Всё о Castle Creations
BERSERK80
If you are not calibrating and have no throttle input then:
Flashing Red and Yellow = over temp
Flashing Green and Yellow = low voltage cut-off(battery)
Flashing Green OR Red = Speed control has not been calibrated and is not armed; or throttle sub-trim is not at 0.
Solid Green OR Red = should not happen when at neutral, indicates full throttle/reverse
Flashing Yellow = possible problem with controller
Solid Yellow = indicates neutral and armed
Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver.
If you are applying throttle or reverse when NOT calibrating:
Flashing Green OR Red = indicates partial throttle (green) or reverse (red)
Solid Green OR Red = indicates full throttle (green) or reverse (red)
Solid Yellow = should never happen
If you are applying throttle or reverse WHEN calibrating:
Flashing Red and Yellow = should not happen when calibrating
Flashing Green and Yellow = should not happen when calibrating
Flashing Green OR Red while beeping = indicates speed control is looking for full throttle (green) or full throttle (red). If it continues for more than ~ 8 seconds, indicates speed control is seeing partial throttle (green) or reverse (red), increase endpoints on transmitter so speed control sees full throttle/reverse.
Solid Green OR Red = indicates full throttle (green) or reverse (red) has been read
Flashing Yellow = speed control is not seeing a valid neutral signal, check your transmitters throttle sub-trim is at zero, exponential is set to 0 or linear, and mixing is disabled.
Solid Yellow = indicates neutral has calibrated and is armed
Flashing all colors = speed control is not receiving a valid signal from the receiver. Usually indicates the receiver wire is plugged in backwards into the receiver; also happens when speed control has accepted a calibration setting (throttle, reverse or neutral) and flashes/chimes 4 times before moving to next calibration point; or problem with throttle channel on receiver.
diver2008
как у самой продвинутой теме по регулям спрошу, помогите опознать феты.
поиск пока результат не дал.
Ezrun-60A вперед едет, тормозит, но нет задней и мотор не пищит.
SviridenkoA
diver2008:
Вариант с выключенным задним ходом уже исключили?
Всем спасибо и особенное Александру. Проблема оказалась в покупателе. Человек еще с зарядником даже не разобрался, воткнул акк, думал заряжается, а оказалось нет. Вобщем акк был разряжен, маргали жолтый с зеленым. Человеку помогли зарядить акк и регуль ожил 😃
diver2008
SviridenkoA:
конечно, светодиод на задний ход отрабатывает, в одном фете дырка.
idk
ребята у меня проблема, катал на саваже весь день акии 2х 2S потом 2x 3S, все было супер, уже подустали катать, стояли отдыхали (в том числе модель), немного дал газа, и отрубилось все полностью, не серва не регуль не работали, подумали на кнопку питания - НЕТ не она.
принес домой подключаю к Castle программатору, ничего не горит ну и софт не видет, и программатор сильно нагрелся - сразу отрубил. что это может быть?
прошу прощения если в этой теме была подобная проблема и я повторяю вопрос, я все неуспел посмотреть на делеле полистаю, если кто поможет ссылкой или еще как буду благодарен.
PS. Регуль стоковый BLUR загермечен был так что не придратся, ремонтопригодность затруднена из за присутствия на нем специального лака (смыть сложно растворители не берут), возможно локальное счищение с одного или нескольких элементов, помимо всего был покрыт PlastiDip, так что попадание воды или прочей влаги исключено. грешу на брак производителя и думаю что это BEC.
Wishnu
Подскажите, есть ли в Москве проверенный человек, кто может гарантированно хорошо за деньги загерметить Mamba Monster или Tekin RX8? Сам боюсь накосячить.
Напишите в личку, если кто знает таких людей.
DОКТОR
SviridenkoA:
Это куда ж ты такое льешь
Зимой по льду дрифтовать:)
diver2008:
Ezrun-60A
В нем всего 6 фетов?😃
diver2008
DОКТОR:
12, остальные с другой стороны под платой управления.
