fimi-x8-se
Кот_Кокос
fortemio:
при первом запуске появился файл с настройками WiFi . какая то точка доступа пароль 01234… еще информация внутри. а потом затерся.
Вот его содержимое. wifi.conf
У меня пока не затёрся, потому что дрон не обновляется:(
##### Wifi configuration file ##########################################
## Empty lines and lines starting with # are ignored
# ap: SoftAP mode
# sta: Station mode
# p2p: Enable Wifi Direct Support for peer-to-peer connectibity
WIFI_MODE=ap
# GPIO pin to enable or disable WiFi
#WIFI_EN_GPIO=95
#1=GPIO high to enable WiFi; 0=GPIO low to enable WiFi
#WIFI_EN_STATUS=1
# GPIO physical button that user can turn WiFi ON/OFF
#WIFI_SWITCH_GPIO=43
##### STA mode configuration ##########################################
# SSID
ESSID=amba_boss
# Passphrase. Leave empty at no security mode; please edit wpa_supplicant.conf when your AP cannot be detected
PASSWORD=1234567890
# Device Name for AMBA Discovery Protocol (optional)
STA_DEVICE_NAME=amba-1
# Do not detect SSID setting changes, use previous scanned results
STA_SKIP_SCAN=yes
##### Wifi Direct configuration ##########################################
# Find devices with correct name prefix and automatically connect at startup
P2P_AUTO_CONNECT=no
# Auto-connect with devices if the name prefix matches
P2P_CONNECT_PREFIX=amba
## Do not enable this optional field unless you are certain
# please provide a unique name amoung multiple devices to prevent confusion
#P2P_DEVICE_NAME=amba-1
# Set the default P2P GO Intent
#P2P_GO_INTENT=0
# Specify P2P operating channel
#P2P_OPER_CHANNEL=1
# Default mode for HT40 enable when operating as GO
#P2P_GO_HT40=0
##### SoftAP configuration ##########################################
# SSID (1 ~ 32 characters)
AP_SSID=amba_boss
# IP address
LOCAL_IP=192.168.42.1
# IP subnet mask
LOCAL_NETMASK=255.255.255.0
# IP pool starting address of DHCP server
DHCP_IP_START=192.168.42.2
# IP pool end address of DHCP server
DHCP_IP_END=192.168.42.6
# Wifi channel number, set 0 to use Auto Channel Selection
AP_CHANNEL=0
# Maximum number of stations allowed in station table
AP_MAXSTA=5
# If you say yes here, all WPA/WEP settings will be ignored
AP_PUBLIC=no
# WPA Passphrase (8 ~ 63 characters)
AP_PASSWD=1234567890
fortemio
Кот_Кокос:
  1. нашел в скрытых
  2. тоже самое внутри
  3. после форматирования карты в дроне - папка MISC теперь не скрытая, вайфай конфига в ней нету. правда я переключатель перевел в RC mode
ЗЫ даже не обновлял из коробки - а смысл? пока все работает как надо. а то еще флипнет
только отписал им еще раз:
Hello! Have you VR mode? I offered to split the interface of the program for flights in VR glasses!
Can we do that?
Если кто в теме - можете поддержать хотя бы копи-пасте. 😒
amamitchev
fortemio:
Я не в курсе что поддерживает VR софт - есть подозрение что читаться буквы плохо будут. Я на Алиэкспрессе нашел такой шлем.
MaLexa
Получил сегодня свой коптер. Дома включил, обновил, все что прилетело. Завтра постараюсь на натурные испытания выехать. Единственное огорчение - это как и у всех - зарядка телефона от пульта. Одновременно еще и лопасти запасные пришли. Теперь еще батарея осталась (уже едет), сумка какая-нибудь для переноски и защита для камеры.
Пока рылся в настройках, понял, что тайм-лапс, дрон писать умеет, осталось панорамы дождаться.
fortemio
amamitchev:
юмор это хорошо, буквы на сайте нужно читать, а полетом наслаждаться 😃
обычный зеркальный. не то совсем… цена тоже не божеская. хотя кто то покупает и за 500$B-)
MaLexa:
таймлапс в пределах 30 минут это не самое важное в дроне. ну хорошо что уже есть. в каком разделе?
а вот панорама
amamitchev
fortemio:
Никакого юмора - буквы я имел в виду телеметрию: скорость высота и т.п. В приложении они почему-то очень мелкие и я не нашел настроек шрифтов чтобы статус бар крупнее сделать. Я искал шлем типа того, которые используются FPV для гоночных дронов - там просто экран и линза и никакого VR. В VR не вижу смысла поскольку камера одна 😃
Кстати об упомянутом шлеме - на алике по моей ссылке один из отзывов именно от того кто брал его для FPV.
