Програмирование регуляторов Scorpion
Есть такой регулятор COMMANDER-15V-90A-V2. Летает на самолете.
Не нравится поведение в первой 2/3 газа. Уж больно вялое.
Кто нибудь подскажите, можно ли на нем настроить кривую газа.
А заодно подсказать как настроить конечные точки.
Насколько я знаю по 45А Скорпам никаких кривых там в настройках нет. При первом подключении задаются только начальная и конечная точки газа.
Если не трудно расскажите как это сделать.
Есть оригинал из инструкции к регулю и есть перевод из другого источника, оба документа выкладываю.
4.0 Initial setup
You MUST perform throttle range setup before the first use of
the ESC. Remove propeller/pinion from motor while
performing initial throttle range setup.
4.1
Throttle range setup (full throttle and stop)
4.2
Turn on transmitter and set throttle to maximum
position be sure that your throttle is set at 0%
minimum throttle and 100% at maximum throttle
4.3
Place the switch on the IR Receier to IRS (see section
5.0) Connect battery to ESC.(On 50V OPTO ESC’s you
will need to apply power to the receiver before
connecting the battery to the ESC). After few seconds
you will hear 3 beeps come from the motor to
indicate you are in programming mode. Check that
your throttle is at its maximum postion then push the
IR switch to PPM, After approximately 3 seconds you
will hear 2 beeps from the motor confirming the
maximum throttle position has been set. (If at this
time, you leave the throttle stick at maximum
position for over 10 seconds, the ESC will reset itself
to Factory default throttle settings)
4.4
Move throttle to minimum position within 10 seconds
and hold throttle at minimum position. Then you will
hear 2 beeps indicating minimum throttle position is
set and confirmed. Your ESC will also arm after you
have set the minimum position. You only need to do
this once as throttle range will be stored in the
memory of the speed controller. You can reset the
throttle range by performing steps 4.1 to 4.4 again
4.0 Первоначальная настройка.
Вы должны выполнить первоначальную настройку газа перед первым использованием
регулятора. Снимите пропеллер/адаптер с мотора перед началом выполнения настройки.
4.1
Настройка диапазона ручки газа ( полный газ и остановка)
4.2
Включите передатчик и установите газ в максимальное положение
4.3
Подсоедините батарею к регулятору. Приблизительно после 2х секунд диод начнет быстро
мигать, затем после еще одной секунды мотор должен пропищать 2 раза, подтверждая, что
максимальное положение газа установлено. (Если вы оставите ручку газа в таком же положении в
течение 10 секунд, то регулятор вернет заводские настройки.)
4.4
Сдвиньте ручку газа в минимальное положение в течение 10 секунд после предыдущей
операции. Диод должен быстро мигнуть. Затем вы должны услышать 2 коротких пика, говорящих о
том, что минимальное положение ручки газа установлено. Данная настройка проводится только
один раз, так как данные сохраняются в памяти регулятора. Вы можете сбросить эти настройки,
выполняя пункты 4.1-4.3.
Спасибо.
