Вопрос по HPI Baja 5t c alibaba
sanya3m
Здравствуйте я нашел на сайте alibaba багу 5т, я написал продавцу что бы он мне отправил характеристики и ее фото.
сказал что она оригинальная. стоимость за две 700$
скажите может ли она столько стоить ?
redbox
Оригинальная, но китайская! Китай столько и стоит
sanya3m
но по фоткам она полностью оригинал. . . .
яя специально просил фотографии
redbox
Выкладывай тут фотки! Китай от оригинала мало чем отличается
sanya3m
Вот он мне написал еще:
Dear Mr Alexander Praviliev
Thank you for your response sir
Yes sir This from the Baja 5T HPI, but we are so sorry sir because according to our company regulation our minimum order 2 units for first order so total payment = US$ 700.
Here we attach photos and features :
Baja 5T Features:
* 2.4GHz Radio Equipment: The Baja 5T comes ready-to-run with a high quality 2.4GHz radio with excellent range, a high torque metal-gear steering servo, failsafe equipped receiver, throttle servo and a rechargeable Ni-MH receiver battery pack. The critical electronics are enclosed in a water resistant compartment to shield them from the elements.
* Baja 5T-1 Truck Body: Tough 2mm polycarbonate Baja 5T-1 desert truck body. Pre-painted, pre-trimmed with body post holes, pre-applied racing decals and clear tinted windows.
* Truck Body Mounts: Tough nylon construction and 8 mounting points keep the truck body securely mounted, fully adjustable design for compatibility.
* Molded Rear Spoiler: Molded nylon rear spoiler for stable handling. Molded nylon rear body brace for body protection, includes provisions for optional rear LED tail lights.
* Fuelie 26 Engine (26cc): 26cc engine for more power, more torque, and more speed than 23cc engines. Equipped with a convenient pullstarter for quick and easy starting. A high capacity dual-element air filter keeps the engine running clean even in grueling off-road conditions, quick-change design for easy maintenance. Air cooled with built-in fan for consistent running temperatures. Fully adjustable carburetor with primer and kill switch. Now constructed using Torx screws for extra durability and easier maintenance, Torx T-27 wrench included.
* Gasoline Powered: Gasoline powered for low-cost operation compared to nitro fuel, easier to tune and more consistent than nitro engines. More than 30 minutes of run-time per tank.
* Ready-to-Run: The Baja 5T comes pre-built from the factory to precise build tolerances. Normal build-time for a vehicle like the Baja 5T is around 8 hours, but you can hit the track in just a few minutes, reassured by the knowledge that your truck was prepared by trained assembly specialists.
* Aluminum Alloy Diff Case: For increased drivetrain durability and extended time between maintenance.
* VVC/HD Shock Set: Oil-filled coilover shock set with large diameter shock shafts for increased durability, 16 hole rear piston with sealing ring for consistent damping, fully adjustable design for tuning options.
* Front Skid Plate Bumper: Adjustable skid plate front bumper protects the truck on big jumps, now with 4 headlights for realistic Trophy Truck looks.
* Dirt Guards: New side guards deflect dirt and debris away from the chassis. The engine also receives dirt guards on both sides for extra protection.
* Extended Roll Cage: Extra bracing for durability, extended upper roll cage for spark plug protection.
* Outlaw Truck Wheels: 8-hole design, tough nylon construction, authentic bead-locks for durability and tuning options.
* Desert Buster Tires: Large diameter truck tires for realistic looks. Heavy duty rubber compound and thicker carcass for extra durability.
* Heavy Duty Inner Foam: Special heavy duty rear inner foam inserts for extra durability and extended tire life.
* Truck Gearing: 19T transmission top gear adapts the drive ratio for quick acceleration and high top speed when using truck tires.
* High Flow Muffler: Large capacity design, tuned for increased horsepower.
* Metal Gear Steering Servo: Tough metal final gears for extra durability and reliable steering. Ball bearing equipped and water resistant. This oversized steering servo has high torque specs, making it a perfect match for the Baja 5T.
