Новая 700ка: OMP M7
OMP Hobby анонсировали вертолёт 700ого класса в своей линейке. Выглядит интересно. Фичи:
The M7 is engineered with many state-of-the-art design features, such as a beautifully painted fiberglass canopy which closes in the back, a hollow 15mm main shaft with a large sprag clutch for power transfer, a sturdy helical main gear, an 8mm wide tail belt with very large pulleys, a strutless large diameter tail boom and much, much more!
Features of the OMPHOBBY M7
• Designed by Jonas Wackershauser
• Large control throws on all axes provide tremendous authority and maneuverability
• Ball bearing supported spindle shaft pivot for precise rotor phase alignment and crisp collective authority
• Possible blade lengths up to 715mm + 116mm
• RotorTech 700 Ultimate + RotorTech 106 Ultimate, the best performing 700 blades on the market, included with the kit
• Motor mount with special coaxiality flange allows for easy gear meshing
• Molded 3D carbon fiber lower frame with integrated battery rails
• Innovative helical belt tensioner system, not needing any tools for adjustment from loose to tight
• Highest grade 7075 aluminium on all moving parts
• Canopy quick release connectors installed by default
• Quick release dual-lock battery system
• Vibration isolating FBL platform with optional mass damper
• Multiple available gear ratios from 10.90:1 to 8:1
• Convenient and clean wiring paths across the entire helicopter
• Dual row ball bearings in critical components guarantee highest precision and longevity
• Specially made servo spacers and nuts guarantee effortless and perfectly square servo mounting
• Turnbuckles with wrench hole allow for easy setup, adjustment and tracking
• Rotation-plane matched yaw control pivots provide minimal linearity error
• Blade grips feature integrated steel bushings to retain the specially designed blade spacers and reduce wear
• 15mm sprag clutch for secure power transfer
• Highly engineered ball joints provide maximum flight safety and butter smooth ball link operation
• Easily accessible screws across the entire heli provide effortless maintenance
• Large diameter strutless carbon tailboom
• Steep tail transmission ratio for exceptional tail authority at any RPM
• Large drive pulleys with an 8mm wide belt ensure secure power transfer to the tail rotor
• One-piece, CNC-machined aluminium tail housing for unparalleled precision
• Long-throw tail rotor design with integrated dynamic weights guarantees maximum precision and unparalleled tail control
Цена и когда появится в продаже пока непонятно. Но это будет мой второй 700й в компанию к Tron 7.0
