Вопрос к владельцам Айсов
В инструкции на стр 13 про термодатчик написано следующее:
Cutoff Temperature: Ice can monitor the temperature of the battery which
is connected to the banana jack outputs. This feature is used in conjunction
with Ice’s optional Temperature Sensor (DTXP4171) which can be found at
local retailers. The Hobbico® Accu-Cycle™ Elite Temperature Sensor
(HCAP0281) and the Triton™ Thermal Probe from Great Planes®
(GPMM3151) are also directly compatible. Monitoring a battery’s
temperature in addition to its voltage can result in the most accurate full
charges without damaging the battery, and is highly recommended for use
with Li-Ion/Li-Po batteries. The adjustable range is from 50 - 132°F (10 -
55°C). The sensor jack is located on the right side of the charger
underneath the banana jacks. When properly connected to the jack, the
sensor’s white wire will be on the left and the black wire will be on the right.
Все ли пользуются родными датчиками или может кто использует например от Тритона?
Спасибо. Евгений
подходит и от тритона
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"40084dd23df9550077795462":{"_id":"40084dd23df9550077795462","hid":2731,"name":"Antenboy_E","nick":"Antenboy_E","avatar_id":null,"css":""},"4299dcec3df9550077790b7b":{"_id":"4299dcec3df9550077790b7b","hid":7497,"name":"pivankin","nick":"pivankin","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50a8","hid":4,"title":"Аппаратура радиоуправления","parent":"61c9a54c3df9550077bb50fc","description":"Приёмники и передатчики для радиоуправляемых моделей.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":9176,"post_count":222136,"last_post":"6aa2d5dab4761b70be47921b","last_topic":"58ff3b0f3df9550077d3f71a","last_topic_hid":494687,"last_topic_title":"Jeti Duplex DC-16, DS-16, DS-14 руководство по эксплуатации на русском","last_ts":"2026-09-10T16:07:54.304Z","last_user":"5beb0d533df95500776fba2b"}},"topic":{"_id":"452485a49970730077fa262d","hid":50640,"title":"ice? Не ice... ice!","views_count":1664,"last_post_counter":2,"cache":{"post_count":2,"first_post":"452485a49970730077fa2d19","first_ts":"2006-10-05T04:10:12.000Z","first_user":"40084dd23df9550077795462","last_post":"45249bc99970730077fa2d1b","last_post_hid":2,"last_ts":"2006-10-05T05:44:41.000Z","last_user":"4299dcec3df9550077790b7b"},"st":1,"section":"61c9a54c3df9550077bb50a8"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
