Nakonjecto prisla dolgozdannaja posilo4ka 😃 v kotoroi bil reguljator 30A no toljko on i bez kakoi ljibo bumazhki o tom kak jego programmirovatj s raznimi motorami.
Pomogitete bednomu pilotu 😇
Specifications:
MYSTERY 30A Speed Controller ESC
-Size: 52.1mm x 24.5mm x 9.3mm
-Weight: 27g each
-Constant Current: 30A
-Max Current: 40A
-Input Volt: 6V - 12V
-Low-Voltage Cutoff: Auto detect and set
Advantage of the MYSTERY Speed Controller
-Low resistence
-High rate PWM
-Sixteen cells Max (with BEC disabled)
-User programmable brake
-Low voltage auto setting based on battery
-Throttle range self-adjusting
-Soft start ramp up
-Runs motor in forward or reverse
-Auto motor cutoff with reset
-Safe power arming program ensures motor will not run accidentally after turn on
-Low torque start
-Auto shut down when signal is lost
Tema zakrita.
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"400feedf3df95500777953d5":{"_id":"400feedf3df95500777953d5","hid":2755,"name":"Modris","nick":"Modris","avatar_id":null,"css":""}},"settings":{"can_see_ip":false,"can_report_abuse":false,"can_see_hellbanned":false,"forum_can_view":true,"forum_can_reply":false,"forum_edit_max_time":30,"forum_can_close_topic":false,"forum_show_ignored":false,"forum_mod_can_delete_topics":false,"forum_mod_can_hard_delete_topics":false,"forum_mod_can_see_hard_deleted_topics":false,"forum_mod_can_edit_posts":false,"forum_mod_can_pin_topic":false,"forum_mod_can_edit_titles":false,"forum_mod_can_close_topic":false,"can_vote":false,"forum_mod_can_add_infractions":false,"forum_topic_title_min_length":10,"forum_reply_old_post_threshold":30,"votes_add_max_time":168,"forum_show_post_interval":7,"can_see_deleted_users":false},"section":{"_id":"61c9a54c3df9550077bb50d8","hid":20,"title":"Электродвигатели, регуляторы, мотоустановки","parent":"61c9a54c3df9550077bb518f","description":"Коллекторные, бесколлекторные двигатели и регуляторы скорости.","is_category":false,"is_votable":true,"is_writable":true,"cache":{"topic_count":3531,"post_count":36024,"last_post":"66ceb5bbc68e4ffcbce15a94","last_topic":"66ceb5bbc68e4ffcbce15a93","last_topic_hid":572534,"last_topic_title":"Вдруг кому-то пригодится с регулем.","last_ts":"2024-08-28T05:29:31.813Z","last_user":"59ad19b83df9550077703a54"}},"topic":{"_id":"450696959970730077fa8faf","hid":49130,"title":"kakk programmirovatj esc","views_count":1380,"last_post_counter":2,"cache":{"post_count":2,"first_post":"450696959970730077fa98cb","first_ts":"2006-09-12T11:14:29.000Z","first_user":"400feedf3df95500777953d5","last_post":"4506d9b69970730077fa98cd","last_post_hid":2,"last_ts":"2006-09-12T16:00:54.000Z","last_user":"400feedf3df95500777953d5"},"st":2,"section":"61c9a54c3df9550077bb50d8"},"subscription":null,"pagination":{"total":2,"per_page":25,"chunk_offset":0},"posts_list_before_post":["paginator","datediff"]},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
