Xiaomi Mi Drone FPV 4K
MadGrizly
Jentosik86:
Есть вообще характеристики?
Product name: millet UAV version 1080p
Product number: MJSZFXQ01FM+YTXJ01FM/
Type of the products: + millet millet unmanned drone PTZ camera
Millet UAV version 4K
MJSZFXQ02FM+YTXJ02FM/
  • Millet millet unmanned drone PTZ camera (4K)
    Aircraft
    Product type: four-axis aircraft (entry level)
    Hover accuracy: vertical: +/-0.1M (ultrasonic range), +/-0.5M
    Hover precision: horizontal: +/-1.5mm
    Lifting speed: speed: 6m/s (currently limited to 4 m)
    Lifting speed: decrease speed: 1.5M/s
    Flight speed: 18m/s (currently limited within 6 meters)
    Altitude: 120 m (domestic, restrictions)
    Flight time: 27 minutes
    Wheel base: 434mm
    Wind resistance level: 4
    Four-axis aircraft (entry level)
    Vertical: +/-0.1M (ultrasonic range), +/-0.5M
    Horizontal: +/-1.5mm
    Increase speed: 6m/s (currently limited to 4 m)
    Falling speed: 1.5M/s
    For more than 27 minutes
    434mm
    4
    Remote control
    Operating frequency: 2426.5MHz~2461MHz
    Control distance: 1000 m (domestic limit of 500 m)
    Sensitivity:-101 ± 2dBm
    Transmit power: <20dBm (domestic)
    2426.5MHz~2461MHz
    2000 m (domestic limit of 500 m)
    -101±2dBm
    <23dBm (domestic)
    PTZ
    Controllable rotation range: pitch:-90 to 0 degrees
    Angle accuracy: ± 0.02 °
    Three-axis stabilized pan/tilt: image stabilized + course followed
    Auto stable angle: pitch -120~35
    Auto stable angle: roll -35~35
    Auto stable angle: position -65~65
    Elevation:-90 to 0 degrees
    ± 0.02 °
    Image stabilized + course followed
    Pitch -120~35
    Roll -35~35
    Directions -65~65
    Camera
    Lens: focal length of camera FOV 104 ° F/NO:F2.6:4.2mm (equivalent to 23mm)
    Sensors: 1/2.3-inch 16.35M Exmor r Sensor
    Effective pixels: 16.35 million
    ISO range: 100-3200 (video)
    ISO range: 100-1600 (photo)
    Shutter speed: 1/6 ~1/8000 seconds
    Photo resolution: resolution: 16M (4608x3456 4:3)/12M (4608x2592 16:9)/
    Photo resolution: 8M (3264x2448 4:3)
    Video resolution: 1920x1080p 60fps
    Video resolution: 1920x1080p 30fps
    Video resolution: 1280x720p 120fps
    Shooting mode: single shot
    Shooting modes: video capture
    File formats: file system: FAT32/exFAT
    File format: image format: JPEG
    File formats: video format: MP4
    Memory card type: TF Card (support more than Class10/U1) 8~64G
    Supported frequency band: 5GHz CH100 ~ CH165
    Power range: 14dBm ~ 20dBm
    FOV 94 ° F/NO:F2.8 camera focal length: 3.7mm (equivalent to 20mm)
    1/2.3-inch 12.4M Exmor R Sensor
    12.4 million
    100-3200 (video)
    100-1600 (photo)
    1/8 s ~1/8000 s
    Resolution: 12M (4000x3000 4:3)/8M (3840x2160 16:9)
    3840x2160p 30fps
    2560x1440p 30fps
    1920x1080p 100/60/30fps
    Single shot
    Video capture
    File system: FAT32/exFAT
    Picture format: JPEG
    Video format: MP4
    2.4G
    20dBm~23dBm
    Chargers
    Charger: 17.5V
    Rated output: 16V-2.9A
    Rated input: 100-240V ~ 50/60Hz 1.5A Max
    Rated power: charger rating: 46.4 km w
    17.5V
    16V-2.9A
    Charger power: 46.4 km w
    Battery
    Charge limiting voltage: 17.4V
    Rated capacity: 15.2V (TYP) -5100 mAh 77.52Wh
    Time: 27 minutes (including PTZ cameras)
    17.4V
    15.2V(TYP)-5100 mAh 77.52Wh
    Propeller
    Type: self tightening
    Length: 10 inches
    Pitch: 4.6 inches
    Model: 1046
    Self tightening
    10 inch
    4.6 inches
    1046
    Protection frame
    Weight (single): 22.66g
    Angle: 140 °
    RADIUS: 135mm
    After installation the maximum overall dimensions: 704mm
    Lwh: 254mm*13.8mm*38mm
    22.66g
    140 °
    135mm
    704mm
    254mm*13.8mm*38mm
    Other parameters
    Product color: white
    Product weight: 1376 g
    Application environment: 0 ° c to 40 ° c
    White
    1376 g
    0 ° c to 40 ° c
Droider
А где нибудь уже говорили, когда это чудо ждать в продаже?
