С типом понятно 2LIPO, а вот с остальными параметрами не понятно что выбрать.
BREKE SET - Варианты такие: NO/SOFT/MID/HARD . Какой выбрать? На что повлияет?
TIMING MODE SET: 2"/ 7"/ 15"/ 30". Какой выбрать для данного двигателя? На что повлияет?
3.Voltage Protection: 2.8V/CELL, 2.9V/CELL, 3.0V/CELL. Какой выбрать для данного аккумулятора?
Двигатель Brushless Motor 2408-21t-3 (www.xushobby.com/servlet/Detail?no=31)
Параметры:
For 2-3 Li-Poly Cells (7.2-12.6V)
Recommended props: 9 x 4.7, 10 x 4.7, 11 x 4.7 Slow Flyer
31 mm diameter x 46.5 mm length
Maximum current: 12A
Weight: 66.7 grams / 2.35 oz (everything shown in picture including gray gear box housing)
Comes with stick mount plastic frame
Firewall mount capable
Comes with two prop nuts and one washer
3mm shaft diameter
10mm x 10mm stick mount
Kv: 1260
12 Stator Poles, 14 Magnets
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"463f5dff3df955007778476a":{"_id":"463f5dff3df955007778476a","hid":22895,"name":"UserM","nick":"UserM","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50d8","hid":20,"title":"Электродвигатели, регуляторы, мотоустановки","parent":"61c9a54c3df9550077bb518f","description":"Коллекторные, бесколлекторные двигатели и регуляторы скорости.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":3531,"post_count":36024,"last_post":"66ceb5bbc68e4ffcbce15a94","last_topic":"66ceb5bbc68e4ffcbce15a93","last_topic_hid":572534,"last_topic_title":"Вдруг кому-то пригодится с регулем.","last_ts":"2024-08-28T05:29:31.813Z","last_user":"59ad19b83df9550077703a54"}},"topic":{"_id":"475c35f33df9550077b6803b","hid":85698,"title":"Программирование ркгуляторя MAG8 ESC18A","views_count":1833,"last_post_counter":2,"cache":{"post_count":2,"first_post":"475c35f33df9550077b68649","first_ts":"2007-12-09T18:37:39.000Z","first_user":"463f5dff3df955007778476a","last_post":"475c3ab53df9550077b6864b","last_post_hid":2,"last_ts":"2007-12-09T18:57:57.000Z","last_user":"463f5dff3df955007778476a"},"st":1,"section":"61c9a54c3df9550077bb50d8"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
