TBS PowerCube и другие модульные контроллеры
Данная тема посвящена контроллеру TBS PowerCube, а также всем модульным контроллерам, которые появются в будущем.
Спецификации:
The next generation plug & play RACE system. Design optimized for ultimate performance and
reliability. Compatible with any multi rotor frame.
- Ultra-lightweight and high performance multi rotor stack
- Designed to be bundled and sold with any 120 – 330mm size frame
- Stacked boards for extreme durability
- STM32F3 based flight controller
- Innovative wire-free power distribution through stand-offs
- Purely plug and play, no soldering required
- Cost-efficient and field-repairable
- Tested, Developed and Flown by the world’s leading pilots
- Highest quality aluminum screws, brass standoffs and electronic components
- Dimensions: 36mm x 36mm x 30mm. Weight: 62g incl. PDB, wires & connectors
For the Professionals
- Weight saving AluminumGold-spacers, additional 10g weight saving
- Specialized tools for faster repair
Спецификации модуля полетного контроллера:
- STM32F303 based chipset for ultimate performance
- PPM, SBUS, DSM, DSMX input (5V and 3.3V provided over internal BUS)
- 6 PWM ESC output channels (autoconnect, internal BUS)
- Choose between plug & play sockets or solder pads for R/C and buzzer
- 36x36mm standard size (30.5mm standard raster)
- RGB LED strip support incl. power management
- Extension port for GPS / external compass / pressure sensor
- UART port for peripherals (Blackbox, FrSky telemetry etc.)
- 5V buzzer output
- MPU6500 new generation accelerometer/gyro
- 3x status LED (DCDC pwr/ 3.3V pwr/ status)
- Weight: 4.4g
Спецификации регуляторов:
BULLETPROOF 20A ESC 2-6S
The next in line of the most innovative, reliable and powerful ESCs. The first 6S capable TBS
BULLETPROOF ESC, forged and optimized for racing.
Built for race
- 960 step input resolution
- OneShot auto detection
- Fast regenerative braking
- SimonK firmware, BLHeli compatible
Safe and Reliable - Mechanical crash protection (no more
fires!) - Optimized passive cooling
- Automatic Motor/ESC protective
cutoff - Status LED
Technical Data: - Continuous Current: 20A
- Burst Current: 45A
- Voltage Range: 5.5 - 26V
- Dimensions: 36mm x 36mm x 3mm
- Weight: 4.8g without wires. 7.3g incl.
wires & 2mm bullet connectors - Input: PWM or OneShot
- Connectors: 2.0mm bullet connectors,
80mm wire - Firmware: SimonK RACE (custom)
Спецификации платы распределения питания:
POWERCUBE CURRENT SENSOR
Measures current and controls power distribution across the entire PowerCube. Provides
regulated and filtered voltage for ESC, Flight Control and FPV System (video transmitter and
receiver)
Performance
- Digital current and voltage
measurement for highest accuracy - Provides up to 2A 5V & 600mAh 12V
- Gold-plated contact points for best
performance
Building block - Accepts TBS CORE PNP PRO for
interactive flight control configuration - Provides flight telemetry to TBS CORE
PNP PRO - Interacts with all BST-compatible
equipment
Technical Data: - Continuous power: 100A
- Peak power: 120A
- Weight: 9.8g
Ports: - FPV Tx (5V, 12V or VBatt)
- FPV Camera (5V or 12V)
- BST (BlackSheep Telemetry)
- PowerCube BUS
- Battery connector
Официальное описание: www.blackeyeteam.de/shop/…/tbs_powercube.pdf
Инструкция:
www.team-blacksheep.com/tbs-powercube-manual.pdf
Тут можно задать вопрос создателям:
fpvlab.com/forums/showthread.php?42763-TBS-POWERCU…
Тут можно заказать:
miniquadfpv.com/product/tbs-powercube-pre-order/
redbee-copter.de/TBS-PowerCube
Я уже успел получить данный контроллер из первой партии, могу ответить на вопросы.
Пока удалось подключить к нему внешний BlackBox(openlog), LED-подсветку и Micro MinimOSD.
Из особенностей стоит отметить что в портах Serial-разъемов только 4.5v и OSD от них не работает, при этом на приемник идет полноценные 4.99v
Полетные испытания будут позже.