SovGVD
Ох тыж, срачельник как обычно DIY vs Phantom. Все эти доводы про DIY лучше разбиваются об цену и возможности. Ни разу не видел самоделку, где настройками камеры можно рулить с пульта и в целом иметь хоть какой то интерфейс, а не запоминать азбуку морзе из перемигиваний и пикания.
А я вот жду от Сиоми коптер, посмотрим что выйдет, цена очень привлекательная, характеристики красивые, но без РЕАЛЬНЫХ ИСХОДНИКОВ фото (raw) и видео смысла о чем то говорить мне кажется нет. На рекламных роликах любая палка с изолентой снимает не хуже red epic.
Shuricus
Я о том же. Нет универсальных коптеров. Поэтому нельзя смешивать все в кучу. Под свои задачи, лучше Фантома пока ничего нету. Надеюсь теперь будет. Не лучше, но дешевле.
ARXITEKTOR
Моторки стандарт в этом классе 2212 ?
Акк 4S и HV ?
Линк цифровой как я понял 2,4 Ггц может станет источником потрохов для самосборов ).
Камеру удобно сделали снять можно для транспортировки.
Предусмотрели бы механизм катапультирования при крашах.
MFer
Предзаказать можно уже где-то?
ARXITEKTOR
Передача на телефон по проводу или без?
Matrixro
Вроде по проводу. Посмотрите картинки на бангуде по ссылке.
Что там за батарейка с номинал 17,4В? 😃😃
MFer
еще видосы:
1 , 2 , 3
vs P3 - рама точно больше, моторы субъективно тоже…
Shuricus
Они задолбали, даже видео полетов есть, а с коптера нет.
Не весь текст понял, но тут явно слышно, что он говорит Сяоми. 😃
MFer
QwErT1999:
Ну как же, есть.
это реклама, на что снимали понятно ))
Shuricus:
настораживает фраза с одного новостного ресурса:
“Сбор средств на выпуск младшей версии БПЛА планируется осуществить посредством краудфандинга, старт которого запланирован на завтра. Что касается модификации с 4К-камерой, то этап открытого бета-тестирования данной модели намечен на конец июля 2016 года.”
  1. xiaomi и краудфайндинг - как-то не вяжется, не? ))
  2. бета-тестирование… получим мы готовый аппарат осенью, а потом окажется, что зимой он мерзнет и не летает )) ждем весны 2017 )))
upd: так, спецы, налетай - чеза начинка, кто рассмотрит здесь?
Shuricus
QwErT1999:
Ну как же, есть.
MFer:
Еще больше не вяжется смысл HD версии при такой смехотворной разнице в цене с 4К. Она никому не нужна.
Shuricus
Это такой официальный магазин, как я балерина.
И где там софт?
Неизвестно когда его продавать будут. Какой софт вообще.
Странник_163
Shuricus:
И где там софт?
Ну я предполагаю два варианта:
  1. Софт лежит в пульте управления и устанавливается при первом подключении телефона/планшета.
  2. Как вариант ничего не устанавливается, а просто транслируется с пульта по проводу…
Scorp77
Странник_163:
Для iOS такое точно не возможно.
Я думаю Софт появится в сторах как начнутся продажи.
Shuricus
Ну или на официальном сайте, как это обычно всегда и происходит.
Странник_163:
Человек спросил где ссылки на софт, а вы продолжаете писать бесполезные сообщения. Нет ни ссылок, ни софта, ни коптера. Наберитесь терпения.
citric
MFer:
еще видосы:
1 , 2 , 3
Субьективно посмотрите фото и увидите что там субьективно написано 2212 и на вид такие же как на али по 300 рублей моторы))
Странник_163
Shuricus:
Что-то я не увидел здесь -
Modesto:
Не увидел не где ни какой ссылки на софтину, которая в смарт или планшет заливается:
ни одного вопроса, только констатация факта)))
MFer
А че так горизонт завален? ))
