Торжокское небо
OK-40
Вов, скинь мне свой dump c крыла
Sem-EX
OK-40:
а мож прям сюда,для всех…
Entering CLI Mode, type ‘exit’ to return, or ‘help’
# dump
# version
# INAV/OMNIBUSF4PRO 1.8.0 Nov 1 2017 / 06:34:32 (912d1315)
# resources
# mixer
mixer FLYING_WING
mmix reset
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 -90 -1
servo 4 1000 2000 1500 90 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mix
smix reset
# feature
feature -RX_PPM
feature -VBAT
feature -RX_UIB
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DASHBOARD
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature -SUPEREXPO
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -PWM_SERVO_DRIVER
feature -PWM_OUTPUT_ENABLE
feature -OSD
feature VBAT
feature GPS
feature CURRENT_METER
feature AIRMODE
feature PWM_OUTPUT_ENABLE
feature OSD
# beeper
beeper RUNTIME_CALIBRATION
beeper HW_FAILURE
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACTION_SUCCESS
beeper ACTION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper LAUNCH_MODE
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSED
# map
map AETR5678
# name
name -
# serial
serial 20 1 115200 38400 0 115200
serial 0 64 115200 38400 0 115200
serial 2 0 115200 38400 0 115200
serial 5 2 115200 115200 0 115200
# led
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
# aux
aux 0 0 0 1475 2100
aux 1 1 1 1500 2100
aux 2 3 3 1500 2100
aux 3 8 2 1500 2100
aux 4 10 1 900 1500
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# master
set looptime = 2000
set gyro_sync = ON
set gyro_sync_denom = 2
set align_gyro = DEFAULT
set gyro_hardware_lpf = 20HZ
set gyro_lpf_hz = 60
set moron_threshold = 32
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 1
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 1
set vbat_adc_channel = 2
set rssi_adc_channel = 3
set current_adc_channel = 1
set airspeed_adc_channel = 0
set acc_notch_hz = 0
set acc_notch_cutoff = 1
set align_acc = DEFAULT
set acc_hardware = MPU6000
set acc_lpf_hz = 15
set acczero_x = 122
set acczero_y = 31
set acczero_z = 153
set accgain_x = 4056
set accgain_y = 4082
set accgain_z = 4030
set rangefinder_hardware = NONE
set align_mag = DEFAULT
set mag_hardware = NONE
set mag_declination = 0
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set mag_calibration_time = 30
set baro_hardware = NONE
set baro_use_median_filter = ON
set pitot_hardware = NONE
set pitot_use_median_filter = ON
set pitot_noise_lpf = 0.600
set pitot_scale = 1.000
set receiver_type = SERIAL
set mid_rc = 1500
set min_check = 1100
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_invert = OFF
set rc_smoothing = ON
set serialrx_provider = SBUS
set sbus_inversion = ON
set rx_spi_rf_channel_count = 0
set spektrum_sat_bind = 0
set rx_min_usec = 885
set rx_max_usec = 2115
set serialrx_halfduplex = OFF
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SDCARD
set sdcard_detect_inverted = ON
set min_throttle = 1000
set max_throttle = 1850
set min_command = 1000
set motor_pwm_rate = 400
set motor_pwm_protocol = STANDARD
set failsafe_delay = 5
set failsafe_recovery_delay = 5
set failsafe_off_delay = 200
set failsafe_throttle = 1000
set failsafe_throttle_low_delay = 100
set failsafe_procedure = RTH
set failsafe_stick_threshold = 50
set failsafe_fw_roll_angle = -200
set failsafe_fw_pitch_angle = 100
set failsafe_fw_yaw_rate = -45
set failsafe_min_distance = 0
set failsafe_min_distance_procedure = DROP
set align_board_roll = 16
set align_board_pitch = 68
set align_board_yaw = 0
set gimbal_mode = NORMAL
set battery_capacity = 0
set vbat_scale = 110
set vbat_max_cell_voltage = 43