DОКТОR
diver2008:
12,
Хм… Значит должен быть выносливей, чем Sidewinder, в котором 9 фетов, но держит больший ток.
BERSERK80
Протри глаза 😅
транзисторов должно быть кратно 6
если не 6 так 12 или 12+6 и так далее
diver2008:
опознать феты
Есть спец тема аппаратура в разрезе
она как раз для того и сделана
BERSERK80
idk:
То что сгорел бек это верно
в нём пробило деталь защиты
одно из решений
убрать все детали относящиеся к беку , высверлить , выпаять в общем удалить.
Микросхему лтбрз
транзистор
и защитный диод (он и пробит)
И поставить внешний бек .
Причина Скорее всего машинка если осталась включенной то виной серво машинка "недоповёрнутые колёса " после нагрев бека и кирдык
ПСЫ также проверь серву
idk
BERSERK80:
спасибо!
убираю все эти детали, ставлю внешний BEC, транзистор я не упустил? если да то какой?
возможно ли разобрать внешний BEC и заменить погоревший диод (ну или просто заменить на аналог) как я понял это один из 2х диодов слева. (надеюсь остальные элементы в схеме BEC на регуле не постродали кроме диода.)
PS. спасибо lehuy за фото, свой фоткать не стал так как весь блестит лаком.
BERSERK80:
похоже на то… нелюблю HPI за их переделки криворукие, а серву вообще хотел поменять - уже поздно.
BERSERK80
Убрать то что помечено синим , если используешь внешний бек
Защитный диод тот что отмечен синим слева . убрав только его есть два варианта развития событий
А) заработает бек
Б) згорит мозх
Дабы рег не сгорел
можешь убрать диод и запустить рег от 6-7в . если рег заморгал
и на беке 5.5-5.78в . то значит всё ок
только учти следующий раз при пробое/перегреве без диода сдохнет всё
Юра42
SviridenkoA:
Мужик это делал не первый раз, у него заняло времени че то около 5 минут, видео даже выкладывал.
Тот мужик,это я.В эти выхи на соревках парню выбил в полевых условиях за пару минут,подш был вклеен,кстати двиг ммм 2200 проехал полтора аккума(около 20мин) передний подш в труху.Надо типа графитки как можно гуще.
vazikk
BERSERK80:
SviridenkoA
Есть смысл ставить кастловский вентилятор на двигатель 2200кв? За окном градусов 20, рабочая температура двигателя 60 градусов, аки 45-50. Производитель пишет, что магниты держат 200 градусов, а вот все остальное… До какой температуры можно греть двигатель без последствий?
SviridenkoA
Вентилятор то помогает или не особо? Пишут до 30 градусов снижает температуру, а как оно на самом деле?
DОКТОR
Кастоловские кулеры имеют весьма средненькое качество. Помогать конечно помогает, особенно если естественный обдув слабый (я его в дрифте юзал), но у меня на 540 моторе кстоловский кулер через 2 недели начал издавать противные звуки, а другой такой же (был в комплекте с системой) был неисправен.
BERSERK80
Кастловский почти не помогает
сотню ватт тепла развеять . нужен как в компе 80*80
KastetFr
SviridenkoA:
до 30-ти точно нет, но помогает чуток факт.
idk
BERSERK80:
Дабы рег не сгорел
убрал диод, подключил внешнее питание 5в (от бп для компа - другого нет под рукой) через разъем для приемника, регуль заморгал, теперь думаю заменить диод вот на такой, но не уверен в идентичности характеристик. Может вы знаете номинал родного диода ((ON) pA33 KP) я найти так и не смог, предположил что родной около 33-36 вольт, а вот мощность…?..
BERSERK80
7.5в
да этой серии
600ватт
кстати можешь параллелить их хоть до посинения
idk
BERSERK80:
7.5в
да этой серии
600ватт
что-то напаял, нет возможности проверить от li-po, в субботу буду знать наверняка работает или нет.
