Jeslji interesujet, to mogu vislatj dokumentaciju na boljeje solidnij V-Tail Mixer, kotorij imejet neskoljko rezhimof mikshirovanija.
Input/Output - 2 channels of pulse width modulated information in and out
1500us neutral pulse width, 500us deviation, 20ms frame width. Constructors with a programmer can alter this by simply changing the equates in the program. Persons purchasing prebuilt units or precoded micros can specify variations.
User interface - 6 way dual inline switch.
Mixing ratios - 1 to 8 in eighths, selectable by switch
Mix types - mix into and mix with, selectable by switch
Mixing order - selectable by switch
Reversing - one output channel can be reversed, selectable by switch
Resolution - 1us equivalent to 10 bits over the servo operating range or 11 bits total
Power - 2.5 to 6.5volts at 2mA nominal
Size - 12mm x 17mm
samoje glavnoje, 4to ano rabotajet 😃
Мужики !
Кто ни-ть может помочь с документацией на V-микшер ? Никак не могу зайти на “www.geocities.com/ilufa/MIXER_E.htm”…
У меня вобще на этот домен не получается зайти. Видимо что то у китайцев не так с фильтрацией доменов.
мыло: ustas.asia(собачка)gmail.com
Заранее спасибо !
Shas skinu vsu infu at etogo mixera.😃)
Посмотреть можно. Но для меня важнее вес. Получилось 4 г.
Насчет веса - не проблема… Платку потоньше и SMD компоненты.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"400feedf3df95500777953d5":{"_id":"400feedf3df95500777953d5","hid":2755,"name":"Modris","nick":"Modris","avatar_id":null,"css":""},"4147db903df9550077793b23":{"_id":"4147db903df9550077793b23","hid":4484,"name":"Ustas-Asia","nick":"Ustas-Asia","avatar_id":null,"css":""},"4147ec7f3df9550077793b10":{"_id":"4147ec7f3df9550077793b10","hid":4486,"name":"ReM","nick":"ReM","avatar_id":null,"css":""},"421dcdcf3df9550077792035":{"_id":"421dcdcf3df9550077792035","hid":6184,"name":"bea","nick":"bea","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50ba","hid":8,"title":"Самодельная электроника, компьютерные программы","parent":"61c9a54c3df9550077bb50f3","description":"Софт для моделирования и черчения, самодельные электронные устройства.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":2669,"post_count":48293,"last_post":"6af7454900fb687e16579301","last_topic":"6af3132f44153b3865f8f6da","last_topic_hid":572740,"last_topic_title":"В каком режиме заряжать аккум AMG ?","last_ts":"2026-11-13T17:13:45.153Z","last_user":"4f3e22e13df955007774805c"}},"topic":{"_id":"42aa011c9970730077041367","hid":23908,"title":"V-tail Mixer","views_count":3129,"last_post_counter":8,"cache":{"post_count":8,"first_post":"42aa011c9970730077041aba","first_ts":"2005-06-10T21:07:40.000Z","first_user":"4147ec7f3df9550077793b10","last_post":"42ad87099970730077041ac8","last_post_hid":8,"last_ts":"2005-06-13T13:15:53.000Z","last_user":"4147db903df9550077793b23"},"st":1,"section":"61c9a54c3df9550077bb50ba"},"subscription":null,"pagination":{"total":8,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
