Setup Instructions
1.Before connecting the battery or switching on make sure that no damage or injury can occur from spinning wheels or propeller.
2.Set the throttle in the position you will use for neutral (engine off).
3.Connect the power and or switch on (Careful the motor may spin) The LED may flash and then go a constant red.
4.Using a pen or small screwdriver depress the “SET” button on the front face of the ESC The LED will flash - This has set the neutral throttle position.
5.Select full reverse and depress the “SET” button. The LED will flash - This has set the full reverse position.
6.Select full forward and depress the “SET” button. The led will flash - This has set the full forward position.
7.Turn off and turn on check that neutral and forward and reverse are correct. If as with some transmitters the motor is running opposite direction redo the set up with the forward and reverse in the reverse order.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"4543b4763df95500777884ce":{"_id":"4543b4763df95500777884ce","hid":17851,"name":"leliksan","nick":"leliksan","avatar_id":null,"css":""},"45630f923df9550077787d9e":{"_id":"45630f923df9550077787d9e","hid":18404,"name":"AlexN","nick":"AlexN","avatar_id":null,"css":""},"48f474053df95500777768f3":{"_id":"48f474053df95500777768f3","hid":39415,"name":"Brodiaga","nick":"Brodiaga","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50ba","hid":8,"title":"Самодельная электроника, компьютерные программы","parent":"61c9a54c3df9550077bb50f3","description":"Софт для моделирования и черчения, самодельные электронные устройства.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":2670,"post_count":48294,"last_post":"6b0c1d9db4761b70be86818d","last_topic":"6b0c1d9db4761b70be86818c","last_topic_hid":572744,"last_topic_title":"Бесплатные браузерные инструменты для изучения классических шифров","last_ts":"2026-11-29T12:42:05.144Z","last_user":"6b05add844153b386524b907"}},"topic":{"_id":"495f0d873df9550077a309ed","hid":126676,"title":"контроллер EK2-0605A","views_count":1659,"last_post_counter":3,"cache":{"post_count":3,"first_post":"495f0d873df9550077a30d5d","first_ts":"2009-01-03T07:02:31.000Z","first_user":"48f474053df95500777768f3","last_post":"4b3dcd543df9550077a30d61","last_post_hid":3,"last_ts":"2010-01-01T10:24:20.000Z","last_user":"4543b4763df95500777884ce"},"st":1,"section":"61c9a54c3df9550077bb50ba"},"subscription":null,"pagination":{"total":3,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