set vbat_min_cell_voltage = 32
set vbat_warning_cell_voltage = 34
set current_meter_scale = 265
set current_meter_offset = 0
set multiwii_current_meter_output = OFF
set current_meter_type = ADC
set yaw_motor_direction = 1
set yaw_jump_prevention_limit = 200
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lpf_hz = 20
set flaperon_throw_offset = 200
set tri_unarmed_servo = ON
set reboot_character = 82
set imu_dcm_kp = 2500
set imu_dcm_ki = 50
set imu_dcm_kp_mag = 10000
set imu_dcm_ki_mag = 0
set small_angle = 180
set fixed_wing_auto_arm = OFF
set disarm_kill_switch = ON
set auto_disarm_delay = 5
set gps_provider = UBLOX
set gps_sbas_mode = AUTO
set gps_dyn_model = AIR_1G
set gps_auto_config = ON
set gps_auto_baud = ON
set gps_min_sats = 6
set deadband = 5
set yaw_deadband = 5
set pos_hold_deadband = 20
set alt_hold_deadband = 50
set 3d_deadband_throttle = 50
set fw_autotune_overshoot_time = 100
set fw_autotune_undershoot_time = 200
set fw_autotune_threshold = 50
set fw_autotune_ff_to_p_gain = 10
set fw_autotune_ff_to_i_tc = 600
set inav_auto_mag_decl = ON
set inav_gravity_cal_tolerance = 5
set inav_use_gps_velned = ON
set inav_gps_delay = 200
set inav_reset_altitude = FIRST_ARM
set inav_max_surface_altitude = 200
set inav_w_z_surface_p = 3.500
set inav_w_z_surface_v = 6.100
set inav_w_z_baro_p = 0.350
set inav_w_z_gps_p = 0.200
set inav_w_z_gps_v = 0.500
set inav_w_xy_gps_p = 1.000
set inav_w_xy_gps_v = 2.000
set inav_w_z_res_v = 0.500
set inav_w_xy_res_v = 0.500
set inav_w_acc_bias = 0.010
set inav_max_eph_epv = 1000.000
set inav_baro_epv = 100.000
set nav_disarm_on_landing = OFF
set nav_use_midthr_for_althold = OFF
set nav_extra_arming_safety = OFF
set nav_user_control_mode = ATTI
set nav_position_timeout = 5
set nav_wp_radius = 100
set nav_wp_safe_distance = 10000
set nav_auto_speed = 300
set nav_auto_climb_rate = 500
set nav_manual_speed = 500
set nav_manual_climb_rate = 200
set nav_landing_speed = 200
set nav_land_slowdown_minalt = 500
set nav_land_slowdown_maxalt = 2000
set nav_emerg_landing_speed = 500
set nav_min_rth_distance = 0
set nav_rth_climb_first = ON
set nav_rth_climb_ignore_emerg = OFF
set nav_rth_tail_first = OFF
set nav_rth_allow_landing = NEVER
set nav_rth_alt_mode = AT_LEAST
set nav_rth_abort_threshold = 64999
set nav_rth_altitude = 7000
set nav_mc_bank_angle = 30
set nav_mc_hover_thr = 1500
set nav_mc_auto_disarm_delay = 2000
set nav_fw_cruise_thr = 1400
set nav_fw_min_thr = 1200
set nav_fw_max_thr = 1700
set nav_fw_bank_angle = 35
set nav_fw_climb_angle = 20
set nav_fw_dive_angle = 20
set nav_fw_pitch2thr = 15
set nav_fw_loiter_radius = 5000
set nav_fw_land_dive_angle = 2
set nav_fw_launch_velocity = 300
set nav_fw_launch_accel = 1863
set nav_fw_launch_max_angle = 45
set nav_fw_launch_detect_time = 40
set nav_fw_launch_thr = 1700
set nav_fw_launch_idle_thr = 1000
set nav_fw_launch_motor_delay = 500
set nav_fw_launch_spinup_time = 100
set nav_fw_launch_timeout = 5000
set nav_fw_launch_climb_angle = 18
set telemetry_switch = OFF
set telemetry_inversion = OFF
set frsky_default_latitude = 0.000
set frsky_default_longitude = 0.000
set frsky_coordinates_format = 0
set frsky_unit = METRIC
set frsky_vfas_precision = 0
set frsky_vfas_cell_voltage = OFF
set hott_alarm_sound_interval = 5
set smartport_uart_unidir = OFF
set smartport_fuel_percent = OFF
set ibus_telemetry_type = 0
set ltm_update_rate = NORMAL
set ledstrip_visual_beeper = OFF
set osd_video_system = 0
set osd_row_shiftdown = 0
set osd_units = METRIC
set osd_rssi_alarm = 20
set osd_cap_alarm = 0
set osd_time_alarm = 20
set osd_alt_alarm = 300
