забиндил, работает, телеметрия идет, но модуль XJT постоянно пищит.
как понять, что ему нужно?
уже просто готов выломать пищалку.
Самое смешное, что подобное уже было, но тогда на приемнике было питание 3.7в
сразу померил - 4.75
как диагностировать?
Это может быть проблема с антенной модуля, сломана или нет контакта.
Constant Beeps: Detect the module antenna’s working status and give sound warnings if the module antenna is broken or does not have intact contact, etc.
Number Beep Alarming Meaning
0 No Beep The signal strength is strong
1 Single Beep The signal strength is adequate
2 Constant double Beeps The model is far, but safe range
3 Constant triple Beeps The model in near maximum range
Constant Beeps The module antenna is broken, or does not have intact contact, etc.
так она пищит именно на этот приемник.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"431fca353df955007778f4ae":{"_id":"431fca353df955007778f4ae","hid":9031,"name":"VladislavVY","nick":"VladislavVY","avatar_id":null,"css":""},"5963e0023df9550077705137":{"_id":"5963e0023df9550077705137","hid":292274,"name":"tuskan","nick":"tuskan","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50a8","hid":4,"title":"Аппаратура радиоуправления","parent":"61c9a54c3df9550077bb50fc","description":"Приёмники и передатчики для радиоуправляемых моделей.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":9176,"post_count":222136,"last_post":"6aa2d5dab4761b70be47921b","last_topic":"58ff3b0f3df9550077d3f71a","last_topic_hid":494687,"last_topic_title":"Jeti Duplex DC-16, DS-16, DS-14 руководство по эксплуатации на русском","last_ts":"2026-09-10T16:07:54.304Z","last_user":"5beb0d533df95500776fba2b"}},"topic":{"_id":"5d02954f3df9550077c3804a","hid":542938,"title":"О чем пищит XJT?","views_count":985,"last_post_counter":3,"cache":{"post_count":3,"first_post":"5d02954f3df9550077c38310","first_ts":"2019-06-13T18:26:23.000Z","first_user":"5963e0023df9550077705137","last_post":"5d0352b23df9550077c38314","last_post_hid":3,"last_ts":"2019-06-14T07:54:26.000Z","last_user":"5963e0023df9550077705137"},"st":1,"section":"61c9a54c3df9550077bb50a8"},"subscription":null,"pagination":{"total":3,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
