Караул! Алула не летит!
Cherkashin
ДАК:
Звякнул я туточки одному иностранцу- владельцу оригинальой Алулы- говорит- нет в его модели крутки…
Ну на нет и суда нет!! Где ты раньше был??? Ладно проехали…
gennady
Online Building Instructions Index
  1. Setting Control Throws
  2. Below are the suggested control throws. These rates are a good place to start; however, feel free to adjust the throws to match your flying style once you the glider properly balanced and trimmed.
Elevator: 4-5mm total movement
Aileron: 10-12mm total movement
  1. Balancing Glider
  2. Balancing the Alula is a fine tuning process. Small, lightweight, flying wings are inherently very sensitive to CG (center of gravity) location. Being off by 1mm can make a large difference in how the glider will perform. Before flying, we recommend balancing the glider on a balancing stand made of two sharpened dowels or pencils spaced about 2-3 inches apart. We have designed the Alula so that very little or no nose weight will be required for balance using the suggested radio equipment.
Make sure to set the points of the balance stand directly at the CG location designated on the plans. This location is 25 mm (plus or minus 1mm) behind the leading edge of the wing, at the pod/wing junction. The glider should sit level on the dowels when balanced at this location. Add nose weight if necessary. Again, you will have to test fly the glider to verify the precise CG location, and as a result you may have to add or remove very small amounts of weight to fine tune the balance position. The above procedure will give you a good place to start, and most importantly, the Alula will fly with the CG at this position; however, a bit of fine tuning may be necessary to get the best performance.
  1. Flying, Finally!
Well, its time! Pick a nice flat and open area, preferably grassy, to test fly your new Alula. Make sure everything is functioning correctly and gently toss the glider into the wind. We strongly recommend starting with simple javelin-style launches (overhand), until you get the glider properly trimmed and balanced and accustomed to flying it. Make trim adjustments until a nice flat glide is achieved. Once you have achieved this, you can progressively try harder launches and eventually side arm launches. Always launch into the wind; your launches will be higher and less effort will be required.
When proper trim and balance is achieved, the glider should track almost straight through when in a dive. It should not exhibit the tendency to tuck under in a dive when down elevator is given. If the glider has the tendency to nose up strongly as airspeed in increased, the glider is most likely nose heavy.
A Few Notes on Side Arm Launching the Alula
While side arm launching the Alula, grasp the wingtip at the spar, with your thumb on top and index finger on bottom. Never snap your wrist while launching, as this will cause the glider to yaw excessively after launch, thus decreasing the height of the launch. Try to pinch the wingtip to prevent the glider from pivoting between your fingers, and always keep your arm straight and fully extended during the entire launch. If you are having trouble launching this way, one trick is to release the glider a little sooner than you usually do. Often people release too late, and this results in the glider being launched oblique to the wind direction. This results in an ugly, yawing climb after launch.
Happy flying!
111
“только у меня 2006”
то же
это обновленный файл с 3 вариантами расширения профиля
HN_1038.zip
ДАК
Cherkashin:
Позжее почту глянь- сладкое на ночь отправлю. Правда более 3метров будет. Пройдёт?
Dendy
flysnake:
О крутке… При такой маленькой КОС эффект от крутки существенно меньше “весит” в продольной устойчивости, чем эффект элевонов. Очень приблизительно: плечо от эффекта крутки - 50мм, а плечо элевонов - 100мм.
Золотые слова! При минимальном отклонении элевонов в ту или иную сторону, от нашей хваленой S-образности и крутки не остается и следа… А крутка боюсь недостаточна у нашего варианта Аулы… Попробуем отрезать концевые участки элевонов, и использовать их для увеличения/уменьшения крутки крыла.
Cherkashin
Dendy:
Блин!! Чёйто мне профиль не нравится… посмотрю как Баклан с ним полетит и попробую применить аэродинамическую крутку ( к консолям сгоню на NASA 009) Я на одной так делал но потолочка не тот материал на котором можно так изголяться посему крылья получились немного разными…
S мож и хорошо только вот при сравнении полёта Баклана и Торо… При порывах Баклана притормаживает немного сильнее… 😦 .
gvv7302
По моим расчетам при 10% запасе устойчивости цт тяжести должен находится на кромке крыла см. черт. Сам Алулу заложил но до конца ее не доделал 😦 😃
Lazy
Dendy:
Отклонения элевонов, даже если он 25% хорды, не особо сильно повлияют на S-образность 😃 Она ведь выражается не только подгибом хвостика…И опять таки, S-образность влияет только на продольную устойчивость. А уж связи между круткой и элевонами - так уж точно нет никакой.
Ещё раз повторю - для Алулы крутка не нужна даже вредна.
Cherkashin
gvv7302:
Ага попался!!! Ну как справы?? Попинай там Дака немного…
Блин эт получается крутка не нужна??? плёхо…
Кинь мне прогу для энтих прекрасных картинок ( ну или ссылку на крайняк)
А прикинь ка что получается у Баклана с круткой -5 и без оной??? интересно глянуть…
ДАК
Ну не надо говорить о том, что потолочка сильно отличается по пластичности от бальзы! Просто надо брать в листах 3ммпотолочку- она сделана под дерево или в длиных пластинах такого же типа- она ещё тоньше. Форму по нервюрам держит просто здорово. Очень точно.
Cherkashin
ДАК:
Всё замечательно только вот одна проблема нету у нас 3мм.
А посему сделал резак и не парюсь … 😉 .
