кто знает этот гироскоп?
zaq
Купил гироскоп гироскоп MS
поставил его на Spirit M-8 что-то никак не могу его настроить. Вообще можно ли его ставить на этот вертолёт? Или он только для микро вертолётов?
a-korenev
zaq:
Digital Mini Piezogyro with Heading Lock For
All Helis
The fully digital Heading Lock Gyro from model sport was specially designed to accommodate the demanding requirements of Micro Helis. It is small and light enough to fit in any micro Heli and yet provides sophisticated features such as Heading Lock, Controllable delay, Authority mixing and much more.
Heading lock technology has truly made it much easier to learn to fly. The locking effect of the tail rotor and the removal of revolution mixing make for a simpler installation that just works. The MS044 takes this one step further, both Heading Lock and Rate modes are available for 4 channel installations where the gain is set through the dial adjustment. The second dial is used to set end point limits to ensure that the tail rotor does not bind. Intermediate pilots would connect the red lead to a proportional channel and instantly add the ability to change the gain from the transmitter. In remote gain installations the gain dial becomes a delay setting.
It is strongly recommended to use a high speed rudder servo, we suggest a transit speed of 0.09sec/60° rated on 4.8volts. When using heading lock mode, all revolution mixing and rudder offset must be removed and it is vital that the rudder linkage can move very smoothly. Any resistance or slop in the rudder linkage can make the helicopter unflyable due to extremely low gain or ATV settings.
Size: 25mm x 25mm
Weight: 7g <
P.S.Какой вы батенька молодой и ленивый!
lyoha
А в чем выражается невозможность настроить? У меня такой же. Проблемы были с машинкой HS55. Поставил футабу - грабли исчезли.
zaq
При взлёте вроде держит хвост, потом добавляю газ и его начинает уводить.Пробывал изменять сувствительность, триммировал -не помогает.
malikh_d_a
zaq:
У Вас скорее всего не настроено изменение нейтрали хвоста при изменении шага НВ (не знаю как по английски это правильно). Есть такой микшер в аппаратуре. У меня что то вроде RV-MIX называется.
a-korenev
zaq:
Если расходы не регулируются на гиро электрически , то необходимо это сделать путём подбора плеча качалки . Т.е. выставить его так , чтобы не было ограничений хода серво и рычага упр. шагом хв. винта . 😃
Sly_tom_cat
zaq:
Может не хватает угла отклонения хвостовых лопаток? вы посмотрите как там стоит начальное положение (ножшницы) и на сколько еще получается регулировать шах заднего ротора - у меня (я правда в руках держал верт) тоже уводить на большом газу начинало, пока я не перенастроил задний ротор - теперь в положительную сторону лопатки чуть ли не до 45 градусов отклоняются и в отрицательный шаг тоже выводятся градусоов на 5. При начальном положении “ножниц” по инструкции вертолет действительно перестало крутить и любые мои попытки его развернуть рукой довольно быстро стали компенсироватся гирой.
Ну гира у меня другая, но смысл именно в настройке механики, а работают (теоритически) все гиры почти одинаково.