Топ вопросов:
- и - действительно идут по стойкам? - Да, именно так, при этом крепится контроллер только на две стойки(-) и на тонкий скотч.
- Можно ли подключить к контроллеру не родной OSD и BlackBox - Да, можно.
- Можно ли прошить контроллер на BetaFlight? - Мне не уудалось это сделать через CleanFlight, но можно сделать через утилиту для STM, однако она принимает только прошивки в .BIN
- Как сменить настройки регуляторов/перепрошить? - Есть спец-утилита для прошивки регулей, по сути это надстройка над AVRDude, но ее нет в открытом доступе.
- Что за прошивка залита в регуляторы? - BLHeli 14.2, возможно модифицированная, так как создатели заявляли что они побороли проблемы на 6s.
- Применяется ли какая либо водозащита? - Производитель заявляет полную защиту от влаги в виде плат покрытых лаком.
- Продаются ли отдельно платы из данного комплекта? - Пока в открытой продаже нет!
Открытые вопросы?
- Как настроить Current Sensor, чтобы показания корректно отображались в CleanFlight?
Открытые вопросы?
Видимо оно передаются по их протоколу только к их же CorePro
Примеры компоновки:
Тоже добавлю пару фоток
Красный держатель для гоупро распечатан на 3д-принтере? Можно чертёжиком поделиться?
не для GoPro, для XiaoMi брал здесь
Вот еще вопрос.
Как записать в контроллер Betaflight последней версии? .Hex файлы принимает только cleanflight, но через cleanflight контроллер не прошивается. Можно через штатную утилиту STM Flasher, но он принимает только .bin, а .bin на colibry race почему-то не выкладывают.
Вот еще вопрос.
Отвечаю сам себе.
В утилите, которой производится прошивка(см. инструкцию) - Defuse, есть программа которая конвертирует .hex и .bin файлы в фалй .dfu, которые принимает прошивальщик Defuse. Называется эта программа Dfu File Manager.
Соответственно порядок прошивки следующий:
- Скачиваем желаемый файл прошивка hex или bin
- Устанавливаем Defuse, ссылка есть в инструкции
- Запускаем программу Dfu File Manager
- В программе выбираем hex файл нашей прошивки и генерируем dfu файл, настройки можно не менять
- Далее прошиваем контроллер через Dfuse как написано в инструкции
Я все еще ищу способ отображать ток в MinimOSD, так как датчик тока подключен через шину bst и не может отражаться в Cleanflight/Betaflight. Тем не менее bst это ни что иное, как MavLink, который minimOSD также поддерживает с прошивками для ардукоптера например. Так вот можно ли подключить MinimOSD к powercube через bst и при этом снимать все показатели в OSD. Может кто подскажет?
Пока основная проблема в том что bst - это шина i2c, а в minimOSD - uart. Подойдет ли простой конвертер i2c->uart ? Вот такой:
Пришел по гарантии новый FC Colibri для PowercubА ,старый FC сильно кренился на задний правый луч, новый на передний правый ,причем чем за минуту уплывает так ,что невозможно управлять , что предпринять уже не знаю.
Наверно вопрос банальный, но все же спрошу:
Аксель калибровали?
Триммировали?
ну конечно , у меня это не первый контролер, на других контролерах все нормально летает.
первые 5 секунд полет нормальный потом начинает кренится на 1 луч
Убирать вибрации, летать в Акро.
Вибраций нет , летать могу в Акро ,но если я за что то заплатил , то это что то должно работать правильно! и никаких полумер.
Я ж не против, боритесь!
Но это частый глюк, от вибраций многие контроллеры заваливаются на бок.
Есть ли смысл переплачивать за Power Cube? Приемущества не критичны и понятны. Кроме цены,какие могут быть недостатки по сравнению с обычными билдами?
Недостатки, кроме цены, на мой взгляд, такие:
Здоровый этот кубик и тяжелый.
Регули какие-то непонятные, вроде бы на atmega (?) - если так, то не особо быстрые, эффективность также под вопросом
Герметизировать это все неудобно (я для зимы и/или дождя хотя бы регули герметизирую)
На пайке не соберешь, какие-то разъемы останутся, а я их в последнее время не люблю
Апгрейд усложнен - например, заменить полетный контроллер на свежий/современный будет затруднительно
Честно говоря, вообще не понял, зачем этот кубик и на кого рассчитан.
