Чесн слово, устал ковыряться в инете с поиском 😦
Мож кто пояснит или приведет примеры вывода с ардуины информации на сей девайс?
А еще лучше, пояснить как к мультивию привязать его?
Я так понимаю подключается он к RX, в config.h надо настроить здесь:
/**** LCD - display and telemetry settings ****/
/* In order to save space, it's possibile to desactivate the LCD configuration functions
comment this line only if you don't plan to used a LCD */
#define LCD_CONF
/* to include setting the aux switches for AUX1 and AUX2 via LCD */
//#define LCD_CONF_AUX_12
/* to include setting the aux switches for AUX1, AUX2, AUX3 and AUX4 via LCD */
//#define LCD_CONF_AUX_1234
/* choice of LCD attached for configuration and telemetry, see notes below */
#define LCD_SERIAL3W // Alex' initial variant with 3 wires, using rx-pin for transmission @9600 baud fixed
/* serial (wired or wireless via BT etc.) */
//#define LCD_TEXTSTAR // Cat's Whisker LCD_TEXTSTAR Module CW-LCD-02 (Which has 4 input keys for selecting menus)
//#define LCD_VT100 // vt100 compatible terminal emulation (blueterm, putty, etc.)
/* i2c devices */
//#define LCD_ETPP // Eagle Tree Power Panel LCD, which is i2c (not serial)
//#define LCD_LCD03 // LCD03, which is i2c
/* style of display - autodetected by LCD_ setting - only activate to overwrite defaults */
//#define DISPLAY_2LINES
//#define DISPLAY_MULTILINE
/* keys to navigate the LCD menu (preset to LCD_TEXTSTAR key-depress codes)*/
#define LCD_MENU_PREV 'a'
#define LCD_MENU_NEXT 'c'
#define LCD_VALUE_UP 'd'
#define LCD_VALUE_DOWN 'b'
Как именно не разбирался.
Код:
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"4e0330223df955007775116f":{"_id":"4e0330223df955007775116f","hid":91496,"name":"sulaex","nick":"sulaex","avatar_id":null,"css":""},"4f8489913df95500777459c6":{"_id":"4f8489913df95500777459c6","hid":117624,"name":"serenya","nick":"serenya","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb51e0","hid":123,"title":"Коптеры. Комплектующие, сборка, настройка.","parent":"61c9a54c3df9550077bb51fe","description":"","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":1140,"post_count":370855,"last_post":"6750cc406bffb2a544b4911e","last_topic":"4dcc27f13df9550077537431","last_topic_hid":233564,"last_topic_title":"А давайте обсудим Arducopter - APM","last_ts":"2024-12-04T21:40:16.348Z","last_user":"5469d13d3df9550077723996"}},"topic":{"_id":"4fc375f23df9550077364721","hid":280157,"title":"MWC MultiWii Lite /SE 4-axis FlightControler Flight Control Board LCD Debugger Module","views_count":2430,"last_post_counter":3,"cache":{"post_count":3,"first_post":"4fc375f23df9550077364bf8","first_ts":"2012-05-28T12:56:18.000Z","first_user":"4e0330223df955007775116f","last_post":"4fc462793df9550077364bfc","last_post_hid":3,"last_ts":"2012-05-29T05:45:29.000Z","last_user":"4e0330223df955007775116f"},"st":1,"section":"61c9a54c3df9550077bb51e0"},"subscription":null,"pagination":{"total":3,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
