Justin Jee - Extreme Edge 540T EXP 60" - 2012-07-01
Temp motor .80 Rimfire 500kv
Neu 1910/2y 520kv 320g 1200w continuous will be put in soon.
Griphon Agena BEC at 6.8v
APC 15x7 (xoar 15x6 did not arrive in time)
Jeti Opto Pro 77
TP 6s3800-3850 (temp setup using heli pack)
TP 6s3300 on the way (4oz lighter) will be fine as 7min flight consumed about 2500-2600
Hitec 5245s
Small airplanes seem to take few more flights to figure it out. Also, elevator deflection of more than 45 degree will take some getting used to.
Температура двигателя 0,80 Rimfire 500кВ
Neu 1910/2y 520kv 320г 1200w непрерывного будет введена в ближайшее время.
Griphon Agena БЭК на 6.8v
APC 15x7 (15x6 xoar не прибыть вовремя)
Джети Opto Pro 77
TP 6s3800-3850 (темп установки с помощью вертолета упаковке)
TP 6s3300 на пути (4 унции легче) будет хорошо, 7мин полета потребляется около 2500-2600
Hitec 5245s
Малые самолеты, кажется, принять несколько рейсов, чтобы понять это. Кроме того, лифт отклонение более чем на 45 градусов займет некоторое привыкнуть.
Теперь он и на самолетах.)
Now he flies planes too. 😃
Which part of the US is that?
Sashanar
The field is located in Northford, Connecticut
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"4c8218db3df955007775cd87":{"_id":"4c8218db3df955007775cd87","hid":71346,"name":"sashaNar","nick":"sashaNar","avatar_id":null,"css":""},"4fd0e8773df95500777438c5":{"_id":"4fd0e8773df95500777438c5","hid":120601,"name":"red_z06","nick":"red_z06","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb517a","hid":86,"title":"Пилотаж","parent":"61c9a54c3df9550077bb50fc","description":"3D-пилотаж, F3A, фристайл, техника пилотирования.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":482,"post_count":30225,"last_post":"6a95d19a44153b3865a4d5e4","last_topic":"4c74e2893df955007777f027","last_topic_hid":200206,"last_topic_title":"И снова 3D","last_ts":"2026-08-31T19:10:18.467Z","last_user":"63aabb4f6bd00911082b65f2"}},"topic":{"_id":"4ff332c53df955007733e54a","hid":284610,"title":"Justin Jee - Extreme Edge 540T EXP 60\" - 2012-07-01","views_count":2319,"last_post_counter":3,"cache":{"post_count":3,"first_post":"4ff332c53df955007733ecd3","first_ts":"2012-07-03T17:58:29.000Z","first_user":"4fd0e8773df95500777438c5","last_post":"4ff3407a3df955007733ecd7","last_post_hid":3,"last_ts":"2012-07-03T18:56:58.000Z","last_user":"4fd0e8773df95500777438c5"},"st":1,"section":"61c9a54c3df9550077bb517a"},"subscription":null,"pagination":{"total":3,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
