab47","last_topic_hid":572722,"last_topic_title":"Ищу USB шнурок для fbl helicomand","last_ts":"2026-01-29T08:04:38.920Z","last_user":"4fee0f683df9550077742b04"}},"topic":{"_id":"4a525d363df95500779502e2","hid":148171,"title":"Чем отличаются сервы?","views_count":1134,"last_post_counter":3,"cache":{"post_count":3,"first_post":"4a525d363df955007795065b","first_ts":"2009-07-06T20:23:18.000Z","first_user":"418527b73df95500777934c0","last_post":"4a5465963df955007795065f","last_post_hid":3,"last_ts":"2009-07-08T09:23:34.000Z","last_user":"4720f05e3df95500777804f8"},"st":1,"section":"61c9a54c3df9550077bb5141"},"subscription":null,"pagination":{"total":3,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
