The output power is adjustable from 10mw (legal anywhere in the world that allows 2.4GHz) up to 100mw of power (U.S. and select other countries only). Power consumption is extremely low.
Data encryption and 64 bit CRC error checking means that invalid data being passed to the servos is virtually impossible.
1024 systems are great. 2048 (Futaba’s 14MZ) is even better. The XtremeLink™ has an unparalleled 65536 (16 bits) system! Future versions of the XtremeLink™ could have enough bandwidth for live video and audio transmissions!
The transmitter module has a port for a remotely mounted telemetry control unit consisting of a large (20 character x 4 lines) trans-reflective and backlit LCD screen with three function buttons.
Up to 256 different sensor modules can be connected and accessed at the same time via the telemetry system.
XtremeLink™ Features:
Range (6 channel receiver)
Up to 500 feet ground based, line of sight.
Up to 1500 feet ground to air, line of sight.
Range (8/10/16 channel receivers)
Up to 1 mile (5200+ feet) ground based, line of sight.
Up to 5 miles (26,000+ feet) ground to air, line of sight.
Frequency
2.4GHz ISM bands, using intelligent frequency hopping.
Spherical RF radiation technology eliminates the need for multiple receiver antennas.
Resolution
1 in 18,446,744,073,709,552,000 chance of being on the same channel as another module (and that’s only if we sold that many systems + 1!)
Up to 120 modules in use simultaneously.
Antenna length
Integrated in 6 channel receiver.
1.2" for receiver, fully enclosed.
5" external transmitter antenna.
Miscellaneous
Individually programmable failsafe for all channels (in event of transmitter battery failure).
Programmable channel mapping.
Bi-directional telemetry data interface.*
FCC, IC, CE/ETSI approved!
Это мультиплекс выпускать собирается? Или уже выпускает? Интересно, сколько это счастье стоить будет?
Дима там же написано XPS
это та штука которую я себе для жиэрки прикупил
Что расскажешь?
P.S.Где ? 😉
Что расскажешь?
P.S.Где ? 😉
Народ я правильно понял что теперь можно докупить этот модуль и мы станем обладателями аппаратуры на 2,4 гГц ?
И да , и нет! С Россией не торгуют…
При большом желании посредники есть.
Слышал… Но! Подождёмссс…
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"425a3e433df95500777914f8":{"_id":"425a3e433df95500777914f8","hid":6851,"name":"Dima=","nick":"Dima=","avatar_id":null,"css":""},"4285a94b3df9550077790ddd":{"_id":"4285a94b3df9550077790ddd","hid":7308,"name":"a-korenev","nick":"a-korenev","avatar_id":null,"css":""},"42dc0bcc3df9550077790040":{"_id":"42dc0bcc3df9550077790040","hid":8239,"name":"PigTail","nick":"PigTail","avatar_id":null,"css":""},"4461b3af3df955007778b32b":{"_id":"4461b3af3df955007778b32b","hid":13991,"name":"SNikolayV","nick":"SNikolayV","avatar_id":null,"css":""},"45250f753df9550077788b7f":{"_id":"45250f753df9550077788b7f","hid":17278,"name":"Andrei_Sss","nick":"Andrei_Sss","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb5141","hid":65,"title":"Аппаратура, гироскопы, гувернеры, электроника","parent":"61c9a54c3df9550077bb5129","description":"Вертолётная аппаратура радиоуправления и бортовая электроника.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":2494,"post_count":58136,"last_post":"697b1496b4761b70bee1ab48","last_topic":"697b1496b4761b70bee1ab47","last_topic_hid":572722,"last_topic_title":"Ищу USB шнурок для fbl helicomand","last_ts":"2026-01-29T08:04:38.920Z","last_user":"4fee0f683df9550077742b04"}},"topic":{"_id":"4753fc503df9550077b6b14b","hid":85021,"title":"Благая весть для владельцев Multiplex ;)","views_count":1892,"last_post_counter":8,"cache":{"post_count":8,"first_post":"4753fc503df9550077b6bdef","first_ts":"2007-12-03T12:53:36.000Z","first_user":"4285a94b3df9550077790ddd","last_post":"4771e98f3df9550077b6bdfd","last_post_hid":8,"last_ts":"2007-12-26T05:41:35.000Z","last_user":"4285a94b3df9550077790ddd"},"st":1,"section":"61c9a54c3df9550077bb5141"},"subscription":null,"pagination":{"total":8,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
