Подскажите кто-нибудь, как настроить фейл-сейф в моём комплекте Модуль DM9, приёмник AR9000 . Поиск не помог…
Programming SmartSafe
(All Spektrum Aircraft Receivers)
During the binding process (see page 17), the bind plug is left in throughout the process and is removed only after the receiver connects to the transmitter. After the connection is made, confirmed by operating the servos, the bind plug can be removed. The receiver is now programmed for SmartSafe.
Programming Preset Fail-safe (AR 9000 SPM Receivers Only)
During the binding process the bind plug is inserted in the bind port or in the charge jack (as shown on page 17), then the receiver is powered up. The LED’s
in each receiver should blink, indicating that the receiver is in bind mode.
_Now __before binding the receiver to the transmitter and with the receiver in __bind mode, remove the bind plug. _
The LED’s will still be blinking. With the control sticks and switches in the desired fail-safe positions, bind the transmitter to the receiver by pressing and holding the bind buttons on the back of the transmitter/module and turning on the transmitter. The system should connect in less than 15 seconds. The receiver is now programmed for preset fail-safe.
Note: Fail-safe positions are stored via the stick and switch positions on the transmitter during binding.
Вроде так.
Спасибо! Буду пробовать.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"42dc0bcc3df9550077790040":{"_id":"42dc0bcc3df9550077790040","hid":8239,"name":"PigTail","nick":"PigTail","avatar_id":null,"css":""},"44ca77103df9550077789cf1":{"_id":"44ca77103df9550077789cf1","hid":15771,"name":"ugh","nick":"ugh","avatar_id":null,"css":""},"4b34a95a3df9550077766900":{"_id":"4b34a95a3df9550077766900","hid":58481,"name":"sptry","nick":"sptry","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50a8","hid":4,"title":"Аппаратура радиоуправления","parent":"61c9a54c3df9550077bb50fc","description":"Приёмники и передатчики для радиоуправляемых моделей.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":9176,"post_count":222134,"last_post":"68cbcb5c44153b386535954f","last_topic":"689edf25eede43b1c460b197","last_topic_hid":572627,"last_topic_title":"Сваливание на крыло при автостарте.","last_ts":"2025-09-18T09:05:32.068Z","last_user":"5ede3f823df95500776f51bb"}},"topic":{"_id":"4ae964723df95500778db743","hid":161523,"title":"купил -- spektrum dsm2 module","views_count":7380,"last_post_counter":103,"cache":{"post_count":103,"first_post":"4ae964723df95500778dc346","first_ts":"2009-10-29T09:46:26.000Z","first_user":"49591e353df9550077774213","last_post":"4c7632d63df95500778dc412","last_post_hid":103,"last_ts":"2010-08-26T09:24:38.000Z","last_user":"4b34a95a3df9550077766900"},"st":1,"section":"61c9a54c3df9550077bb50a8"},"subscription":null,"pagination":{"total":103,"per_page":25,"chunk_offset":100},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
