Заказал на бике 2600KV Brushless Motor 2208-8.
Подскажите пожалуйста на какой ЛА можно его установить, какие винты использовать.
В наличии аккумы 2S.
параметры:
Model No.: 2208-8.
Rpm/V: 2600KV.
Motor Dimensions: Ф28*22mm.
Shaft Size: Ф3.17x33mm.
Battery Opernating: 2-3 Lipo.
Idle current: 1.5A.
Load current: 14A.
Power (Watt): 200.
ESC(A): 20A.
Ri(M Ω): 0.04.
Prop/recom: 6x5.
Size:4cm x 3cm x 3cm - 1.57inch x 1.18inch x 1.18inch.
Посылка пришла! На вид всё аккуратно. Придёт драйвер - поставлю на цессну - отпишусь
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"51fa457b3df9550077733dca":{"_id":"51fa457b3df9550077733dca","hid":167480,"name":"Epox","nick":"Epox","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50d8","hid":20,"title":"Электродвигатели, регуляторы, мотоустановки","parent":"61c9a54c3df9550077bb518f","description":"Коллекторные, бесколлекторные двигатели и регуляторы скорости.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":3531,"post_count":36024,"last_post":"66ceb5bbc68e4ffcbce15a94","last_topic":"66ceb5bbc68e4ffcbce15a93","last_topic_hid":572534,"last_topic_title":"Вдруг кому-то пригодится с регулем.","last_ts":"2024-08-28T05:29:31.813Z","last_user":"59ad19b83df9550077703a54"}},"topic":{"_id":"527636423df955007713402d","hid":341514,"title":"2600KV Brushless Motor 2208-8","views_count":2071,"last_post_counter":2,"cache":{"post_count":2,"first_post":"527636423df95500771344ca","first_ts":"2013-11-03T11:40:50.000Z","first_user":"51fa457b3df9550077733dca","last_post":"528853ca3df95500771344cc","last_post_hid":2,"last_ts":"2013-11-17T05:27:38.000Z","last_user":"51fa457b3df9550077733dca"},"st":1,"section":"61c9a54c3df9550077bb50d8"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
