walkera 4g6
там новый приёмник (RX-2609S) с трехосевым гиро оО Что-то нигде не слышал, кроме как тестов приемника от wowhobbies…
Эх, появилось б на полтора месяца раньше… 😃
В начале месяца успел купить 4г6 в бюджетном варианте (с вк2602) и старым (без S) приемником. Интересно, что дает 3-осевая гира, верт полностью застабилизирован?
А вот, на хелипале тоже продается, с описанием (переводить не буду, в целом понятно и так):
New Era in Micro RC Helicopter - 4G6S with Auto Stabilizing Technology (AST)
A breakthrough in Micro RC helicopter history! 4G6S is the first Palm Size Helicopter with a 3-Axis Gyro with Auto Stabilizing Technology (AST), and by the meaning of 3-Axis Gyro, it acts like a Co-Pilot for the helicopter, it “helps” you to keep the helicopter’s stability, amazing isn’t it? We field tested the helicopter, it is at least 80% more stable than the previous 4G6, and the 3-Axis Gyro really helps for a micro size helicopter, you will feel like you are flying a 450 class helicopter. Walkera has done it again, two thumbs up for this new technology! The 4G6S also features everything you have on a big helicopter, like three CCPM servos, Brushless Motor and ESC, a 2.4Ghz All-in-One Receiver, a Gyro (3-Axis) and a Rudder Servo, the only difference is the 4G6S is even better, because it has a 3-Axis Gyro which other RC Helicopters usually don’t have.What is 3-Axis Gyro?
3-Axis Gyro means it can sense X, Y and Z axis moments, that means body leaning forward / backward, body rolling left / right, tail drifting CW / CWW, it will constantly monitoring any off-balance in all directions, then it will give signals to all CCPM servos and Rudder servo to balance the helicopter, it works constantly and unless you have the helicopter drifts to much, you will not even notice the system exists, please take a look at the following picture.
Чёрт, если не врут - придётся разориться на новый приёмник, когда появится в продаже…
Narayan
Да, вроде, уже продается: Walkera RX2610S receiver w/3 axis gyro to upgrade Walkera 4G6, Trex450 & 400 compatibles CP 3D helicopters
Хы, вчера вечером ещё не было
Эт чо, теперь всякие хеликомандеры побоку?
удивляет, что трехосевой гироскоп мирно уживается с флайбаром
Да и пусть уживается, зато менять ничего, кроме приёмника, не нужно… Кстати, на ваухоббиес указано, что приемник только в режиме 2601 биндится с вк2801, хмм… То есть чувствительности гироскопов только на нём будут регулироваться, а ещё что пропадёт?
Мда… На rcgroups пишут, что полет возможен только “блинчиком”.
Зато, судя по роликам - круто блинчиком летает… даже в некислый ветер держится)
Вот бы на 4g3 такое.
вчера получил зверька 4г6 на почте. Верт настроен, тарелка параллена.
Но у видел, что растяжки между балкой и задней опорой шасси из верхних (балочных) ушей вытащенны. Пока просто вставил их в отверстия в ушах, вклеить их конечно не сложно, но есть ли в этом смысл, т.к. шасси гораздо более гибки, чем соединение рамы и балки.
Где-то на форуме встречал, что на 4г3 кто-то тоже сталкивался с подобной ситуацией, и вклеил растяжки суперклеем в уши.
вопросы:
- почему они небыли приклеены?
- нужно ли мне их вклеевать или достаточно просто вставить?
Такая же фигня, подкосы болтались (с рц711 приехал). Решил не клеить, оставил как есть, а люфт можно убрать, подвинув хвостовой стабилизатор.
спасибо, клеить не буду.
Кстати, либо полохо искал, либо в форуме никто не смог подключить передатчик валкеры к симу, у меня же всё вышлопросто: купил универсальный симкабель к футабе и ескаю,
www.helipal.com/le-0010-simulator.html
подключил к ПК , откалибровал джостик в системе, потом в ФМС. Всё! ТОЛЬКО один ньюанс: НУЖНО на пульте убрать микширование CCPM, оставить пиктограмму с однойбуквой P.
Я в итоге разобрался с симуляторами без дополнительных проводов, сделал с родным шнурком (моноджек-моноджек) через микрофонный вход - нужно ppjoy, sppconsole (там modulation - PPM (walkera), выключить все миксы (взял свободную пустую модель) - и вуаля 😃 Пробовал с фениксом и реалфлайтом, только аэрофлай почему-то не заработал.
Еще вопрос: как проверить-выполнить настройку потециометров на приемнике?
По поводу симов и 2801про добавлю для полноты картины - работает вменяемо только при настройки тарелки в режим с одной сервой 😃
А пульт 2801pro можно настроить что бы таймер включался когда стик throttle идет вверх и выключался когда он внизу? 😒
Неа, только кнопками
чтобы держать хвост к себе, приходиться двигать рудером. Мне с нулевым начальным опытом это сложновато.
по передатчику 2602 и настройках 4г6 гироскопа ктонидь подскажет?
как настроить? что на что влияет? как на ходу корректировать, без входа в настройки пульта.
Триммерами не пробовали, которые под стиками.
Ну и режим heading hold использовать, попроще летается; как на 2602 включается - не знаю…
уточняю вопрос: каким процентам настройки гиры какой режим соответсвует?
и еще один: что настраивается потециометрами на приемнике, диапазон хода серв и/или центральная точка?
Режим работы гироскопа выбирается переключателем (на 2801про) aux2/gyro: 0 - normal, 1 - heading hold, для каждого из них можно настроить чувствительность гироскопа отдельно; потенциометры на приемнике пока не трогал 😃
диапазон хода серв
Точно - расходы. Второй на сколько помню - микширование хвоста.
Добрый вечер! Вопрос к специалистам:можно ли пульт WK2601 от от Валкеры 4g3 использовать с Валкерой 4#3 вместо её пульта WK2401?
