KMS KBM 31/08 Brushless Motor 75g 1260Kv
Size (mm): Ø31.0x28.0
Weight: 75.5g
Max efficiency: 81%
Battery: 2~3 Li-Po
Recommended prop: 9x4.7 or 10x4.7
Current: .7~12A
Voltage: 7.4~11.1v
KMS KBM 31/09 Brushless Motor 75.5g 1100Kv
Weight: 75.5g
Max efficiency: 84%
Battery: 2~3 Li-Po
Current: .5~12A
Voltage: 7.4~11.1v
KMS KBM 31/21 Brushless Motor 57.5g 1750Kv
Weight: 57.5g
Max efficiency: 80%
Battery: 2~3 Li-Po
Recommended prop:8x4 or 9x4
Current: 1.8~13A
Voltage: 7.4~11.1v
KMS KBM 31/12 Brushless Motor 74g 970Kv
Size: 31 x 28 (mm)
Weight: 57.5 Grams
Max Efficiency: 80%
Battery: 2-3 Cell Lipo
Recommended Prop: 8 x 4, 9 x 4
Current: 1.3-13A
Voltage: 7.4 - 11.1
Mozhet ktoto mozhet podskazatj, 4to za zveri i kakuju tjagu pri kakih oborotah onji dadut.
smotrel v i-nete tam dazhe kitajozo-proizvoditelja naiti neljzja.
Stoimostj s 18A reguljatorom sostovlajjet okolo 100$
Extremely low resistance
High pulse rate
Low-voltage cut-off
Brake
Self-adjusting throttle range
Low torque soft start
Safe power-on arming program
Auto shut-down if radio signal is lost
Size (mm): 32x22x6
Weight: 22.5g
Constant current: 18a
Max… current: 25a
BEC: 5v/2a
Timing: auto
Pulse width: 8k
Battery: 2~3Li-Po or 4~12 NiMH
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"400feedf3df95500777953d5":{"_id":"400feedf3df95500777953d5","hid":2755,"name":"Modris","nick":"Modris","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50d8","hid":20,"title":"Электродвигатели, регуляторы, мотоустановки","parent":"61c9a54c3df9550077bb518f","description":"Коллекторные, бесколлекторные двигатели и регуляторы скорости.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":3531,"post_count":36024,"last_post":"66ceb5bbc68e4ffcbce15a94","last_topic":"66ceb5bbc68e4ffcbce15a93","last_topic_hid":572534,"last_topic_title":"Вдруг кому-то пригодится с регулем.","last_ts":"2024-08-28T05:29:31.813Z","last_user":"59ad19b83df9550077703a54"}},"topic":{"_id":"43832a339970730077016ac1","hid":31732,"title":"Motori kms","views_count":1751,"last_post_counter":1,"cache":{"post_count":1,"first_post":"43832a3399707300770171c1","first_ts":"2005-11-22T14:24:51.000Z","first_user":"400feedf3df95500777953d5","last_post":"43832a3399707300770171c1","last_post_hid":1,"last_ts":"2005-11-22T14:24:51.000Z","last_user":"400feedf3df95500777953d5"},"st":1,"section":"61c9a54c3df9550077bb50d8"},"subscription":null,"pagination":{"total":1,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
