DimensionsPerformance with 0.9 kg payload span 3.00 m max level speed 145 km/h 79 kt area 0.70 sq m cruise speed 80 km/h 44 kt overall length 1.60 m max vertical climb @ max weight, SL 1.0 m/s 200 ft/min rotor diameter 1.85 m max climb @ max weight, SL 3.8 m/s 750 ft/min fuselage diameter 0.18 m endurance, no reserves more than 40 hr max VTO weight 19.2 kg still-air range @ max endurance more than 3000 km/2000 nm
Подскажите какой двигатель подходит и какой пропеллер ?
The main rotor is powered by a single-cylinder 28 cc two-stroke through a reduction gearbox. It is placed forward of the wing in a tractor layout, but aft of a non-rotating nose reserved for an imaging turret or other payload.
гуглоперевод “Основной ротор оснащен одноцилиндровым 28 см двухтактных через редуктор. Он расположен спереди от крыла в компоновке трактора, но в кормовой части невращающегося носа защищены для башни изображений или других полезных данных.” spacedaily.com/…/Aerovel_Strolls_Out_Flexrotor_Lon…
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"5001a4743df9550077742240":{"_id":"5001a4743df9550077742240","hid":122384,"name":"integro","nick":"integro","avatar_id":null,"css":""},"53677b233df95500777297b2":{"_id":"53677b233df95500777297b2","hid":201188,"name":"MANS","nick":"MANS","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50c3","hid":1,"title":"Самолёты с ДВС. Общие вопросы","parent":"61c9a54c3df9550077bb518c","description":"Простые самолёты с двигателями внутреннего сгорания для тренировочных полетов.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":3153,"post_count":46960,"last_post":"66b8f075c68e4ffcbc0d8bb1","last_topic":"668c30cd563b07d6031abf5d","last_topic_hid":572480,"last_topic_title":"Колеса-дутики от Техноспорта.","last_ts":"2024-08-11T17:10:13.011Z","last_user":"5f2fbbe83df95500776f4a70"}},"topic":{"_id":"54e5daa23df9550077fabac9","hid":397586,"title":"С вертикальным взлетом Flexrotor","views_count":1356,"last_post_counter":2,"cache":{"post_count":2,"first_post":"54e5daa23df9550077fabd1a","first_ts":"2015-02-19T12:44:18.000Z","first_user":"5001a4743df9550077742240","last_post":"54e5e3603df9550077fabd1c","last_post_hid":2,"last_ts":"2015-02-19T13:21:36.000Z","last_user":"53677b233df95500777297b2"},"st":1,"section":"61c9a54c3df9550077bb50c3"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
