Он к примеру потяжелее 600XL, потолще, но по высоте, если я правильно понял, ниже.
Там же на сайте можно найти регулятор оборотов на 5,7 КВт!!
Вот полные спеки на данные два мотора:
HK-4035-560(12N10P) dia 1.47
Specifications
Stator Diameter 40 mm(1.56 in)
Stator Thickness 35 mm(1.024 in)
No.of stator Arms 12
No.of stator Poles 10
Motor Wind 8 Turn Delta
Motor Wire 26-Strand 0.29 mm
Motor Kv 560KV RPM/Volt
NO-Load Current(IO/8.4V) 1.74Amps
Motor Resistance(RM) 0.012 Ohms
Max Continuous Current 100 Amps.
Max Continuous Power 4200 Watts
Weight 430 Grams (15.05 oz)
Outside Diameter 48.9 mm (1.9 in)
Shaft Diameter 5.98 mm (0.23 in)
Body Length 58.5mm (2.28 in)
Ovrall Shaft Length 86.3 mm (3.37 in)
HK-4035-500(12N10P) dia 1.27
Specifications
Motor Wind 10 Turn Delta
Motor Wire 26-Strand0.25mm
Motor Kv 500KV RPM/Volt
NO-Load Current(IO/8.4V) 1.9Amps
Motor Resistance(RM) 0.020 Ohms
Max Continuous Current 84 Amps.
Max Continuous Power 3500 Watts
Weight 399 Grams (13.96 oz)
хе, хе, они там регулятор еще на толи на 11 толи на15 киловатт готовили 😃
Скорпионы рулят!!!
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"446370603df955007778b24d":{"_id":"446370603df955007778b24d","hid":14032,"name":"Piranha","nick":"Piranha","avatar_id":null,"css":""},"4781687b3df955007777eacb":{"_id":"4781687b3df955007777eacb","hid":30483,"name":"Nazgul","nick":"Nazgul","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb513b","hid":63,"title":"Электродвигатели, регуляторы, аккумуляторы, зарядники","parent":"61c9a54c3df9550077bb5129","description":"Электрические мотоустановки для вертолётов, системы питания и вся сопутствующая аппаратура.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":1453,"post_count":32180,"last_post":"6af4ba1100fb687e162e719c","last_topic":"5ea889663df9550077bf9661","last_topic_hid":554798,"last_topic_title":"Hyperion EOS 0615i DUO 3 где взять прошивку?","last_ts":"2026-11-11T18:55:13.482Z","last_user":"40f7c0ac3df955007779431e"}},"topic":{"_id":"482eb1423df9550077af7ab1","hid":101002,"title":"Scorpion HK-4035-560","views_count":1766,"last_post_counter":2,"cache":{"post_count":2,"first_post":"482eb1423df9550077af8813","first_ts":"2008-05-17T10:19:46.000Z","first_user":"4781687b3df955007777eacb","last_post":"48309c373df9550077af8815","last_post_hid":2,"last_ts":"2008-05-18T21:14:31.000Z","last_user":"446370603df955007778b24d"},"st":1,"section":"61c9a54c3df9550077bb513b"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
