Порекомендуйте новый мотор для Aquacraft Lucas oil под 6 S
Вот выбор мой. и порекомендуйте что еще посмотреть из моторов. будут две батареи 3S 5000mah 50C и регуль 120A
Turnigy AquaStar 4084-620KV Water Cooled Brushless Motor
Specs:
RPM/v: 620kv Winding: 2.5Y
Max voltage: 37V (10S)
Max Current: 105A
Max Watts: 3050W
Resistance: 0.03ohm
No Load Current: 0.7A
Can Diameter: 39mm (actual motor diameter)
Can Diameter inc. Water Jacket: 49mm
Can Length: 84mm
Shaft Size: 5mm
Weight: 508g
Motor Connector: 4mm bullet plu
Turnigy AquaStar 4084-1050KV Water Cooled Brushless Motor
Specs:
RPM/v: 1050kv
Winding: 1.5Y
Max voltage: 22.2V (6S)
Max Current: 160A
Max Watts: 3100W
Resistance: 0.014ohm
No Load Current: 1.4A
Can Length: 84mm
Shaft Size: 5mm
Weight: 490g
Motor Connector: 4mm bullet plug
оба негодные. обороты будут смешные. ищите мотор с kv=1800…
у него родной мотор 1800KV, вполне 2000 пойдет!
А я думал чем меньше kv и больше Max Watts тем скоростнее мотор
кв*вольтаж батареи = холостые обороты.
что-бы ехало - холостые от 38-40 тыс. об.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"4b9b96393df95500777634a2":{"_id":"4b9b96393df95500777634a2","hid":62678,"name":"MaslikoFF","nick":"MaslikoFF","avatar_id":null,"css":""},"50f2115f3df955007773b9f3":{"_id":"50f2115f3df955007773b9f3","hid":133583,"name":"puss5","nick":"puss5","avatar_id":null,"css":""},"55542f713df955007771d6e6":{"_id":"55542f713df955007771d6e6","hid":223596,"name":"nideckergt","nick":"nideckergt","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb51f2","hid":129,"title":"Скоростные модели, электро","parent":"61c9a54c3df9550077bb5111","description":"Скоростные модели судов: постройка, оснастка, эксплуатация.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":1060,"post_count":62029,"last_post":"69de887c00fb687e16226f42","last_topic":"69de887c00fb687e16226f41","last_topic_hid":572724,"last_topic_title":"Нужна помощь по поводу модели Моно-1","last_ts":"2026-04-14T18:33:32.174Z","last_user":"69b7ab5444153b3865ac787e"}},"topic":{"_id":"55d4c6fa3df9550077f0683e","hid":421956,"title":"Порекомендуйте новый мотор для Aquacraft Lucas oil под 6 S","views_count":1115,"last_post_counter":5,"cache":{"post_count":5,"first_post":"55d4c6fa3df9550077f069f1","first_ts":"2015-08-19T18:12:10.000Z","first_user":"55542f713df955007771d6e6","last_post":"55d6ba8f3df9550077f069f9","last_post_hid":5,"last_ts":"2015-08-21T05:43:43.000Z","last_user":"4b9b96393df95500777634a2"},"st":1,"section":"61c9a54c3df9550077bb51f2"},"subscription":null,"pagination":{"total":5,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
