Spektrum DX8 - счупаем , изучаем , летаем !
Spectrum и Spektrum В чём разница?
где Вы видели Spectrum?
Иногда так пишут, и внизу пульта под экраном есть такая надпись)
точно
Spe k trum - название торговой марки
Spread Spectrum - метод передачи сигнала.
Новая версия прошивки
Version 3.01
2014 Feb 19
Software Features
• Enabled support for LiIon transmitter battery as an option on the System
Settings screen.
• Enabled support for V-Tail B (electronically swapped ruddervator servos)
• Added access to the System menu directly from the Function menu.
• Added the ability to reverse Flap System controls for analog-style inputs
(Knob, Left and Right Trimmers)
• Updated telemetry to include the GPS Distance calculation found in our
higher radios.
• GPS supports a “home” altitude. This cannot be used to generate an alarm at
this time, but it does make it easier to understand altitude above ground level.
At the GPS status screen, press CLEAR to set the altitude to 0. This will also
set the “home” position for the Distance calculation.
• Telemetry “Settings” menu has new option to auto-populate the list of sensors
reporting from the model at the current time.
• Telemetry filename now defaults to the model name. It is NOT retained
through a power-cycle or when changing the model.
• Hidden Apple Mac files and directories are not listed in the SD menu screens.
• The telemetry menu has been added to the Function list.
• The Spektrum Vario Sensor SPM9589 may be used to report altitude data.
The radio does NOT support the vario functionality, only the altitude reported
by the vario sensor.
• Sailplane mode supports the trainer button as a Flight Mode switch option.
Software Corrections
• In Sailplane mode, the camber system now properly supports a smooth trim
change on elevator between different flight modes.
Приветствую всех этой ветки форума.
Суть вопроса у меня такая: столкнулся с проблемой потери сигнала этого передатчика примерно на расстоянии 150-250м, причём на разных приёмниках один AR6210, а второй AR600. Оба установлены на авиамоделях. Передатчик у меня EU версии, причём при уходе в морковку с высоты сигнал даже не пытается восстановиться. Кто сталкивался с такой проблемой, что можете посоветовать.
Было такое у меня . Менял антену в передатчике . мне помогло .
Я для всех своих передатчиков сделал вот такие антенны.Зона покрытия на DX8 600м и механически очень прочная.
Сегодня с ребятами на нашей ВПП сделали тест на дальность, при рендж тесте как и положено вышло метров 30-40, тесты на дальность показали примерно метров 250-300, при том что я находился под высоковольтными проводами, но на таком расстоянии индикатор на приёмнике начинал периодично мигать. Просто где свалился у меня второй самуль, ребята говорят что и на Футабе у кого то тоже там падал. А антена от Wi-Fi подойдёт я так думаю?
Так вроде бы, изначально, там один проводок. Для чего разветвление? Или что-то дорабатывали. Пожалуста, можно подробнее или схемки.
С уважением, Игорь.
Я подготовлю и напишу здесь небольшой тренинг в понятном изложении.Это “топографическая” антенна.Пожалуйста,не спрашивайте меня,как программно задавать параметры трансивера,здесь это запрещено правилами форума.
… Пожалуйста,не спрашивайте меня,как программно задавать параметры трансивера,здесь это запрещено правилами форума.
Ну вот обнадежили и расстроили … 😦. А я уже собрался покупать детальки. Хоть намекните, куда и какие проводки паять (это-то точно можно) и где почитать, все равно уже попали под колпак спецслужб. 😉
С уважением, Игорь.
Вы противовес приляпали ? Анализатором спектра проверяли ? Напряженность поля и направленность как изменились ?
Спасибо,мой тренинг отменяется.
Кому интересно ? Ищем \ диполь 2,4ггц \ готовые антенны есть 9дцб усиление , есть узконаправленные . Есть такая фишка -
2W бустер 2.4Ghz для увеличения дальности управления. В соседний город за пивом слетать получится .1w 2.4G booster
1w 2.4G booster
1 890 руб.
Бустер на 2.4G
Блин, мужики, ну не прикалывайтесь над старым “чайником”. 😃 Я ж кроме 27 МГц приемников-передатчиков и 40 МГц приемников, когда дифицит был, ничего не собирал, дипольные антены не делал, поскольку образование не то.
Поискал по указанному направлению - выдает готовые антенки совсем не похожие на приведенные выше фото.
И, если правильно понял намеки, что это не секрет, то лучше бы нарисовали или описали поподробнее, а уж руками бог не сильно не обидел. Можно в личку.
С уважением, Игорь.
Игорь,я никогда не прикалываюсь над человеком который просит совета.Я отрицаю когда в диалог вступают безграмотные показушники приляпоспектроанализаторщики.Пишите мне в “личные сообщения”.
А что так косвенно ? Если на элементарные вопросы не ответить зачем хамить уважаемый конструктор на 2,4 ГГЦ ? И пока не будет фото передатчика рядом с высокочастотными приборами эта антенна от винтика и шпунтика , с неизвестным побочным излучением .
Алексей,спасибо,троллинг рулит.
Ой,сейчас “забанят”.
Нужно в Camber System настроить отрицательные значения для элеронов. И вместо изгиба крыла у вас будет бабочка, закрылки вниз и элероны вверх.
Прошу прощения за некомпетентность, а как войти в режим Camber System?
Нашел этот режим в плпнерной программе, но я задавал ворос по мотопланеру, поскольку даже в посоедней прошивке dx8 в планерной программе не поддерживает мотор. По крайней мере у меня не получилось мотор настроить на стик газа…
Функция Motor в теории должна настраиваться в Wing Type, и может управляться полетными режимами.
В Wing Type функция Мотора назначается на выключатели, при этом на мониторе в последующем движение стика газа не отображаются, а только значек выключателя, назначенный на мотор перемещается на экране от - 100 до + 100. Правда это я пробую только с пультом, без подключения электромоторчика.
так и будет, что щёлкнул тумблер и мотор на всю катушку включиться,
хотя я делал так, что при выборе полётного режима(три позиции на FLAP) устанавливал на LAND активный газ.
Я на F-mode назначил три полетных режима Thermal Cruise и Launch, но мотор все равно не оживает, ни плавно ни на всю катушку…
