Подскажите для чего на выходе к приемнику четвертый белый провод с отдельным конектором?
это настраиваемый вход регуля.
например можно использовать для блокировки запуска с помощью канала на приемнике.
настройка определяется на вкладке Other программы CastleLink пункт Auxiliare Wire Mode
возможные значения
Disabled
Disabled input and output of the AUX LINE.
Gain Inpu t
Allows an external throttle signal connected to the AUX LINE to adjust the governor gain of controller in real time.
RPM Out
Toggles the AUX LINE for every electrical commutation. Divide this number by your number of magnetic pole pairs for mechanical RPM.
Arm Lock Key
This mode uses the Arming Lock Key Harness which attaches to the AUX LINE and the receiver. While the key is in the socket the controller will be incapable of arming. Once removed, the ESC will be allowed to arm when it receives a low throttle command on the traditional throttle line.
RX Arm Lock
Locks the controller when the signal on the AUX LINE is below 50% (<1.5ms).
Audible Beacon
Causes the controller to emit an audible beacon from the motor when the AUX LINE receives a signal over 50% (>1.5ms). The beacon is only emitted if the motor is not running.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"4f3e22e13df955007774805c":{"_id":"4f3e22e13df955007774805c","hid":114200,"name":"Маркс","nick":"Маркс","avatar_id":null,"css":""},"52f992e73df955007772c510":{"_id":"52f992e73df955007772c510","hid":195518,"name":"rkloff","nick":"rkloff","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb517d","hid":87,"title":"Бортовая электроника","parent":"61c9a54c3df9550077bb50fc","description":"Рулевые машинки, гироскопы, индикаторы питания и т.п.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":2535,"post_count":34059,"last_post":"6a85ee7f44153b3865ee8f7e","last_topic":"53d757cb3df95500770343c1","last_topic_hid":373167,"last_topic_title":"Перепрошивка ESC HobbyPower 30A","last_ts":"2026-08-19T17:57:19.397Z","last_user":"6a84693200fb687e16fba339"}},"topic":{"_id":"54cf5b483df9550077fb5a57","hid":394914,"title":"регулятор castle phoenix","views_count":852,"last_post_counter":2,"cache":{"post_count":2,"first_post":"54cf5b483df9550077fb6527","first_ts":"2015-02-02T11:11:04.000Z","first_user":"52f992e73df955007772c510","last_post":"54cf5ff23df9550077fb6529","last_post_hid":2,"last_ts":"2015-02-02T11:30:58.000Z","last_user":"4f3e22e13df955007774805c"},"st":1,"section":"61c9a54c3df9550077bb517d"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
