Xaircraft SuperX Pro Flight Controller
Есть пользователи данного девайса ?
Думаю прикупить на смену “Назе”
XAircraft SuperX is our latest generation of multi-copter flight control systems, supporting between 2 to 8 rotors.
The SuperX FC has an easy-to-use design concept allowing the end user to be up and flying after a few simple steps, making SuperX one of the simplest multi-copter flight controllers on the market.
SuperX Features:
•3 different flight modes: Manual Mode, Attitude Mode, and GPS Attitude Mode.
•Altitude Hold in both GPS and Attitude flight modes.
•Several options for “Safe Mode”, e.g. return to home and auto landing.
•Built-in compensated signal outputs for servo controlled bi-axial camera gimbals.
•Built-in “green” software for ease of configuration. No need to install any software or drivers.
•Module expandable.
•Firmware upgradeable.
•Three high precision Industrial grade gyros for flight stability.
•Three-axis accelerometer sensor.
•High precision barometer.
•Built-in thermostat system guarantees stability of all sensors.
•Built-in Micro USB port allows you to connect to a PC to perform firmware updates, or to fine tune flight parameters.
•Auto take off in GPS Mode.
SuperX “Basic”
•Supports up to four motors. ie: Quadcopters.
SuperX “Standard”
•Support for up to six motors. ie. Hexacopters or Y6 frames.
SuperX “Professional”
•Supports up to eight motors for Octacopters or X8 platforms.
SuperX Flight Controller is the core controller of SuperX, has a Built-in AHRS to calculate copter attitude, and runs all flight control tasks.
- Three high precision Industrial grade gyros.
- Three-axis accelerometer sensor.
- High precision barometer.
- Built-in Thermostatic system to ensure that sensors are working stably.
- Built-in Micro USB port for tuning settings and upgrading firmware.
Машинный перевод:
XAircraft SuperX наша последнее поколение систем управления полетом мульти-вертолет, поддерживая от 2 до 8 роторов.
SuperX FC имеет легкий в использовании дизайн-концепцию, позволяющую конечному пользователю составлять и летать через несколько простых шагов, что делает SuperX один из самых простых диспетчерами мульти-вертолет на рынке.
SuperX Особенности:
• 3 различных режима полета: Ручной режим, Режим Отношение, и режима GPS отношение.
• Высота Удержание в обоих GPS и режимов Отношение полета.
• Несколько вариантов “безопасном режиме”, например вернуться в дома и авто посадки.
• Встроенный компенсированных сигнальных выходов для Сервоуправляемая би-осевых кардановом камеры.
• Встроенная функция “зеленый” для простоты конфигурации. Нет необходимости устанавливать дополнительное программное обеспечение или драйверы.
• Модуль расширения.
• Обновление встроенного программного обеспечения.
• Три высокоточные промышленного класса гироскопы для стабильности полета.
• Трехосный акселерометр.
• Высокая точность барометр.
• Встроенная система термостат гарантирует стабильность всех датчиков.
• Встроенный Micro USB порт позволяет подключать к ПК для выполнения обновления прошивки, или на тонких параметров настройки полета.
• Авто снять в режиме GPS.
SuperX “Basic”
• Поддержка до четырех двигателей. т.е.: Quadcopters.
SuperX “Стандарт”
• Поддержка до шести двигателей. т.е… Hexacopters или Y6 кадров.
SuperX “Профессионал”
• Поддержка до восьми двигателей для Octacopters или X8 платформ.
SuperX Полет контроллер является ядром контроллер SuperX, имеет встроенный в Ahrs для расчета вертолет отношение, и работает все задачи управления полетом.
- Три высокоточные промышленного класса гироскопы.
- Три-осевой датчик акселерометра.
- Высокая точность барометр.
- Встроенный термостатический системы для того, чтобы датчики работают стабильно.
- Встроенный Micro USB порт для вариантов настройки и обновления прошивки.
Есть своё осд
Descriptions:
OSD module is an optional module for XAircraft SuperX.It can add fly data to FPV video, such as attitude,flight mode, number of satellites,height, velocity and voltage alarm. User can check the status of flight controller through screen or video glasses. XAircraft OSD enable Real time info(altitude, speed, voltage) communication between ground telemetry.
Features:
Two video input, one for SuperX, one for 3.5mm audio interface, could switch video input by remote controller, and switch view angle between FPV and gimbal One video output, connects with image transmission devices, send video to ground.
Size: 47.5mm x 26.9mm x 10.5mm
Weight: 17.5g
Compatibility: onl for Xaircraft SuperX flight control
Processing: CNC Aluminum alloy case
Машинный перевод:
Описания:
Модуль OSD является дополнительным модулем для XAircraft SuperX.It можете добавить данные лететь в FPV видео, таких как отношения, режим полета, количества спутников, высота, скорость и тревоги напряжения. Пользователь может проверить состояние контроллера полета через сито или видео очки. XAircraft OSD позволяют Real данные времени (высота, скорость, напряжение) связь между массой телеметрии.
Особенности:
Два видео входа, один для SuperX, один для 3,5-мм аудио интерфейс, может переключите вход видеосигнала с пульта дистанционного управления, и переключения угол обзора между FPV и карданных Один видеовыход, соединяется с устройствами передачи изображения, передачи видео на землю.
Размер: 47.5мм х 26.9mm х 10,5 мм
Вес: 17,5 г
Совместимость: только для управления полетом XAircraft SuperX
Обработка: ЧПУ Случай алюминиевого сплава
ОК !
Есть пользователи на дизайне ?
Какие отзывы ?
Последние коптеры китаец Алишанмао собирает именно на этом контроллере, вижу по антенне GPS
Вот его страница, там можно найти www.youtube.com/channel/UCsFctXdFnbeoKpLefdEloEQ
Раньше у него была только Наза, даже удивило что он изменил ей 😃
