Помогите пожалуйста не могу настроить двигатель . Заводится нормально но даю газ глохнет крутил все не помогает . нет паспорта -незнаю заводские установки .винтернете не могу найти ПОМОГИТЕ ПОЖАЛУЙСТА😍
NEEDLE SETTINGS
Master Needle Valve - main control for fuel mixture. Set at 3 to 31/2 turns from closed. Adjust this needle for
maximum RPM and power without being too lean or too hot. Make sure you start at bottom of needle seat!!
Side Carburetor Needle (Low Speed) - This needle is in the center side of the carburetor and provide throttle
response. It is not the idle adjustment. Set FLUSH with the brass sleeve. Turning in is Lean and Out is Rich. Do
not adjust this needle until the Master Needle is set for power and top speed. This will only effect throttle response.
FOR THREE NEEDLE CARBURETORS, DO NOT ADJUST MID RANGE NEEDLE, PRESET BY FACTORY
Barrel Stop Screws - Used for adjusting Idle. Set for 1/16th inch gap to start new engines. You can open more for
faster idle.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"493e320f3df9550077774aff":{"_id":"493e320f3df9550077774aff","hid":41633,"name":"saintgrun","nick":"saintgrun","avatar_id":null,"css":""},"4a15af3c3df955007776ddfc":{"_id":"4a15af3c3df955007776ddfc","hid":48510,"name":"sergej5908","nick":"sergej5908","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50ed","hid":27,"title":"Авто Off-Road","parent":"61c9a54c3df9550077bb50ff","description":"Внедорожники - монстр-траки, багги, стадиум-траки и другие. Масштабы от 1:12 до 1:8.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":7589,"post_count":468977,"last_post":"696dc781b4761b70bec1a5d6","last_topic":"57be78a63df9550077dd17c3","last_topic_hid":470306,"last_topic_title":"WLtoys 12423/12428","last_ts":"2026-01-19T05:56:17.346Z","last_user":"5ad37be83df95500776fed5b"}},"topic":{"_id":"4a3be2283df9550077967b40","hid":146230,"title":"Нужна помощь по двигателю Force46","views_count":701,"last_post_counter":2,"cache":{"post_count":2,"first_post":"4a3be2283df9550077968646","first_ts":"2009-06-19T19:08:24.000Z","first_user":"4a15af3c3df955007776ddfc","last_post":"4a3cb8c73df9550077968648","last_post_hid":2,"last_ts":"2009-06-20T10:24:07.000Z","last_user":"493e320f3df9550077774aff"},"st":1,"section":"61c9a54c3df9550077bb50ed"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
