Mobius Mини 27г * 44 Mbps - Шоу маст гоу он
Поступила сегодня в продажу новая мини камера от Мобиуса, весом всего 27 грамм, максимальный битрэйт - 44 Mbps!!!
Примеры фото и видео:
mytempfiles.info/…/Mini Pre-release Sample.mp4
i.imgur.com/IJQxT9r.jpg - Frame grab from largest video with wide lens B
i.imgur.com/undefined.jpg - Largest still image size with narrow Lens A
i.imgur.com/undefined.jpg - Largest still image size with wide Lens B
Basic Functions
· Sync Date/Time with PC
· Date Display: Date Only, Date and Time, Off
· Date Format: YY/MM/DD, MM/DD/YY, DD/MM/YY
· Recording Indicator: ON, OFF
· Rotate Image: 180 deg., NO
· Artificial Light Frequency: 50 Hz, 60 Hz
· TV Video Out Display Mode: NTSC, PAL
· Power-Off Standby: Off, 30 sec.,1 min., 3 Min., 5 Min.
· Auto-Record with External Power: Off, On
. OSD Language: English, Dutch, French, Spanish, Italian
Video Functions
· Audio Sound: On, Off
· Motion detect: On, Off
· Image Stabilization: On, Off
· Loop recording: On, Off
· External Microphone: Enable, Disable
· On Screen Display (OSD - in Video Out Mode Only):
· View/Delete recorded images, change config settings, view system info.
· Two Video Modes - Set Frame Resolution and Frame Rate:
· 1920x1440@30fps, 1920x1080@60/30 fps, 1280x720@ 120/60/30 fps, 848x480@240 fps
· Video Quality (approx. ave. data rate): Normal (16 Mbps), Fine (32 MBps,) Super Fine (44 Mbps)
· Video Clip Length: 1 min., 3 min., 5 min., 10 min., 15 min., Max. (4GB FAT 32 limit)
Photo Functions
· Photo Frame Size: 2688x1512, 2048x1536, 1600x1200, 1920x1080, 1280x960
· Image Quality (JPEG): Normal, Fine, Super Fine (1.8 MB-)
· Time-lapse Photos: Off, 3 sec., 5 sec., 10 sec., 30 sec., 1 min.
· Time-lapse Duration (auto-stop): Unlimited, 5 min., 10 min., 15 min., 20 min. 30 min., 60 min.
· Photo Burst (rapid images): Off, 3 photos, 5 photos, 10 photos
· Shutter Delay: Off, 2 sec. delay, 10 sec. delay, Photo - 3 sec delay - photo
· View OSD: Off, On
Advanced Image Functions
Exposure: -6EV to +6 EV, in 1 EV steps
White Balance: Auto, Daylight, Cloudy, Tungsten, Fluorescent
Metering: Multi, Center weighted, Center Spot
Package included
1X Mobius mini ActionCam
1X Mounting Base
1X USB cable
1 pair Velcro
1 x Mobius TV cable
Продается тут: www.ebay.com/itm/162177778578
Нам не хочет отправлять…Видео оч понравилось…
На банггуде появился за 5800
На Бангуде вроде только 1и2 версии, мини не нашел.
Я заказал с ебея вчера, уже выслали…
Обсуждение на рцгрупс:
Вот на банггуде banggood.com/Mobius-2-ActionCam-1080P-130-Degree-W…
Продавец с ебея в рф не отправляет…
Это 2-ая версия, 45 грам, мини -27г
Добрый день всем. А её можно использовать в качестве курсовой камеры для FPV ?
Вполне. Задержку при записи обещают 60мс
Провод в комплекте.
Вот бы ей нормальный WDR приделали…
А судя по роликам с цветами у двушки получше, или от WDR еще что то хочется? Ну и мини на таком же камне сделана?
Не увидел в примере видео выдающего качества. Примерно как старый Мебиус. А насчет веса - непонятно как он достигнут. Примерно такие же размеры как у старой. Основной вес дает оптика и аккумулятор. Выводы можно сделать.
“Mobius Mini uses a Sunplus chip compared to the Mobius2 uses the HiSilicom chip”
And the CMOS imager in the Mini has some capability the M2 does not as well (e.g. larger resolution and frame rates in some modes).
Я смотрел на большую двушку, или ты Дима, про нее и написал?
Приехала нарядная. Порядочно меньше классического Мобиуса.
Через часик-два сделаю пробное видео.
Здесь будут фото и видео:
drive.google.com/folderview?id=0B0omq8HFiWBQOHlNam…
Снимал как было из коробки. Позже постараюсь снять что то более интереснoе. Завтра может запущю ее полетать.
На мобиускамточкару появился предзаказ на эту камеру. Цена 4300 + 150 р. за доставку по РФ. Я себе заказал. Мужик там серьезный работает, заказы (по крайней мере мои) высылал. Говорит, партия уже таможню прошла.
Стаб вроде пока не работает, обещали починить
Щас проверил. Стаба действительно нет. И битрейт на 1920х1080, 60fps 40078 кбит/с (со звуком 40205)
Там еще баг вчера нашли с переключениями режимов: www.rcgroups.com/forums/showpost.php?p=35708871&po…
А вот и первая плохая новость. Камера не включилась в поле. Вчера дома включалась и записывала. Сегодня, когда крепил к квадрику, случайно нажал кнопку, и она включилась. Я ее выключил. А в поле ноль эмоций. Щас держу в руках кирпичик и думаю, разбираться с ней или во двор швырнуть. Пока без видео… 😦
Писали на рцгрупс что кнопка ресет помогает очухаться, я пока тоже не могу потестить дожди уже неделю, есть мобиус первый линза С и мобиус мини
Спасибо, помогло! 😃
Бросил в полетный ящик несколько зубочисток 😃
Глючная пока прошивка на Мини. Будем ждать улучшений…
Первый мобиус у меня так же завис не так давно на последней прошивке. Не мог выключить, не реагировал на нажатие, но при этом горел красный и жёлтый диод, тоже подсказали друзья что есть reset. Помогло после сброса.
Тестовый видосик в “боевых условиях”. Для оценки качества видео надо скачать.
Картинка мне понравилась. По впечатлениям она лучше, чем на Ранкам 2. Цветовая гамма как у первого мобиуса (что логично). Я поставил баланс белого на ясный день, чтобы он не скакал во время съемки.
Желе. Пока нет режима стабилизации. Площадка под камеру на резиновом амортизаторе, движки сбалансированы. Видимо, это из-за того, что камера очень легкая, а амортизаторы жестковаты. Но даже эти амортизаторы раскачиваются при резких маневрах и рывках, мягче ставить смысла нет. Можно попробовать вообще без виброразвязки, либо через мягкую прокладку. Решит ли стабилизация проблему желе? Наверно решит, но появится размытие. Решением может стать светофильтр. Заодно появятся киношные смазы на длинных выдержках
Блики. Нужна бленда. Форма объектива позволяет ее нацепить. Вот бы производитель камеры (или любой, кому не лень) наладил выпуск светофильтров и бленд
