Приёмник может передавать!?
Вскрыл сегодня очередной приёмник НК-6 для пропайки. И решил найти даташит на ВЧ-часть, микруха А7105, квадратная, 20-ти контактная. Нашел. :
A7105
2.4G FSK/GFSK Transceiver
Feb. 2010, Version 1.1 1 AMIC Communication Corporation
Document Title
A7105 Data Sheet, 2.4GHz FSK/GFSK Transceiver with 500Kbps data rate
- General Description
A7105 is a high performance and low cost 2.4GHz ISM band wireless transceiver. This device integrates both high sensitivity
receiver (- 95dBm @ 500Kbps) and high efficiency power amplifier (up to 1dBm). In low data rate application, A7105 has
special strength for long LOS (line-of-sight) distance because of its ultra high sensitivity (-107 dBm @ 2Kbps, - 104 dBm @
25Kbps) with no requirement of external LNA or PA. Based on Data Rate Register (0x0E), user can configure on-air data
rates from 2Kbps to 500Kbps.
A7105 supports fast settling time (130 us) for frequency hopping system. For packet handling, A7105 has built-in separated
64-bytes TX/RX FIFO (could be extended to 256 bytes) for data buffering and burst transmission, CRC for error detection,
FEC for 1-bit data correction per code word, RSSI for clear channel assessment, data whitening for data encryption /
decryption. Those functions are very easy to use while developing a wireless system. All features are integrated in a small
QFN 4X4 20 pins package.
A7105’s control registers can be easily accessed via 3-wire or 4-wire SPI bus. For power saving, A7105 supports sleep mode,
idle mode, standby mode. For easy-to-use, A7105 has an unique SPI command set called Strobe command that are used to
control internal state machine. Based on Strobe commands via SPI bus, MCU can control everything from power saving, TX
delivery, RX receiving, channel monitoring, frequency hopping to auto calibrations. In addition, A7105 supports two general
purpose I/O pins, GIO1 and GIO2, to inform MCU its status so that MCU could use either polling or interrupt scheme to do
radio control. Hence, it is very easy to monitor radio transmission between MCU and A7105 because of its digital interface. - Typical Applications
n Wireless keyboard and mice
n Remote control
n Helicopter and airplane radio controller
n 2400 ~ 2483.5 MHz ISM system
n Wireless metering and building automation
n Wireless toys and game controllers - Feature
n Small size (QFN4 X4, 20 pins).
n Frequency band: 2400 ~ 2483.5MHz.
n FSK or GFSK modulation
n Low current consumption: RX 16mA, TX 20mA (at 0dBm output power).
n Low sleep current (1.5 uA).
n On chip regulator, support input voltage 2.0 ~ 3.6 V.
n Programmable data rate from 2Kbps to 500Kbps.
n Programmable TX power level from – 20 dBm to 1 dBm.
n Ultra High sensitivity:
u -95dBm at 500Kbps on-air data rate.
u -97dBm at 250Kbps on-air data rate
u -104dBm at 25Kbps on-air data rate
u -107dBm at 2Kbps on-air data rate
n Fast settling time (130 us) synthesizer for frequency hopping system.
n Built-in Battery Detector.
n Support low cost crystal (6 / 8 /12 / 16 / 20 / 24MHz).
n Support crystal sharing, (1 / 2 / 4 / 8MHz) to MCU.
n Support Frequency Compensation.
n Easy to use.
u Support 3-wire or 4-wire SPI.
u Unique Strobe command via SPI.
u ONE register setting for new channel frequency.
u 8-bits Digital RSSI for clear channel indication.
u Fast exchange mode during TRX role switching.
Т.е это передатчик, а функция приемника - вспомогательная.😃
И вывод рсси у него имеется - вывод №1. при отсутствии сигнала - короткие импульсы. Завтра испытаю с пультом.
Кому интересно, может нагуглить даташит, или дать мне мыло, ПДФ-5 метров.
Обычный приемопередатчик, сейчас почти все на 2.4 такие
Теоретически можно заставить передавать телеметрию. Но нужно писать процессор. Жаль, не “дорос” до них, остановился в развитии:(
У меня тоже была такая мысль хотел прошивку с передатчика прошивку в приёмник закачать схема один в один как мне показалось только в передающем модуле стоит усилитель на передачу а в приёмнике его нет а без усилителя ростояние будет мало я так думаю
что там того усилителя, пара полосковых линий да транзистор. Кстати, а найти его реально?
Найти думаю не проблема проблема все это заставить работать правильно .В своё время плотно занимался КВ аппаратурой так
без правильных приборов настроить проблема на 430мГц и с приборами геморой ну а 2.4 гГц в домашних условиях это полный мазохизм.
Покрайней мере я на это не подпишусь
Проскакивала такая темка rcopen.com/forum/f8/topic106239
Эт точно, выше 300 без анализатора нефиг делать.
