Чем отличаются эти видео передатчики Lawmate ?
Pash_Ok
Подскажите, в чем отличие передатчика:
T1012 TRANSMITTER 1.2 Ghz 1000mW - 95$
от
TX-V1012 1000mW 1.2GHz plug and play transmitter - 150$
Есть подозрение что переплата в 55$ только за встроеный преобразователь 5V под питание камеры. Так ли это??? Еще отличия есть?
аналогичный вопрос по:
T512 Transmitter 1.2 GHz 500mW - 60$
и соответственно:
TX-V512 500mW 1.2 GHz plug and play transmitter -120$
baychi
Pash_Ok:
Так. А еще там встроенный микрофон.
Pash_Ok:
И доп. модуль преобразователя с микрофоном одbн в один, похоже. 😃
webconnector
встроенный микрофон, защита от переполюсовки. разъемы , защита от дрейфа частоты итд …
This is a plug and play transmitter only, part of our FPV512 plug and play system.
This combo uses PLL (Phase-Locked Loop) technology to prevent frequency drift.
The plug and play board has lots of important features built-in such as:
  • High quality microphone
  • Audio volume control
  • High quality 5v voltage regulator (no heat and noise free)
  • Reverse-Polarity Protection (avoids damage if you plug the battery pack inverted)
  • Dual power output (provides selectable power for 5 and 12 volts cameras)
  • Molex connector with safety latch (prevents connection to come loose while in use)
  • Power LED (helps to identify bad power connection, reminds you to disconnect power when it’s not in use)
If you want to expand your current FPV512 system to another R/C vehicle, or you have damaged your existing transmitter, or you either want to buy everything separated to build your own system, this is the deal.
What are the advantages of a plug-and-play transmitter?
A plug and play transmitter eliminates the use of the stock bulky and heavy connectors, no soldering is needed, with only two clicks you will have the camera, battery, microphone (built-in), reversed-polarity protection, microphone volume control…besides all that it can provides power to 5 V or 12 V cameras, click here for plug and play cable for cameras.
It works with any of our 1.2 GHz receivers, that includes the ORACLE diversity receiver as well.
It uses PLL technology, very tiny and so light weight that if you hold it in one hand and a coin of the same size on the other hand, you’ll have a hard time telling which one is heavier.
To those whom are going to use it, make sure the voltage your camera needs to be operated, and if you are building your own setup from scratch, the camera connector needs to be made using Futaba type connection, for the following wires colors (white video in) (red + positive) (black - negtive)
The TXV512 is able to send audio and video wirelessly for more than 2 miles with high gain antennas.
It works flawlessly with 2.4 GHz radios and it’s perfect for use where there is not much room, and weight can be a problem.
Pash_Ok
Пожалуй вместо TX-V1012, за те же деньги лучше взять T1012+T512 😃
… и еще жменьку BECов или кренок на оставшиеся деньги.
Кстати, какой нынче самый “легкий” способ (и по реализации и по весу), преобразовать 12в в 5в?
webconnector:
Защита от дрейфа?
Т.е. радиомодуль все же другой? или тот же модуль с той же дальностью и качеством только с обвязкой: “встроенный микрофон, защита от переполюсовки. разъемы” ?
blade
webconnector:
Ну, с микрофоном (нафига он вообще нужен)- всё ясно, с переключателем питания камеры- тоже.
А вот “защита от дрейфа частоты” в синтезаторном передатчике- это как?
Он по своей сути кварцованный и, следовательно никакого дрейфа там быть- не может в принципе 😃
Совсем на лохОв рассчитывают?
Pash_Ok
у кого то есть фото внутренностей радиомодуля первого и второго варианта?.. может коллективом мы сможем восстановить истину? 😉
webconnector
щас второй найду
из твоих ссылок
не понимаю в радио но в первом много деталей он лутшый 😁 😁
Pash_Ok
та фотка которую ты дал фторой - она у них на сайте на 500 и 1000мв одинаковая… Скорее всего отбалды всунули. Нужен реальный экземпляр!
webconnector
если серьезно по картинкам нельзя нужна картинка второй стараны второго рисунка (ато ни кварца ни чего не видна )
Pash_Ok:
может платки одинаковые усилки разные (а усилков не видно нужна вторая сторона)
есть и такой те что справа (как обычный но с платкой ) как понимаю просто в нем есть встроенный микрофон с регулировкой и dc-dc
img222.imageshack.us/img222/2337/photoubf.jpg (396 Kb)
baychi
webconnector:
За основу взяты стандартные модули от Lawmate. Сама LW других передатчиков на 0.5 и 1 Вт не делает. Просто данный продавец дополонил модуль передатчика своим преобразователем питания с микрофоном.
blade:
А вот “защита от дрейфа частоты” в синтезаторном передатчике- это как? Он по своей сути кварцованный и, следовательно никакого дрейфа там быть- не может в принципе
Имеется в виду ФАПЧ - подстройка VCO с помощью обратной связи. Вешь стандартная в хороших передатчиках, но упомянуть не грех (в кетайских дешевках может и этого не быть). 😃
blade
baychi:
Если можно- с этого места подробнее?