* Heavy Duty Beadlocks: Reinforced design increases durability of the wheels and tires. Beadlocks allow the removal and replacement of individual parts of the wheels and tires for maintenance.
* 8000 RPM Clutch: Lightweight clutch and heavy duty spring launches the Baja 5T at higher RPM for more punch off the line.
* Anodized Aluminum Parts: Black anodized 4mm 6061-T6 aircraft grade extruded and CNC milled chassis, orange and gunmetal anodized alloy parts give the Baja 5T an aggressive look.
* Double Wishbone Suspension: Full double wishbone front and rear suspension to soak up off-road bumps and jumps. Consistent geometry throughout the full stroke of the suspension movement for precise handling.
* Adjustable Suspension: Turnbuckles for quick and easy adjustment of toe-in. Fully adjustable camber and caster for tuning the handling to a wide variety of conditions. High quality nylon is used throughout the suspension for protection from crash damage.
* All-Metal Transmission Gears: All-metal transmission gears for incredible drivetrain durability, even in difficult off-road conditions with powerful engines like the Fuelie 26.
* Full Ball Bearings: 23 precision metal ball bearings for efficiency, durability, and extended maintenance intervals.
* Front & Rear Sway Bars: Sway bars are used on the front and rear suspension for precise handling and stable steering feel.
* Modified Rear Shock Tower Brace: Relocates shocks for increased rear suspension travel for stable performance on rough surfaces and soft landings over jumps.
* Heavy Duty Rear Dogbones: Metal construction with rubber dirt boots for extra durability with high horsepower engines like the Fuelie 26.
* Disc Brake System: Braking is controlled by a vented steel/aluminum hybrid brake rotor and semi-metallic brake pads for smooth and consistent stopping power.
Includes:
* Pre-Assembled 1/5th scale 2WD truck w/Fuelie 26cc gasoline engine
* 2.4GHz Spread Spectrum radio system
* 3300mAh receiver pack
* Painted body
* Comprehensive instruction manual
* HPI RC Cars DVD
redbox
Что-то не верится 2 штуки за 700%, оригинал столько не стоит! Лучше брать в проверенных магазинах. Продавец в каком городе сам?
redbox
Значит это китайская баджа и гонет он про оригинал
sanya3m
спасибо за советы. подумаю тогда еще.
LordVipeR
Мне кажется не две за 700уе, а минимальный заказ 2шт, каждая по 700. Даже 5б там дешевле 400 без доставки не попадается
YvO
Да, 700 за 2-е 5Т не может стоить по-любому. Ну и по-любому оригиналов на алибабе не продают))
Rasmus
Оригинальную баджу тоже в китае делают 😃 Но на алибае есть щанс получить китайские китайские баджи 😃))))))
LordVipeR
Ну, судя по форуму, Рованы и Кинг Моторы ездят не меньше тех, что с наклейкой HPI.
З.Ы. я после покупки квадра CF Moto кардинально изменил мнение о китайской технике.
Soul_Train
LordVipeR:
Согласен. 700 за 2 шибко дешево. Кидаловом попахивает!
LordVipeR
sanya3m:
Не прочитал перед своим первым постом…
Речь как раз про 700 за пару. Скорее всего кидалово, либо недостающая до средне-рыночной сумма будет включена в сумму доставки, как часто и происходит.
aleksandrk79
Заказал недавно 5T. 798 баков с доставкой.Жду
😵 надеюсь дойдет
9 days later
stuff
Я заказывал с алиэкспресс Баху 5b, дошла до меня. Китайцы не доложили винтов в днище и в качалку рулевой сервы.
Чуть позже мне удалось их развести на новый двигатель 26сс бесплатно! Открыл диспутв Палке, сказал, что мой сам по себе заклинил после 8ого бака
и они отправили мне новый, также доложив нехватающих винтов, колокол сцепления, пиньон, спур!
Двигатель теперь висит на барахолке, а Баха уже радует нового владельца.
Soul_Train
stuff:
Вот так делать не надо и уж тем более потом писать об этом на всё СНГ. А то умных - то у нас много! В итоге они ваще нихрена к нам слать не будут!
YvO
Soul_Train:
Эт точно