set osd_artificial_horizon_reverse_roll = OFF
set osd_crosshairs_style = DEFAULT
set osd_left_sidebar_scroll = NONE
set osd_right_sidebar_scroll = NONE
set osd_sidebar_scroll_arrows = OFF
set osd_main_voltage_pos = 385
set osd_rssi_pos = 23
set osd_flytimer_pos = 311
set osd_ontime_pos = 279
set osd_flymode_pos = 2509
set osd_throttle_pos = 65
set osd_vtx_channel_pos = 200
set osd_crosshairs_pos = 0
set osd_artificial_horizon_pos = 2248
set osd_current_draw_pos = 2464
set osd_mah_drawn_pos = 2432
set osd_craft_name_pos = 84
set osd_gps_speed_pos = 2145
set osd_gps_sats_pos = 2168
set osd_gps_lon_pos = 402
set osd_gps_lat_pos = 384
set osd_home_dir_pos = 2478
set osd_home_dist_pos = 2112
set osd_altitude_pos = 2080
set osd_vario_pos = 183
set osd_vario_num_pos = 248
set osd_pid_roll_pos = 322
set osd_pid_pitch_pos = 354
set osd_pid_yaw_pos = 386
set osd_power_pos = 47
set osd_air_speed_pos = 163
set osd_ontime_flytime_pos = 2455
set osd_rtc_time_pos = 407
set osd_messages_pos = 2530
set osd_gps_hdop_pos = 320
set osd_main_cell_voltage_pos = 44
set osd_throttle_auto_thr_pos = 70
set osd_heading_graph_pos = 82
set osd_efficiency_pos = 161
set i2c_speed = 400KHZ
set debug_mode = NONE
set acc_task_frequency = 500
set attitude_task_frequency = 250
set async_mode = NONE
set throttle_tilt_comp_str = 0
set input_filtering_mode = OFF
set mode_range_logic_operator = OR
set stats = OFF
set stats_total_time = 0
set stats_total_dist = 0
set tz_offset = 0
# profile
profile 1
set mc_p_pitch = 40
set mc_i_pitch = 30
set mc_d_pitch = 23
set mc_p_roll = 40
set mc_i_roll = 30
set mc_d_roll = 23
set mc_p_yaw = 85
set mc_i_yaw = 45
set mc_d_yaw = 0
set mc_p_level = 20
set mc_i_level = 15
set mc_d_level = 75
set fw_p_pitch = 20
set fw_i_pitch = 25
set fw_ff_pitch = 3
set fw_p_roll = 30
set fw_i_roll = 25
set fw_ff_roll = 3
set fw_p_yaw = 0
set fw_i_yaw = 0
set fw_ff_yaw = 0
set fw_p_level = 10
set fw_i_level = 15
set fw_d_level = 75
set max_angle_inclination_rll = 550
set max_angle_inclination_pit = 400
set dterm_lpf_hz = 40
set yaw_lpf_hz = 30
set dterm_setpoint_weight = 0.000
set fw_iterm_throw_limit = 165
set fw_reference_airspeed = 1000.000
set fw_turn_assist_yaw_gain = 1.000
set dterm_notch_hz = 0
set dterm_notch_cutoff = 1
set pidsum_limit = 500
set yaw_p_limit = 300
set iterm_ignore_threshold = 200
set yaw_iterm_ignore_threshold = 50
set rate_accel_limit_roll_pitch = 0
set rate_accel_limit_yaw = 10000
set heading_hold_rate_limit = 90
set nav_mc_pos_z_p = 50
set nav_mc_pos_z_i = 0
set nav_mc_pos_z_d = 0
set nav_mc_vel_z_p = 100
set nav_mc_vel_z_i = 50
set nav_mc_vel_z_d = 10
set nav_mc_pos_xy_p = 65
set nav_mc_pos_xy_i = 120
set nav_mc_pos_xy_d = 10
set nav_mc_vel_xy_p = 180
set nav_mc_vel_xy_i = 15
set nav_mc_vel_xy_d = 100
set nav_fw_pos_z_p = 50
set nav_fw_pos_z_i = 0
set nav_fw_pos_z_d = 0
set nav_fw_pos_xy_p = 75
set nav_fw_pos_xy_i = 5
set nav_fw_pos_xy_d = 8
set rc_expo = 70
set rc_yaw_expo = 20
set thr_mid = 50
set thr_expo = 0
set roll_rate = 55
set pitch_rate = 55
set yaw_rate = 20
set tpa_rate = 33
set tpa_breakpoint = 1300
сообщайте о различиях,ну и … как увеличить скорость возврата и не включается у меня режим удержания высоты…
Sem-EX:
это ?
Sem-EX:
или это ?
OK-40
сходу особых отличий не нашел, моя версия ныряний из-за работы газа при удержании высоты не нашла своего подтверждения, будем думать дальше
Sem-EX:
скорость возврата
не нашел еще? настраивается в конфигураторе, вкладка там есть с настройками “advanced tuning” (настройки вверху слева в сантиметрах)
Sem-EX
извиняюсь за мой тупизм,но…какое именно значение надо менять ?