У меня валяется 60мВт передатчик тайваньский (TWT), которому лет 15- точно, а может -больше.
1,2 мГц, 4 диапазона. Там синтезатор Филлипс и ПИК какой то…То есть, всё как положено- ГУН, ФАПЧ, УМ…Причём, нынешние передатчики- только большей компактностью отличаются, да иногда вместо двух микросхем- одна Fujitsu стОит, в которой “всё в одной”.
А без петли ФАПЧ- даже китайцы ничего сделать не могут 😦
Разве что- одночастотный (тут кто то выкладывал)
Но такого лично я- даже не видел 😦
baychi:
И ещё 50 $ туда прикрутил 😃
Тоже, от себя 😦
Лично я- такой самопал покупать бы не стал.
baychi
blade:
А Вы с подстроечником на VCO вместо ФАПЧ не встречали передатчиков? Я - встечал. ФАПЧ тока на приемнике обязательна. 😃
blade:
Так то Тайвань! 😃
blade
baychi:
Многодиапазонные?
Этого не может быть- ничего не настроишь 😦
VCO по температуре- блудит, как чумачечный…
Я просто работал с ними примерно в этом диапазоне…
И если он на удалении “вывалится” из петли захвата приёмника- его уже не найдёшь.
baychi:
Так то Тайвань!
Я ж говорю- все китайские передатчики (мне их много чинить доводилось)- прямые клоны Тайванщины: отличаются только элементной базой, (ну, не было тогда MOS усилителей монолитных на 0,5 и 1 вТ)
А так- один в один.
Там просто ничего другого не придумаешь 😦
8 days later
Pash_Ok
Не подскажете что это за деталька обведена красным на картинке?.. походе на кандер… Случанйо смыл выпаивая разьем 😦
Дми-III-й
Была такая же проблема в 200 мВт-нике, заменил на кондер со старой материнской платы (те что в районе кварцев там парами стоят), надо найти самый высокочастотный кварц и около него поискать там
blade
Pash_Ok:
Если слева позолоченная железка- антенный разъём, то конденсатор 10-12 нФ. (Развязка антенны по гальванике)
Lexa4
Я весь в раздумьях.нужен комплект видео на 1.2 лавмейт(по ссылке выше)на 1000 мВт.как лучше покупать? по отдельности все или комплект(вот пример www.hobbywireless.com/cart/index.php?main_page=pro…) ?Комплектом получается дешевле.Почему такая разница?
baychi
Lexa4:
На то он и комплект. 😃
Если нужен и приемник и передатчик, берите не сомневайтесь, решение от Lawmate на 1.2 ГГц - лучшее на сегодняшний день.
Pash_Ok
Этих комплектов по той ссылке сейчас нет в наличии.
Я взял это и это
85+49 = 134$ - те же деньги что на HW за комплект 😃
… доставка и там и там 15-20$ сверху
Lexa4
а если я возьму как ты,какие мне еще надо провода докупить,вобщем чтог мне еще нужно чтобы была готовая видео система.камера это понятно.
Lexa4
никто не подскажет что мне еще нужно?а к телевизору чтобы подключиться там есть провод в комлекте?
8 months later
Максус
Ребята нужна помощь!!!Никак не могу взять в толк назначение проводов в TX-V1012 1000mW 1.2GHz plug and play transmitter (ну тот который с модулем переключения на 5 вольт и микрофоном)
Те что слева красный и черный понятно питание +/-, а вот подключение камеры ХЗ.Если кто сталкивался с таким передатчиком подскажите назначение проводов по цветам:Черный - ?Красный -?Желтый -?
Максус
Ну неужели никто не пользует такой передатчик? Ведь так нужен совет!!!
Voldemaar
У всех передатчиков стандартная цветовая маркировка проводов: черный - общий, он же минус, красный - питание, желтый - видеосигнал. Есть еще белый - это звук. Конкретно по Вашему экземпляру - разъем слева, где два провода, это питание передатчика. Разъем справа, где три провода - для подключения видеокамеры. Черный - общий (минус), красный - питание камеры (плюс), желтый - видеосигнал с камеры.
