Добрый вечер. Кто нибудь подскажет о настройках дымовой системы (sullivan) относительно газа? Микшировать, не микшировать, если да то как, или просто вкл./выкл.? Апаратура позволяет всё. Среди моря информации, по настройкам не нашёл. А из инструкции, с помощью переводчика как не стыдно ,ничего не понял.
Example Set-up for Futaba 9CA/9CH Radio System:
If you are running your radio in ACRO mode this is the program that we
recommend:
Program mix 1: (or any free program file)
Page1
MASTER = Throttle
SLAVE = Aux 1 (or Aux 2 if preferred.)
LINK = OFF or ON (this does not matter)
TRIM = ON
SWICH = A (this does not matter either just pick one you are comfortable with)
POSITION = UP (does not matter, same as above)
Page 2
RATE DOWN = 0% (this has no effect on the pump)
RATE UP = something between -50 and -100 (higher numbers make the top
speed of the pump higher and make it come on at a lower throttle setting.
OFFSET = varies, if everything else is zeroed try about 10%-20%. You set this
by putting the throttle stick at or close to your low throttle setting and holding
down the dial to set the position.
Subtrim Menu:
Set the subtrim of the auxiliary channel used for the Skywriter to -100%
(This provides the negative output to override the failsafe when the switch is off.)
This should complete the set up. Be sure that any knobs that affect this
channel are centered (Default is Rotary Knob “C”). You may need to tweak the
program to work with your throttle settings if you have adjusted the travels or
trims but this is a good point to work from regardless.
Other Troubleshooting Tools:
1.) Set this program up on a clean Empty Model then check out the results using
the Servo viewer
2.) If your radio does not have a servo output viewing function use a “Y” harness
to put a spare servo on the same channel so you can monitor the signal being
sent to the Skywriter
Hope this helps!
Присоединяюсь к вопросу- недавно приобрел такую же
Это кто как хочет, у меня стоит краник и помпа. Краником регулирую подачу дым жижи, надо по больше открыл на полную, надо меньше чуть призакрыл, а помпу включаю в воздухе. Можно конечно и замикшировать с каналом газа, тут все просто, полный газ подача жижи больше, меньше газ соответственно жижи меньше.
А какой краник используете, ставится до помпы?
Стоит после помпы, т.е в магистрале между помпой и обратным клапаном.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"467bdafe3df95500777835be":{"_id":"467bdafe3df95500777835be","hid":24445,"name":"Yura_33","nick":"Yura_33","avatar_id":null,"css":""},"46ee1d173df9550077781120":{"_id":"46ee1d173df9550077781120","hid":27876,"name":"samic","nick":"samic","avatar_id":null,"css":""},"4dc82ae63df9550077752c8c":{"_id":"4dc82ae63df9550077752c8c","hid":87853,"name":"odessit","nick":"odessit","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb5183","hid":89,"title":"Бензиновые двигатели","parent":"61c9a54c3df9550077bb518c","description":"Эксплуатация бензиновых двигателей, системы электронного зажигания.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":1479,"post_count":63382,"last_post":"67bff78ef9bb00ab89c15cd0","last_topic":"66d63198c68e4ffcbc52176d","last_topic_hid":572538,"last_topic_title":"Доброго...прошу помочь опознать двигатель","last_ts":"2025-02-27T05:26:38.937Z","last_user":"4aa7eb413df955007776a426"}},"topic":{"_id":"4f74ba313df95500773b1ab2","hid":272441,"title":"Настройки дым.системы","views_count":1862,"last_post_counter":5,"cache":{"post_count":5,"first_post":"4f74ba313df95500773b2032","first_ts":"2012-03-29T19:38:25.000Z","first_user":"4dc82ae63df9550077752c8c","last_post":"4f7bca203df95500773b203a","last_post_hid":5,"last_ts":"2012-04-04T04:12:16.000Z","last_user":"46ee1d173df9550077781120"},"st":1,"section":"61c9a54c3df9550077bb5183"},"subscription":null,"pagination":{"total":5,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