И иде обещанная вкуснятина…
gvv7302
Вчера наконец-то доделал свое «летающее крыло». Люблю я чистые летающие крылья без хвостов и фюзеляжей! 😁 Размах1200мм, масса была 200 после коррекции центровки 264, нагрузка на крыло 14-15гр/кв.дм. профиль какой попало плоско выпуклый толщина 10-12%.
Вначале испытывал крыло дома, отцентрировал, дома неплохо летало. Вышел на улицу пускаю не летит 😃 , то петлю делает, то носом ныряет 😕 . Пошел домой убитый горем…. Сел посчитал центровку…. И прицепить пришлось 64 гр свинца в нос!!! 😃
Вчера закончил доработку, дома модель летать перестала, вышел на улицу швырнул….летит да еще как!!! Летит почти без снижения (как показалось) скорость полета возросла. Радости не было конца!!! 😃
Планеритесь таварищи!!!
ДАК
gvv7302:
Поздравления!!!
Это лишний раз доказывает- глаза боятся, а руки делают. Ну это я в смысле “думающих руками”.
Cherkashin
gvv7302:
От ведь змей 😈 Мы тут корячимся блин сотки, проценты, градусы ловим а он бах… 😃
Cherkashin
Ну вот доделал наконец то Баклана-Д
За исключением стреловидности Алула покойница… один в один… ну типа чтоб было легче сравнивать… 😈 Приёмник всёж дал дуба посему ежели не успею починить к воскресенью - полетать не удастся 😦 Но ничего у меня есть чем заняться - LAZY заканчивать буду… Блин связался с копией чувствую попъёт она мне кровушки.
MUH
2 gvv7302
Опа! Модель СОВСЕМ без вертикального оперения!
Большое поперечное V ?
Как вы ее забрасываете?
Очень интересно как она себя ведет в воздухе?
И в сильный ветер?
ДАК
Cherkashin:
Ну всегол лишь махонькое отличие- КОС, не КОС…
Cherkashin
ДАК:
Ага Борька Моисеев издали тож мужик!!!
Приёмник пока поднять не удалось… но вчера вечером не выдержал покидал с руки… Блин летит зараза!!! И довольно далеко… На всяк случай с помощью фена и утюга уменьшил крутку до - 2град… Лонжерон то не поставил - во какой я предусмотрительный!!! Сижу - чешу репу - а нах ваще крутка на крыле с малой стреловидностью и S образным профилем ??? Получается что не нужна . Небольшой прирост устойчивости и резкое падение качества… А вот профиль Е184 мне чегось не нравится… Надо пошакалить что нить получше…
111
для планера ЛК мне кажется интересными такие профили:
AG09; S4083; NA23009 Mod. - все с отклоненным хвостиком вверх примерно на 5 гр. в диапазоне от 30000 и до 100000 Re.
Кто какие еще предложит?
ДАК
Cherkashin:
Сегодня нашёл на буржуинском сайте, что на Алулу ряд самоделов ставит профили типа HS55, HS2.0/8.0, HS3.0/8.0 и HS51 3.0/8.0
Верусь домой и вышлю фото МОТОРНОЙ АЛУЛЫ!
Cherkashin
ДАК:
Блин!!! Ну сколько можно обещать??? 😈
Вышли хоть что-то 😕
Cherkashin
Значится так Баклан - Д поднялся в воздух…
Душераздирающее зрелище!!!
Летит немного лучше покойницы Алулы. Забрасывается правда немного пониже, но всё равно при любых центровках опускает нос , набирает скорость а уж потом спохватывается что мотора -то нету а лететь надо!!! Вариантов ответа на вопрос - а чё не летит - два. Первый - чрезмерная крутка консолей нафиг не нужная для планера… Второй - поганый профиль (Е-184). Сегодня сдеру с него скотч и постараюсь раскрутить в 0… Блин с каждым разом всё интереснее… Ну а уж потом будем долбасить профиль… но уже на Алуле…
Basilio
Cherkashin:
Летит немного лучше покойницы Алулы. Забрасывается правда немного пониже…
Господин Черкашин!
А Вы на Павловом поле живете?
Если не ошибаюсь, это спортивный комплекс на Отакра Яроша?
А обычно где летаете?
Cherkashin
Basilio:
Господин Черкашин!
Вы правы… Павлово поле
Обычно летаем либо на черкасской лозовой либо на окружной на Алексеевке.
Поляну на Сосновой горке начали застраивать … во облом-то…
gvv7302
Хочу, поделится впечатлениями. На выходных прошел торой этап испытаний- «летающего крыла без хвоста»- включающий в себя пуски с горки с высоты 3 метра, броски за крыло ☕ .
Первые броски порадовали слишком передней центровкой 😛 , с большим удовольствием отпилил 25гр. груза в носу планера. Вес планера стал 240гр. вместо 265гр. Все-таки запас устойчивости 10% много для «средне ветреной погоды».
После смешения центровки планер с пяти метров высоты пролетал половину футбольного поля метров 50 если рули не дергать. Качество планера получается Сy/Cx=10ед 😃 . Не много конечно но для первого планера достаточно 😃 .
А вот управление полная лажа 😕 - необходимо переделывать, или настроить. Напрашивается на концах крыла отдельно поставить две рулевые машинки с тормозами для разворотов планера. Ибо при отклонении элеронов планер очень много высоты теряет, на поворотах…. 😊 . Теперь я понимаю почему некоторые дядьки на Алуле элероны и рули высоты разделяют.
А вот броски за крыло вообще не получились модель на бочку бочком идет, толи опыта мало 😃 толи настройки неправильные, одним словом работать еще и работать над моделью……
