Как правильно забиндить(2,4)передатчик с новым приемником на Big Lame? Спасибо!
Людей знающих как забиндить передатчик с приемником(2,4) наверное нет! А сколько приемников (2,4) можно забиндить на один передатчик(пульт)Что бы на один пульт повесить 2-3 вертолета E-Sky( Big Lama,HB V2,HB cp3 итд)???
а Вы в Гугле забанены? вот по первой же ссылке инструкция:
_To BIND
Unplug the battery to the 4 in 1 mix controller. (If you haven’t already done so).
Connect the battery to the 4 in 1 mix controller. The orange LED should now be flashing slowly.
Turn the transmitter on. The LED should go through a series of high speed flashes and then become solid. Binding should now be successful.
Turn the transmitter off._
_
To UNBIND
Turn transmitter off
Locate the BIND push switch and push it in for about 2 -3 seconds and the LED orange light should start flashing very fast. UNBIND is now successful.
This BIND switch is located at the end of the 4 in 1 mix controller and just pokes out the end of the circuit board in the middle on the same side and level with the LED. Its only about 1mm wide so look carefully._
там же ответы и на другие вопросы.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"4c4704993df955007775e59d":{"_id":"4c4704993df955007775e59d","hid":69321,"name":"rattis","nick":"rattis","avatar_id":null,"css":""},"4cd09d633df955007775a6c2":{"_id":"4cd09d633df955007775a6c2","hid":74297,"name":"Иван_Иванов","nick":"Иван_Иванов","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb5198","hid":96,"title":"Соосные вертолёты","parent":"61c9a54c3df9550077bb5129","description":"Обсуждение радиоуправляемых вертолётов соосной конструкции.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":903,"post_count":18225,"last_post":"61deee2c7f12d6009f8e5bff","last_topic":"61deee2c7f12d6009f8e5bfe","last_topic_hid":570590,"last_topic_title":"Строим соосник на базе 450 вертолетов и их братьев. под копийный корпус","last_ts":"2022-01-12T15:05:16.335Z","last_user":"4ffc7b9e3df9550077742429"}},"topic":{"_id":"4cf549793df955007762fbef","hid":212796,"title":"ESKY BIG LAMA - особенности управления","views_count":31708,"last_post_counter":27,"cache":{"post_count":27,"first_post":"4cf549793df955007762ffe3","first_ts":"2010-11-30T18:59:05.000Z","first_user":"4cf128ae3df9550077759682","last_post":"4ec12ff63df9550077630017","last_post_hid":27,"last_ts":"2011-11-14T15:12:54.000Z","last_user":"4c4704993df955007775e59d"},"st":1,"section":"61c9a54c3df9550077bb5198"},"subscription":null,"pagination":{"total":27,"per_page":25,"chunk_offset":25},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