Serega0787
Парни, кто нибудь сумку или рюкзак заказывал? Именно под fimi x8. Поделитесь впечатлениями.
fortemio
amamitchev:
поясню - зеркальные очки у меня есть. VR не для получения стерео, а для погружения в процесс. надените VR и попробуйте в них видео посмотреть.
потом в зеркальных. Шрифт… а че его читать то? летай и радуйся.
А зеркальный - от безысходности так как пока никаких вариантов
Рамзес888:
Для начала можно опробовать это: ru.aliexpress.com/item/ZX302...3a9933edtgQTua
Я уже ставил на H501S - нормально работает!
наказуемо. т.е. на углядение НКВД
с ними еще какие то нюансы 1. Примечание: Это gps-трекер 2 г, поддерживает г только sim-карту 2g.(Это сказал Austrlia, Сингапур, Мексика, Канаде и США остановится 2 г службы с 2017 года).
Jorik66
fortemio:
беда трекеров этих в том что они привязаны к сотовым сетям. там где сети нет абсолютно бесполезная вещь.
Рамзес888
Jorik66:
Тогда ТОЛЬКО “Тигромух” - tBeacon: tbeacon.org/?language=ru&page=10
Пользуюсь таким, но искать пока не доводилось, зато проверил что в черте плотной городской застройки сигнал пробивает на 500 метров с рацией Baofeng UV-5R (5W). В поле будет В РАЗЫ БОЛЬШЕ!
Jorik66
Рамзес888:
в курсе, вот когда будет описание его интеграции в Х8, тогда куплю
Arts2018
У меня стоит тигромух неа XIRO ставил сам, сложного ничего нету, надо найти питание, которое будет заряжать аккум тигромуха при включении дрона и подпаятся к gps
Jorik66
Arts2018:
подпаятся к gps
вот это и не хотелось бы наугад делать…
Arts2018
думаю на плате найти RX TX не составит труда либо к самому GPS напрямую
hroft=
Ezhukov:
Забыл сегодня снять с подвеса защиту, он в режиме автовзлета
взлетел на четыре метра, сделал флип сам и верхом об асвальт…
В итоге минус четыре винта, батарея отлетела и покоцалась, корпус тоже
немного пострадал. Подвес жив. Еще отлетела две силиконовые прокладки
на задних ножках. Я в шоке…
У меня такая же ситуация, только дрон был на высоте 50 метров. Стики я не трогал. Изучал приложение. Т.е. он должен был просто висеть в точке, а он ни строго ни с сего перевернулся. Пытался его выровнять. От удара сломался луч возле мотора. Написал в поддержку. Выслал им лог полета. Написали что находится в анализе. И да, силиконовые накладки держится на честном слове )
Jorik66
Arts2018:
Подождем пока разберут и опишут сей девайс😒
everyman
hroft=:
Сегодня на ФБ появилось сразу несколько сообщений о подобных выкрутасах. Появился там и известный персонаж Wee Tsai, сообщивший, что вся контора изучает присланные логи и ищет проблему. Поскольку перевороты начались в самом конце апреля, дело, судя по всему, в новых прошивках.
fortemio
everyman:
выход простой - не “обновляться”.
в поддержку www.roi.ru/52056/
Инициатива № 77Ф52056 Уровень инициативы: Федеральный
Против ведения законопроекта № 547297-7 (увеличение админштрафов за полеты БПЛА)
ЗЫ у кого есть доступ в Госуслуги
hroft=
everyman:
Кто такой wee tsai? Интересно как они будут решать с дронами которые разбились…
Zigmund
MaLexa:
Подскажите пожалуйста, где покупали, как быстро отправили, чем отправили, как быстро едет? Тоже собираюсь купить, ищу варианты.
hroft=:
Как будет ответ, не забудьте озвучить его тут 😃 Всем интересно.
Седой75
fortemio:
Я обновился, полёт нормальный.
hroft=:
Тем, кто купил в магазине Фими, заменят тушки.
hroft=
Седой75:
Хм, надеюсь не так … Дрон куплен на Али, надеюсь та же гарантия
Седой75
hroft=:
Я с ними общался по этому поводу, ответили, что по гарантии обслуживает продавец, а не производитель. Вернее, техподдержка производителя старается помочь всем, но если помочь удалённо не получается, то они рекомендуют обратиться к продавцу, у которого покупали товар. А гарантия за пределами Китая не действует.
