Eachine VR011 - FPV шлем с Diversity и портом для Pro DVR
ZVER
Очередная новинка от компании Eachine - Eachine VR011 (не реклама)
Из особенностей – разделяемый корпус, система Diversity и порт для установки рекордера Eachine Pro DVR (в комплект не входит).
Спецификация:
Brand name: Eachine
Item name: Eachine VR011 FPV Goggles
Frequency: 5.8GHz 40CH (Raceband)
Screen resolution: 800*480PX
Screen brightness: 500cd/m²
Voltage: 2s battery(7.4-8.4v)
Working current: 350-420mA
Reception sensitivity: -95dBM
Battery: 7.4v 1000mah Lipo battery
Working time: 1.5 hours
Net weight: 370g
Screen weight: 204g
Straaght pole antenna weight: 6.3g
Whole size: 168*172.5*100mm(exclude antenna and antenna holder)
Screen size: 152*69.5*86.5mm(exclude antenna and antenna holder)
Receiver connector: RP-SMA male
Features:
  • Super transformable
    Disassemble the goggle and use it as a monitor,or put it on a tripod
    It can be used as a monitor separately,or put it on a tripod
  • External DVR optional
    Meticulous design,free to choose,simply to operate and worry-free
  • Dual reception
    Real-time transmission,more stable reception
  • Searching method
    This product has accurate searching function and auto-searching
    frequency function to meet customers’ different habits and needs
  • Support video-in and audio-out
  • Display frequency and signal strength
    Real-time display of current working frequency and signal strength
  • OSD shut down
  • 5 inch LCD display
  • Multiple language options
  • External battery,convenient for replacement
  • Support PAL/NTSC switchable
  • Save all settings from power failure
Package included:
1 x Eachine VR011 goggles
2 x Straight pole antenna
1 x Manual
1 x 7.4v 1000mAh Lithium battery
1 x Charger
1 x Audio cable
2 x Clean cloth
ZVER
medved10:
по предзаказу двр в подарок
Так это просто отлично.
dedok
medved10:
Откуда информация?
Линза похоже не двигается?
ZVER
dedok:
Откуда информация?
На сайте магазина в постере.
dedok:
Нет, не двигается, фиксированная.
ZVER
Pelemen:
Он лучше ev800d
Пока нет отзывов. Непонятно.
andrei_p
Кому интересно, высылать с 5 августа начнут. На алиэкспрессе сказали.
Serpent
medved10:
ZVER:
Что то у вас с английским не того… 😉
Возможно использование внешнего ДВР (Can be external DVR) не означает что он идет в подарок.
По крайней мере я нигде не увидел (2017.07.29)
dedok
Serpent:
Очень хорошо, эта писалка качества условного.
Serpent
Да, есть у меня такая, пишет действительно … как бы это помягче сказать. 😮
С другой стороны - техническая писалка и не должна писать красиво, а за её цену хорошо вообще что включается.
Ну а по теме - я не удержался, записал в хотелки, появится - буду брать.
Еще один шлем в шкафу не помеха…
dedok
Маленькая непонятка. Разрешение экрана Screen resolution: 800*480PX и в тоже время поддерживает пал 720х576, значит будет резать часть изображения (с осд).
andrei_p
Serpent:
Они изменили описание. Раньше на бангуде был баннер как на офсайте и там было написано про подарок. На алиэкспрессе тоже уже убрали. Я спросил в личке на али про dvr (23.07), сказали что подарок вышлют.
56110
Получил подтверждение - DVR подарят.
vaki
День добрый!
Кто понял как DVR к нему подключается? Особого “порта” у него не нашел. Кучка входов-выходов.
Интересует:
  1. Я смогу летая в очках, отдать видео на монитор (на монитор вместо вместо DVR) ?
  2. Как организован просмотр записи с DVR на очках?
  3. Если линза не подвижная, сможет еврочеловек не ломая глаза в них смотреть? (VR D2 не стал брать - много отзывов, что ломит глаза. это как разглядывать мобильник с 18см)
13 days later
andrei_p
Пришло письмо с бангуда о появлении в наличии. Ну а мне с али уже едет.
10 days later
vaki
Отзывы пошли на бенгуде.
>>шлем брал на замену vrd2(качество изготовления vrd2 лучшн) в целом качество нормальное. ни чего не скрепит и не люфтит. лучше стало управление. удобна возможность оставить только экран. качество картинки без изменений. из недостатков: не удобное подключение двр… ладно первый шлейф разъем рядом… но видеоаут с него идет проводом на другую сторону шлема… ну и сразу отвалились буквы на торце шлема… ну ни как не держатся. так же нет регулировки линзы… мне не очень комфортно в нем…
>>Доставка-быстро. Курьер привез на дом. Описанию соответствует. Прекрасно одевается с очками. Внизу экрана информация- уровень сигнала, частота, напряжение батареи, режим работы. Удобное меню, есть русское, но очень корявое, остался на английском. Покупкой доволен. Продавца рекомендую.
Порт есть. Т.е на внешнее устройство писать можно без колхоза.
Осталось выяснить:реально ли в нем два приемника, ну и может еще, что всплывет.
Обтюратор похоже из резины
andrei_p
Получил сегодня. Приемников вроде как правда два, лицевая прокладка из поролона на скотче. Свет не проникает, колхозить не нужно. Мне комфортно, на очки также надевается нормально.
RedGM
andrei_p:
А как качество картинки? А то на забугорном форуме вроде пишут что похуже чем у ev800
a_kopter
RedGM:
качество картинки и обзор есть тут Точнее качество камеры (не написано какой и тех видео)
Обзор на английском… Кстати, о самом шлеме Eachine VR011: выбирать в меню русский язык не стоит, т.к. исчезают наименования настраиваемых значений. Вернуться в настройку языка можно по единственному оставшейся надписи “русский”…
На присланный по предварительному заказу Eachine ProDVR Pro DVR, видео записывать можно в формате AVI: MJPG 640x480 24.771fps или AVI: MJPG 1280x720 24.984fps. При этом разрешение записи/воспроизведения камера/шлем: 800х480. На просмотр в самом шлеме это на глаз не заметно.
andrei_p
RedGM:
Сравнить возможности нет, но я вроде не вижу у себя засветки как у забугорного товарища. На днях попробую записать видео.
56110
Сегодня распаковал посылку, всё цело и даже включается.
Писалку положили.
Подобрал в оптике очки - получились +5 (зрение -1) - теперь можно подключать.
vaki
Заказал себе.
Кстати на бгуде аттракцион неслыханной щедрости по этим очкам 😃 и 11го можно не ждать
andrei_p
Сделал видео с экрана. Камера Foxeer Monster V2, все настройки стандарт.
www.youtube.com/watch?v=8eV_qOia4l4
Комплектная батарейка временем работы не впечатляет.
