Вышел новый релиз RF G3.5 -- 3.50.044
Список нововведений:
* NEW FEATURES:
* Swashplate and flybar angles can be modified
* Launcher: Added a tech support code to force shortcut recreation
* FIXED BUGS:
* Snap roll behavior works as expected for high values of the aircraft editor’s Stall Severity setting
* Snap roll momentum reduced to realistic level
* Prop wash made more effective during turns
* Helis are more responsive
* Planes in general fly at more realistic speeds
* Recalculated fuselage drag factor, resulting in aircraft with short, wide fuselages having higher top speeds
* Hover trainers: Channel mapping works as expected
* Hover trainers: Aircraft are consistently locked on the correct axis
* Airplane Hover Trainer: Airplane consistently points straight up immediately after spawn
* Heli Orientation Trainer: Arrow matches heli orientation while flying at night
* Heli Orientation Trainer: Arrow displays properly for all heli angles
* Heli Orientation Trainer: Detects overlap between user heli and ghost heli more accurately
* Channel mapping dialog works with JR radios
* Improved aircraft break-apart behavior
* Wind speed/direction and sun azimuth/inclination hotkey repeat rates are now based on Windows’ keyboard delay/repeat rate settings instead of being tied to frame rate
* Streamers move when attached to movable pods without frames
* Fuselage components are placed correctly after altering aircraft physics scale
* Tail rotors with more than two blades display all blades properly
* Debris from break-apart does not linger after the aircraft is reset
* Aircraft selection dialog: Colorscheme dropdown box is disabled when only an airframe is selected
* Chat gadget does not drop characters
* Some gadgets now locked within screen boundaries
* Preview images in exported G3X files display the aircraft correctly
* LiPoly 2100 battery specs are correct
* Misc. potential hangs and crashes eliminated
* Misc. aircraft description errors fixed
* Misc. property and settings descriptions improved
* VFI descriptions: Misc. grammar and spelling errors corrected
* Launcher: “Update to Latest Version” function works properly for versions 3.50.033 and later
* AIRCRAFT CHANGES:
* All aircraft reviewed and retrimmed by Jason Noll and John Glezellis
* BLT Park Flyer: Breaks apart after an appropriate collision
* F-16 (AO2): Increased braking strength
* F-86 (ducted fan): Exhaust behaves more realistically
* F-86 (turbine): Reduced flap deflection and flap-elevator mixing for more realistic landing
* Heli-Max Axe CP: Rests normally without sinking into the ground
* Impala (.30 training heli): Exhaust lines up with the muffler
* JetRanger: Renamed from “Jet Ranger”