в чем отличие 2 верхних скоростей ?
300 см/сек получается 10 км/ч…у меня летит 30…
и что меняет самая верхняя графа ,то Altitude,то Cruiz…
про ныряния. А у вас в режиме энжел аппарат летит ровно ? помню ты говорил что элевоны у тебя вверх немного отклонены…может ныряния это борьба стабилизации с элевонами ?
просто у меня для норм полета один элевон явно вниз,другой явно вверх …
Sem-EX
где то нашел -
“3 марта в Торжке пройдет Фестиваль волшебных шаров.
В 19:00 на площади перед Городским Домом культуры начнется самое романтичное шоу марта: сотни волшебных шаров в руках гостей в один миг засияют теплотой сердец, окунув каждого в атмосферу сказки.
В это время на сцене фестиваля представят огненно-пиротехническое представление от мастеров огня, наполненное сложными трюками и пиротехникой.
Вход свободный.”
Мож нас там не хватает ? )
Перед ГДК есть площадь ?
Фестиваль ?
Мих,не ты там мутишь ? Или змеи это другой фестиваль?
Организаторы просто не в курсе как пара полтарашек пива в руках гостей может наполнить их “фестиваль” сложными трюками …))
*шутка
Маус
Sem-EX:
Нет, к этому отношения не имею.
А вот со змеями наша затея. Просто инициативная группа Торжка (Новый Торжок) которая занимается всяческими проектами в Торжке и продвижением города искала предложения и идеи. Я им предложил в качестве интересного события провести в Торжке мероприятие с воздушными змеями. Дальше если дело пойдёт и народ заинтересуется, можно делать такое мероприятие каждый год, организовать ежегодный фестиваль. Так что если есть желание, присоединяйтесь в качестве зрителей или участников. В ВК сделали рабочую группу для обсуждения всех вопросов что да как.
OK-40
Маус:
а какого рожна группа закрытая? чего боимся?
Sem-EX:
организаторам по-бара-барабану, у них другие интересы
в курсе должны быть инвесторы
Sem-EX:
нет
Sem-EX:
для крыла так и должно быть, главное, чтобы в режиме пастру (ручном, который без ПК рулит) крыло ровно летело, а оно летит ровно, и в акро летит ровно и в ангеле, а вот при возврате с небольшой синусоидой по высоте
леха_7000
ДОСОБИРАЛ KESLO НО НЕ РАБОТАЮТ СЕРВЫ И ПИШЕТ
PWM output is disabled. Motors and servos will not work. Use Configuration tab to enable!
Выход ШИМ отключен. Двигатели и сервоприводы не будут работать. Используйте вкладку Конфигурация, чтобы включить!
Б****ЛИН ГДЕ ТАМ
monstrey
Надо кому? А то выкинуть собрался, напряжение 3.7 на каждой
леха_7000
Сер , забиру сыну на машинки аки пофиг какие убивать
Маус
OK-40:
Мы не боимся, группа рабочая поэтому пока решаются организационные вопросы будет закрытой.
OK-40
леха_7000:
ну так включи ПВМ в конфигураторе и будет тебе Щастье 😃
Маус:
зачем создавать группу, когда не решены самые главные вопросы? детсад, блин, в яслях на практике …
леха_7000:
могу, Лёх, показать место, где таких ячеек очень много закопано 😃
Маус
OK-40:
Вот как раз чтоб и решать эти вопросы.
OK-40:
Ага, я тоже так думаю.
OK-40
леха_7000:
ДОСОБИРАЛ KESLO
Лёха, все-таки поэт! KESLO - это звучит гордо!
Sem-EX
Как корабль назовешь так оно и полетит …)
monstrey
В выходные летаем? Планирую и субботу и воскресенье
OK-40
погода только завтра будет, в вск - ветер сильный и снег, так что завтра - и то благоприятный период с 12 по 15
леха_7000
СЕР, В СУББОТУ ПРИЕДУ на полеты ты только позвони во сколько ты будешь и позьми мотор , регуль , и батарейки.
Sem-EX
По " моему" прогнозу(гисметео) в субботу 2 м.сек и небольшой снег , а воскресенье 3 м.сек без снега + солнце.
Меня устраивают оба варианта,буду использовать при возможности по максимуму.
В субботу предлагаю после обеда.
OK-40
Sem-EX:
(гисметео)
гисметео странный сайт, там на различных вкладках на один и тот же день разные прогнозы
я смотрю здесь, более-менее реально www.windguru.cz/362195
